POV-Ray : Newsgroups : povray.general : I dont believe I did that! Server Time
26 Oct 2026 17:29:48 EDT (-0400)
  I dont believe I did that! (Message 1 to 36 of 36)
Subject: I dont believe I did that!
Date: 8 Aug 2000 15:42:55
Message: <399062bf@news.povray.org>
I have just stopped my IRTC entry render 2 days into a very long render{12 -
48 days!) without thinking I clicked on stop render instead of render
priority. Oh well. Try again and hope!
I've been following the 3dMax thread. Pov can do almost anything any other
program can and almost as well. Many programs do some things faster. Vue
d'esprit for instance produces excellent very fast landscapes and with it's
current import facilities it is posible to produce some very serious work.
But I still prefer Pov it is capable of the unexpected.... part of the joy
of creating. I don't get that with other programs.
The problem with Pov is media.
    1. Very slow when combined with complex CSG contructs. My IRTC entry for
example takes two hours to render without media. the media by itself takes
two hours, together though I'm looking at a very, very long render.
    2. I'm still unconvinced by the noise function correction - yes it's
mathmatically correct but it doesn't produce good clouds, I've tried. If you
have time try rerendering Mike Andrews clouds scene in Megapov 05a. As I've
said before what is needed is user control over the noise function - why not
should be easy to implement.
Radiosity is getting better all the time and I'm sure we'll learn to use it.
Pov is a great tool, fun, suprising, exciting and free...... who could ask
for more.
Me, more speed please.
Mick
Subject: Re: I dont believe I did that!
Date: 8 Aug 2000 17:17:28
Message: <chrishuff-871FD5.16183108082000@news.povray.org>
In article <399062bf@news.povray.org>, "Mick Hazelgrove"
> for example takes two hours to render without media. the media by
> itself takes two hours, together though I'm looking at a very, very
> long render.
I can't think of a reason media would be much slower in complex CSG's,
and I haven't experienced this problem myself...
> If you have time try rerendering Mike Andrews clouds scene in Megapov
> 05a. As I've said before what is needed is user control over the
> noise function - why not should be easy to implement.
The new noise function is easier to use(because it stays within the
expected range), and can already be used to simulate the old one. You
could even make a function which behaves like the old one, hard-coding
it into the program isn't necessary. Or you could just adjust the
color_maps to simulate the "plateaus" at each end of the map.
It will produce clouds which are just as good as the old noise, just not
with the exact same code.
Date: 8 Aug 2000 17:21:07
Message: <399077CA.2F2BB51B@faricy.net>
Aargh, sucks to be you! The IRTC period is two months, right? So if you take 48
days to render, that didn't leave much coding time...
Date: 8 Aug 2000 17:57:37
Message: <39908251@news.povray.org>
48 days is my worst case scenario, I hope that past a certain point it will
speed up again.
took a month to code - have my doubts as to whether it will render in time.
Mick
news:399077CA.2F2BB51B@faricy.net...
render{12 -
take 48
> David Fontaine     <dav### [at] faricynet>     ICQ 55354965
> Please visit my website: http://www.faricy.net/~davidf/
Date: 8 Aug 2000 19:04:01
Message: <399091E6.91B796C1@aol.com>
I hope you didn't restart the render!  Just have it render the missing
portion and put the two parts together with copy and paste.  I had to do
this one round when I had the superpatch continually crashing on me.
All the pixels are raytraced so it's not cheating.
Then again, if it's taking 48 days to render, you really should look
into speeding that sucker up.
-Mike
Date: 8 Aug 2000 19:23:46
Message: <39909682@news.povray.org>
"Mike" <Ama### [at] aolcom> wrote in message
news:399091E6.91B796C1@aol.com...
Why not use +C to continue the trace from where it left off?
Date: 8 Aug 2000 19:26:36
Message: <3990972c$1@news.povray.org>
Excellent idea Mike!  I for one am hoping to see Micks image, whether he
completes it in time
for the next round or not.
Doug Eichenberg
http://www.nls.net/douge
dou### [at] nlsnet
Date: 8 Aug 2000 19:45:08
Message: <39909B88.65729FB6@aol.com>
Doesn't that only work if you have that set when you begin the render?
I seem to recall never being able to restart a render because I forgot
to do that.
-Mike
Date: 8 Aug 2000 23:40:31
Message: <3990d2af$1@news.povray.org>
Chris Huff <chr### [at] maccom> wrote...
