POV-Ray : Newsgroups : povray.general : Feature request - density file Server Time
5 Nov 2026 23:06:30 EST (-0500)
  Feature request - density file (Message 1 to 12 of 12)
Subject: Feature request - density file
Date: 5 Aug 2000 05:14:30
Message: <398bdaf6@news.povray.org>
I really would like to be able to use an image as a pattern without having
to create a df3 file first. Something like:
pigment {density_file tga "filename.tga" [interpolate Type]
[PIGMENT_MODIFIERS...] }
From the POV-Ray documentation:
"The syntax provides for the possibility of implementing other formats in
the future."
I hope other formats will be implemented then.
Until then, is there a program that can convert an image (tga, png, or
something) into a df3? I know of Df3Maker, but that's not what I need here.
Greetings,
Rune
\ Include files, tutorials, 3D images, raytracing jokes,
/ The POV Desktop Theme, and The POV-Ray Logo Contest can
\ all be found at http://rsj.mobilixnet.dk (updated July 23)
/ Also visit http://www.povrayusers.org
Subject: Re: Feature request - density file
Date: 5 Aug 2000 05:57:38
Message: <8F87796EBseed7@204.213.191.228>
>here.
TGA2DF3 in:
Newsgroups: povray.binaries.utilities
Message-ID: <35F### [at] merlinnetau>
Date: Sat, 05 Sep 1998 05:45:23 +0930
Subject: Make df3 files from TGAs
Ingo
Date: 5 Aug 2000 12:40:17
Message: <chrishuff-6FB4B8.11411405082000@news.povray.org>
In article <398bdaf6@news.povray.org>, "Rune" <run### [at] inamecom>
> having to create a df3 file first. Something like:
> the future."
You can use an image as a pattern already, in MegaPOV. There are at
least 3 ways: image_pattern, pigment_pattern with an image_map pigment,
pigment function pattern with an image_map...
I think it would be more useful to allow a "stack" image or a group of
images to be used directly. Movie formats would also make good
additions. Like this:
density_file {tga list N
    "filename1.tga",
    "filename2.tga",
    "filename3.tga",
    "filenameN.tga"
    [interpolate Type]
density_file {qt_moov|mpeg|avi "MovieFile.mov"
    [interpolate Type]
Also, it might be nice to have movie formats as ordinary image types...
you could specify the frame number or time(with 1 being the last frame,
and 0 being the first frame). It would be an easy way to animate
image_maps.
image_map {qt_moov "MyMovie.mov" time 0.7*clock | frame int(15*clock)...
Date: 5 Aug 2000 18:02:34
Message: <hg3pos8duqeis4gpu9jbrralveimejf4ag@4ax.com>
On Sat, 05 Aug 2000 11:41:14 -0500, Chris Huff <chr### [at] maccom>
How about supporting different codecs on different platforms?
Peter Popov ICQ : 15002700
Date: 5 Aug 2000 20:06:30
Message: <398cac06@news.povray.org>
Ah yes, image_pattern was what I needed. I had forgot about that one...
However, I still think it is a bit redundant to have two different syntax
that could do basically the same things.
Rune
Date: 5 Aug 2000 20:06:32
Message: <398cac08@news.povray.org>
> > png, or something) into a df3? I know of Df3Maker, but that's
> My DMesh modeling program provides for this.
Right now I have found a better solution, but your program sure sounds
interesting, so I'll probably have a look at it another time. :-)
Greetings,
Rune
Date: 5 Aug 2000 20:06:33
Message: <398cac09@news.povray.org>
"ingo" wrote:
> TGA2DF3 in:
> From: PoD <pod### [at] merlinnetau>
Thank you!
I also went to PoD's homepage, but I only got a blank page. Anybody knows
why?
Rune
Date: 6 Aug 2000 13:34:29
Message: <398DA197.7F0CA0FF@merlin.net.au>
Rune wrote:
> "ingo" wrote:
> > TGA2DF3 in:
> Thank you!
> why?
> Rune
Odd, I just checked it and it's there. The df3 thing isn't there though.
I haven't touched that page for ages, I really should get off my arse
and do a new one.
PoD.
Date: 6 Aug 2000 18:29:25
Message: <398de6c5@news.povray.org>
"PoD" wrote:
> > Anybody knows why?
I still get a blank page. I used http://pod.phong.com/ as listed in the
links at povray.org.
Should I use another address (in which case the link at povray.org should
also be updated)?
> my arse and do a new one.
Yes, that would be great! :-)
Rune
Date: 6 Aug 2000 23:38:11
Message: <398E2D4E.8ACE01E7@pacbell.net>
> also be updated)?
I too get a blank page from that addressssssssssss............sssss.s.s.s.s
Date: 7 Aug 2000 11:51:50
Message: <398EDB14.8853F093@merlin.net.au>
Rune wrote:
> "PoD" wrote:
> > > Anybody knows why?
> also be updated)?
> Rune
Well that ain't my address. Mine is at http://www.merlin.net.au/~pod/
I've just put the df3 thingy there.
Cheers, PoD.
Date: 7 Aug 2000 12:11:05
Message: <398EDDBE.41BF287D@pacbell.net>
It used to be but i just updated the link to the one you just gave.
