POV-Ray : Newsgroups : povray.general : Bug when animating the angle of the camera Server Time
13 May 2026 16:00:00 EDT (-0400)
  Bug when animating the angle of the camera (Message 1 to 3 of 3)
Subject: Bug when animating the angle of the camera
Date: 21 Jun 2000 11:59:36
Message: <39513B4A.849565A7@home.nl>
I was reading the povray html manual about the camera for translating
effects. I read about the angle. Viewing angles bigger than 360 degrees
should give special fx, so I thought let's try. I use the standard
camera. The viewing angle had to be smaller than 180 degrees. Perhaps
this could be set in the manual?
I pulled it on 179 and added a clock, to see the differences, between
no angle and full angle.
Povray then seg faults when creating the vista light buffers.
I'm using Povray for Linux version 3.1g.linux.gcc.
A core is dumped, if anyone needs it, I can mail it.
Remco Poelstra
Subject: Re: Bug when animating the angle of the camera
Date: 21 Jun 2000 15:15:27
Message: <chrishuff-8B6141.14195021062000@news.povray.org>
In article <39513B4A.849565A7@home.nl>, Remco Poelstra
It *is* in the manual:
4.4.2  Types of Projection
  If none is specified, the perspective  camera is the default.
Perspective projection:
... The viewing angle has to be larger than 0 degrees and smaller than
180 degrees.
(severely clipped to save space)
Does this happen without using clock? Have you tried using #debug to
make sure your angle value is within the 0-180 range?
Personal Web page: http://chrishuff.dhs.org/
Date: 21 Jun 2000 15:26:07
Message: <39516BB2.2CEFDCD2@home.nl>
> 180 degrees.
I looked at the angle page of the camera, there it was not specified.
But you are right.
Without clock everything is fine.
Well, it's a bit my error. When multiplexing angle with clock, the first
value is 0.
But I think povray should give a message if such an error is made (like
when you specify an angle >= 180) and not seg fault.
Remco Poelstra
