POV-Ray : Newsgroups : povray.general : 3D file formats, including Warps PCM format Server Time
26 Aug 2025 05:28:49 EDT (-0400)
  3D file formats, including Warps PCM format (Message 1 to 7 of 7)
Subject: 3D file formats, including Warps PCM format
Date: 18 Jul 2000 23:25:50
Message: <39751fbe@news.povray.org>
Notice the effect that Warps mesh compressor had on the file size of the
POV file... dropped it from 12.6M to 3.12M... a 75% decrease in size.
Strata StudioPro (.vis)         1.29M
3D Studio          (.3ds)        1.35M
TrueSpace         (.cob)        1.88M
Imagine              (.iob)         2.64M
DirectX              (.x)            2.75M
Warps PCM      (.pcm)       3.12M     <======
Renderman         (.rib)         3.64M
VRML               (.wrl)         4.67M
Wavefront          (.obj)         5.04M
Renderware       (.rwx)         5.54M
AutoCAD          (.dxf)          6.04M
Alias                   (.tri)           7.40M
OpenGL C code (.c)            7.68M
QuickDraw 3D   (.3dm)        8.13M
stereolithography (.stl)           11.8M
POV                   (.pov)        12.6M
Pro/E                  (.slp)          16.8M
Lightscape           (.lp)           19.1M
-Doug Eichenberg
Subject: Re: 3D file formats, including Warps PCM format
Date: 19 Jul 2000 03:41:54
Message: <39755AF0.17184DD4@inapg.inra.fr>
What about the POV mesh2 format ? It should be around 4-5 M I guess.
G.
Date: 19 Jul 2000 19:08:26
Message: <397634ea@news.povray.org>
Is there a utility to convert to Mesh2 format?  I haven't really looked
into it yet...
- Doug Eichenberg
Date: 20 Jul 2000 04:08:00
Message: <3976B289.A1C2F097@inapg.inra.fr>
> into it yet...
There are several of them (at least 3DS2POV, objuvpov, pose2pov). You can
look at this page here for more info :
http://www.mediaport.net/Artichaud/Tran/sources/tutuve.htm
G.
Date: 20 Jul 2000 11:11:54
Message: <397716ba@news.povray.org>
By the way, did you use the default compression or the extra compression?
Could you try both? I'm interested in the size difference between the two
in this case.
Date: 20 Jul 2000 17:17:44
Message: <39776c78$1@news.povray.org>
Default.
> Could you try both? I'm interested in the size difference > between the
two in this case.
Sure.  I'll check it out within the next couple days, along with mesh2.
- Doug Eichenberg
Date: 20 Jul 2000 17:19:28
Message: <39776ce0$1@news.povray.org>
Thanks.  I'll check out the mesh2 size and post it here.
- Doug Eichenberg