Very true.  In fact, you could use a pigment_pattern with a color_map to
reproduce the old noise (bozo) very easily.  It is just a linear correlation
between the old and the new, except that the old one would clip values, so
you couldn't reverse-transform the old one to the new one.
The following code should work, though it has not been tested at all:
#declare OldBozo = pigment
  bozo
  color_map
    [(0-0.5+1.05242 )*0.48985582, 0]
    [(1-0.5+1.05242 )*0.48985582, 1]
#declare MyPigmentUsingOldBozo = pigment
  pigment_pattern{OldBozo}  // instead of "bozo"
  color_map
    ...your color map goes here...
The mapping is (if I did the math correctly):
old_value = (new_value / 0.48985582) - 1.05242 + 0.5
-Nathan Kopp
Date: 9 Aug 2000 00:25:52
Message: <chrishuff-B30250.23265408082000@news.povray.org>
In article <3990d2af$1@news.povray.org>, "Nathan Kopp"
> to reproduce the old noise (bozo) very easily.  It is just a linear
> correlation between the old and the new, except that the old one
> would clip values, so you couldn't reverse-transform the old one to
> the new one.
...snip...
Actually, I was thinking of a function...how does this look?
#declare OldBozo =
function {max(0,min(1,noise3d(x,y,z)/0.48985582 - 1.05242 + 0.5))}
This has the advantage of being a direct replacement for isosurfaces
which use the old noise3d() function...and it is probably noticeably
faster than running a pigment through a function, and maybe even faster
than pigment_pattern.
Date: 9 Aug 2000 00:27:48
Message: <3990DBEA.BE182729@pacbell.net>
> #declare OldBozo =
It looks like something the "average" POV-Ray user would never be
able to come up with on his/her own.
Date: 9 Aug 2000 02:30:45
Message: <3990fa95@news.povray.org>
You mean the +X switch I think.  No, I never do anything but use the +C in
the ini dialog (command-line) when I need to start over at the last rendered
line.  Even in animations it will skip all the previous frames and continue
where it left off.  I checked to see if I had something set in the
povray.ini file and nothing there that would relate.  Windows version of
POV-Ray.
news:39909B88.65729FB6@aol.com...
| to do that.
| -Mike
Date: 9 Aug 2000 03:33:08
Message: <39910934@news.povray.org>
I just hope it's worth the wait!
"Doug Eichenberg" <dou### [at] nlsnet> wrote in message
news:3990972c$1@news.povray.org...
> Doug Eichenberg
> dou### [at] nlsnet
Date: 9 Aug 2000 03:35:18
Message: <399109b6@news.povray.org>
Ken is right - there's no way on earth I could have come up with that. Thank
you Nathan for the help and Chris for the iso suggestion. There are other
patterns affected by the change, will the same function work for them?
Mick
"Ken" <tyl### [at] pacbellnet> wrote in message
news:3990DBEA.BE182729@pacbell.net...
> > #declare OldBozo =
> Ken Tyler - 1400+ POV-Ray, Graphics, 3D Rendering, and Raytracing Links:
Date: 9 Aug 2000 03:36:09
Message: <399109e9@news.povray.org>
Thank you Nathan, for the info and suggestions.
Mick
"Nathan Kopp" <Nat### [at] Koppcom> wrote in message
news:3990d2af$1@news.povray.org...
correlation
>   bozo
>   color_map
>   color_map
> -Nathan Kopp
Date: 9 Aug 2000 03:38:40
Message: <39910AAB.C58D275D@aetec.ee>
> -Nathan Kopp
I wonder, whether these values are correct too? I followed this
"Wondering about Noise()" thread in programming group and as I
understand, they come from Xander's noise test, where he took several
million samples over a box. But there is no guarantee, that there does
not exist points, where noise value could exceed this range <-1.05242,
0.988997>. So I guess that better would be to just add 1, divide by 2
and clamp into range 0-1. It is easier to understand, as there is no
"Tambov constants" (as we call here constants, which should be added to
value in order to get correct result) and more logical. I guess that
little difference between this approach and current implementation in
unnoticeable.
Date: 9 Aug 2000 05:13:00
Message: <3991209b@news.povray.org>
Mick Hazelgrove <mic### [at] mhazelgrovefsnetcouk> wrote:
: I have just stopped my IRTC entry render 2 days into a very long render{12 -
: 48 days!) without thinking I clicked on stop render instead of render
: priority. Oh well. Try again and hope!
  Why didn't you just use the command line option +C to continue the render?
Date: 9 Aug 2000 10:22:44
Message: <39916934@news.povray.org>
I was so shocked at having been so stupid I was even more stupid and just
clicked render again.
