POV-Ray : Newsgroups : povray.general : Image Size Server Time
26 Oct 2026 21:26:14 EDT (-0400)
  Image Size (Message 1 to 8 of 8)
Subject: Image Size
Date: 13 Jun 2000 02:13:16
Message: <3945d0fc@news.povray.org>
Could anyone tell me if there is a limit to the resolution of images you
create with povray? could i for instance create an image 10240x7680 ? do
different file formats only support up to a maximum resolution?
Thanx
John
Subject: Re: Image Size
Date: 13 Jun 2000 02:46:15
Message: <3945D8E4.4FAFE315@hotmail.com>
Theoretically YES but practically NO - limited by RAM - for image bytes &
virtual mem & when I tried it with a simple scene POV took forever to create
light buffers.
Pabs
Date: 13 Jun 2000 05:17:03
Message: <3945FC0F.39424AEE@gmx.de>
> Thanx
> John
I don't know about pov, but file formats are limited by width and height
data fields:
        TGA :           16 Bit (65535x65535)
        PNG :           32 Bit (... ;-)
Thats probably far away from usual values
(24 Bit TGA uncompressed 65535x65535 would be 12 GB !)
HTH, Christoph
Date: 13 Jun 2000 07:01:51
Message: <wbwvjtondv.fsf@infostream.no>
[Christoph Hormann <chr### [at] gmxde>]
But on some OSes (like Windows) your image would be limited by the
filesystem.
Never attribute to malice that which
can be adequately explained by stupidity.
Date: 13 Jun 2000 23:12:16
Message: <3946EA34.A4C0D047@peak.edu.ee>
> filesystem.
I don't understand. What is the limiting factor? (besides FAT 16 maximum
partition size)
Margus Ramst
Date: 14 Jun 2000 00:33:51
Message: <3946FD51.24B175ED@peak.edu.ee>
If I'm not mistaken, an A1 print at 1440 DPI would be 33,675 by 47,678 points.
Granted, this is an extreme example - but even a 'mere' A4 print would be 11,904
by 16,837 points.
So these numbers are not quite as imossible as they might seem. Working with
images intended for high-quality printing is a royal pain, to say the least.
Margus Ramst
Date: 14 Jun 2000 03:50:16
Message: <39473938@news.povray.org>
In article <3946EA34.A4C0D047@peak.edu.ee> , Margus Ramst
>> filesystem.
> partition size)
There are still a lot of filesystems that have a 2 GB or 4 GB file size
limit.  Additionally, a lot of applications make assumptions about certain
system file IO functions, i.e. when seeking inside a file and using long or
unsigned long (which is most likely 32 bit on common platforms today).
    Thorsten
e-mail: tho### [at] trfde
Date: 14 Jun 2000 04:54:11
Message: <39474833.2383C242@gmx.de>
> by 16,837 points.
Normally, you do not need a full printer resolution image for printing,
because the printer has to do rastering anyway, even though some people
recommend exactly that.
AFAIK a high quality offset print for example for illustrated books has
about 100 to 300 dpi.
