POV-Ray : Newsgroups : povray.general : How do you make really transparent glass? Server Time
26 Aug 2025 07:35:34 EDT (-0400)
  How do you make really transparent glass? (Message 1 to 3 of 3)
Subject: How do you make really transparent glass?
Date: 27 Jun 2000 21:53:36
Message: <39595aa0@news.povray.org>
I have been trying to model a hollow glass sphere (cut in half via a clipped
plane)  Whenever I place the glass object over some steel stuff
(polished_chrome) the part under the glass becomes pretty dark compared to
the same stuff outside the glass.  I know that some light will be reduced
but is there any way to let the light come through 99% or so?  I can
increase the ambient level of the steel under the glass but then it starts
to look "plasticky."  I would like to retain the "reflectivity" of the glass
just allow enough light back through so I don't have to mess with the steel
ambient level.
Here is the object code:
#declare Dome =
difference {
   sphere { <0,0,0> 2.35}
   sphere { <0,0,0> 2.25}
   texture {pigment { rgbf <1,1,1,1>}}
   interior {ior 1.0 }
   finish{
      reflection 0.1
      diffuse 0.1
      specular 0.1
      phong 0.15
   scale <1,1,0.25>
   clipped_by{plane{z,0}}
Subject: Re: How do you make really transparent glass?
Date: 27 Jun 2000 22:50:12
Message: <395966F0.BE924B2C@pacbell.net>
Try increasing the max_trace_level in your global setting statement.
See also -
http://www.students.tut.fi/~warp/povVFAQ/languageVFAQ.html#maxtracelevel
Date: 27 Jun 2000 23:00:26
Message: <chrishuff-F34E62.22002727062000@news.povray.org>
In article <39595aa0@news.povray.org>, "Patrick Dugan"
> clipped plane)  Whenever I place the glass object over some steel
> stuff (polished_chrome) the part under the glass becomes pretty dark
> compared to the same stuff outside the glass.  I know that some light
> will be reduced but is there any way to let the light come through
> 99% or so?  I can increase the ambient level of the steel under the
> glass but then it starts to look "plasticky."  I would like to retain
> the "reflectivity" of the glass just allow enough light back through
> so I don't have to mess with the steel ambient level.
Having a filter or transmit of 1 *is* 100% transparent, though things
like reflections may obscure this.
You might be running into max_trace_level in global_settings if you
haven't raised it from the default. It controls the number of surfaces
POV will refract, transmit, or reflect rays through. Beyond this limit,
the background color is used. Since the default background is black,
this usually produces black streaks, specks, darkened areas, or other
artifacts.