Mick
news:3991209b@news.povray.org...
render{12 -
render?
Date: 9 Aug 2000 10:34:43
Message: <39916c02@news.povray.org>
: I was so shocked at having been so stupid I was even more stupid and just
: clicked render again.
  Well, we learn from our mistakes :)
Date: 9 Aug 2000 10:40:48
Message: <39916d70@news.povray.org>
I hope so:)
Mick
news:39916c02@news.povray.org...
just
Date: 9 Aug 2000 13:04:34
Message: <chrishuff-A021FA.12053809082000@news.povray.org>
In article <399109b6@news.povray.org>, "Mick Hazelgrove"
> that.
I thought it was pretty basic...just remap the values, and clamp to the
[0, 1] range to produce the plateaus. Isosurface functions were the
natural choice for this, since they can be used as a pattern and have
access to the noise function.
> Thank you Nathan for the help and Chris for the iso suggestion.
> There are other patterns affected by the change, will the same
Yes and no...you could rebuild the patterns in function form, but it
wouldn't be easy for some. It would be easier to use the pigment_pattern
for these. However, I think bozo/bumps/spotted were the main
problem...the other patterns might work fine.
Date: 9 Aug 2000 13:11:37
Message: <chrishuff-E4E0EF.12124009082000@news.povray.org>
In article <3990DBEA.BE182729@pacbell.net>, lin### [at] povrayorg
I just don't understand why not, pattern functions seemed the natural
choice, and the function is quite simple. Maybe it would be more easily
understood this way:
//clamps the value x to the range [y,z]
#declare clamp = function {max(y,min(z,x))}
//old style bozo, complete with plateaus
#declare OldBozo =
function {clamp(noise3d(x,y,z)/0.48985582 - 1.05242 + 0.5, 0, 1)}
Or are you talking about the "noise3d(x,y,z)/0.48985582 - 1.05242 + 0.5"
part? That was just the mapping copied from Nathans post.
Date: 9 Aug 2000 13:26:33
Message: <39919449@news.povray.org>
Chris, many of us gave up maths a long time ago and even then, in my case, I
didn't go much beyond what was then in England "O"levels. I have spent most
of my life as a painter, sculptor and teacher. I have a longing to go back
and try and catch up and when I retire it will be my first act. Until then I
will have to rely on asking you and others for help. Sorry!
Mick
"Chris Huff" <chr### [at] maccom> wrote in message
news:chrishuff-E4E0EF.12124009082000@news.povray.org...
> file://clamps the value x to the range [y,z]
> file://old style bozo, complete with plateaus
> #declare OldBozo =
> Christopher James Huff - Personal e-mail: chr### [at] maccom
> TAG(Technical Assistance Group) e-mail: chr### [at] tagpovrayorg
> Personal Web page: http://homepage.mac.com/chrishuff/
> TAG Web page: http://tag.povray.org/
Date: 11 Aug 2000 23:54:51
Message: <3994ca8b$1@news.povray.org>
"Mick Hazelgrove" <mic### [at] mhazelgrovefsnetcouk> wrote...
Thank
I think the only other affected patterns are wrinkles and (maybe) agate
(maybe granite, too, but I don't think so).  Those are not so easy to change
(especially using functions), but I think that using the pigment_pattern
approach would probably work.
-Nathan
Date: 12 Aug 2000 00:41:05
Message: <chrishuff-2C7F78.23421111082000@news.povray.org>
In article <3994ca8b$1@news.povray.org>, "Nathan Kopp"
> agate (maybe granite, too, but I don't think so).  Those are not so
> easy to change (especially using functions), but I think that using
> the pigment_pattern approach would probably work.
The affected patterns include:
bozo, bumps, spotted, noise3d(), all of which are identical. (well,
noise3d() can be used as a function pattern, and they aren't identical
in normals, though bozo, spotted, and noise3d() should be more useful in
normals now)
dents
agate
crackle(with "solid" on, at least)
granite
wrinkles
And of course, the ridged multifractal functions. In addition, anything
using turbulence will be affected.
However, "affected" can simply mean the image generated by the pattern
will change, the difference is probably not very noticeable most of the
time in the more complex patterns. And there isn't any difference in
actual use.
Date: 13 Aug 2000 01:59:08
Message: <39963ACA.97E3CFB2@pobox.com>
what is the significance of these numbers?
Anton Sherwood  --  br0### [at] p0b0xcom  --  http://ogre.nu/
Date: 13 Aug 2000 13:12:15
Message: <3996d6ef$1@news.povray.org>
"Anton Sherwood" <bro### [at] poboxcom> wrote...
