Threre was a thread some time ago about Lightflow...
I wanted to try it but I run across the same problem whether I run it
with Linux or Windows 98.
When I type the command in a console (after a 'proper' installation)
"python sphere.py", the program returns an error :
>>Error (LlFault):>>LfNoiseInit()>>unable to open "noise.dat"
The file noise.dat does exist in the same directory.
Has anyone had the same problem and managed to solve it ?
My apologies if this is off-topic..
Fabien Hénon
Perhaps comp.graphics.rendering.raytracing (in usenet) could be a better
newsgroup?
Fairly simple solution. Find the file named 'noise.dat' (it may probably
be in a different directory than the one where your .py script is
located). Move it into the same directory as the script. Render away the
file again. Its a good idea to set your environment variables and paths
so Lightflow knows where to look for other files and such.
Fabien Hénon wrote:
> Threre was a thread some time ago about Lightflow...> I wanted to try it but I run across the same problem whether I run it> with Linux or Windows 98.>> When I type the command in a console (after a 'proper' installation)> "python sphere.py", the program returns an error :>> >>Error (LlFault):> >>LfNoiseInit()> >>unable to open "noise.dat">> The file noise.dat does exist in the same directory.>> Has anyone had the same problem and managed to solve it ?>> My apologies if this is off-topic..>> Fabien Hénon
I forgot to say that the file noise.dat *is* in the same directory and the
environnement variables are set properly.
Fabien Hénon
Maria Quevedo a écrit :
> Fairly simple solution. Find the file named 'noise.dat' (it may probably> be in a different directory than the one where your .py script is> located). Move it into the same directory as the script. Render away the> file again. Its a good idea to set your environment variables and paths> so Lightflow knows where to look for other files and such.>> Fabien Hénon wrote:>> > Threre was a thread some time ago about Lightflow...> > I wanted to try it but I run across the same problem whether I run it> > with Linux or Windows 98.> >> > When I type the command in a console (after a 'proper' installation)> > "python sphere.py", the program returns an error :> >> > >>Error (LlFault):> > >>LfNoiseInit()> > >>unable to open "noise.dat"> >> > The file noise.dat does exist in the same directory.> >> > Has anyone had the same problem and managed to solve it ?> >> > My apologies if this is off-topic..> >> > Fabien Hénon