They are a result of some tests that Xander did on the "old" noise3d
function.  The function itself has more flaws (such as a grid pattern that
you can see if you look closely).
Actually, 0.5 should probably have been used instead of 0.48985582 and 1.0
should probably have been used instead of 1.05242.  I don't know enough
about the original function to know details, though.  The issue is that the
range of the original function was incorrect.
-Nathan
Date: 13 Aug 2000 13:37:52
Message: <3996dcf0@news.povray.org>
"Chris Huff" <chr### [at] maccom> wrote...
Only crackle solid is affected.  The old-style crackle does not use noise.
Hmm... I forgot about those.
Actually, not everything.  There are two kinds of turbulence in POV.  The
first one, "Turbulence," uses the "Noise" function which is affected.  The
second one, "DTurbulence," which uses the 3D "DNoise" is not affected.  The
following patterns will use "Turbulence" if "classic" turbulence is used.
All other patterns, and all turbulence warps use DTurbulence and are
therefore not affected.
Classic turbulence affected for:
marble
spiral1
spiral2
fog
Also, iridescence uses the "Turbulence" funciton, so it is affected by the
change.
-Nathan
Date: 13 Aug 2000 14:51:39
Message: <chrishuff-FADE69.13524813082000@news.povray.org>
In article <3996dcf0@news.povray.org>, "Nathan Kopp" <Nat### [at] Koppcom>
> noise.
That is what I meant.
> The first one, "Turbulence," uses the "Noise" function which is
> affected.  The second one, "DTurbulence," which uses the 3D "DNoise"
> is not affected.
How is DNoise() different from Noise()? This is something I have never
figured out. I had just assumed both had the same problem.
> marble
> spiral1
> spiral2
I thought only agate had a specialized turbulence...why do these
patterns have a different turbulence from the others?
Date: 13 Aug 2000 15:20:01
Message: <3996F67E.1C9E657B@pobox.com>
What's crackle solid?  (I *did* rtfm!)
Date: 13 Aug 2000 16:23:13
Message: <chrishuff-9AB6A5.15241913082000@news.povray.org>
In article <3996F67E.1C9E657B@pobox.com>, Anton Sherwood
It makes each "cell" of the crackle pattern a different (solid) color,
and it is documented in the MegaPOV manual, so I suggest you rtfm again.
Specifically, section 8.3.2 "Crackle types". :-)
Date: 14 Aug 2000 03:02:32
Message: <399799BD.C847F58F@aetec.ee>
As much as I understand, Noise and DNoise should be fairly same
(DNoise's first component has same value as Noise's return value for
same evaluation point), so I think that this fix should be applied there
as well.
Date: 19 Aug 2000 01:27:04
Message: <399e1aa8$1@news.povray.org>
"Vahur Krouverk" <vah### [at] aetecee> wrote...
> as well.
The algorithm that produces the fractal pattern for DNoise and Noise is very
similar.  DNoise produces a vector of noise, while Noise produces a single
output.
The algorithm itself basically produces an output in the range of
approximately [-1,1].  This is what DNoise wants for each component, so it
doesn't change anything.  However, Noise needs to change it to [0,1] for use
in a pattern.  However, in the official conversion, the change is incorrect,
and it over-saturates the top end.  MegaPov just fixes the conversion.
The old version simply adds 0.5, while the new version (for all practical
purposes) adds 1 and then divides by two.
-Nathan
Date: 19 Aug 2000 15:14:46
Message: <399EDE48.35272C5F@pobox.com>
Oh: rtwfm; r2fm.
Just started playing with Mega yesterday.  When I get my obligatory
Shiny Sphere (containing an iso) the way I want it, I'll put it on a
plane crackle solid rather than checkered.
Date: 21 Aug 2000 03:04:43
Message: <39A0D4C8.F70BAD0F@aetec.ee>
> output.
Ah, so DNoise values are supposed to be between -1 and 1? Indeed, If I
think about it, then in official version its range was not changed
either.
By old You mean official version (3.02??) and by new 3.5?
Are those constants, found by Xander and used in MegaPOV, removed in new
version and (+1)/2 used instead?
Date: 5 Sep 2000 20:24:49
Message: <39b58ed1@news.povray.org>
> either.
It was changed, but not correctly.
Yes.
Yes.  (+1) / 2 will be used.  Remember that the constants Xander found were
very close to that and were determined by sampling a thousand or so points.
-Nathan
