POV-Ray : Newsgroups : povray.general : POV variables in parametric function Server Time
24 Mar 2026 13:21:55 EDT (-0400)
  POV variables in parametric function (Message 1 to 3 of 3)
Subject: POV variables in parametric function
Date: 8 Jun 2000 07:51:32
Message: <393F88C4.9B0A6B8@itam.cas.cz>
  I tried to use POV variables inside function declaration in
  paramatric surface primitive and it told me, that
  another variable than u and v in function definition.
  I'am doing something bad or its normal?
  I want to use it in curved stairway macro, where I
  need "spiral tube" to represent railing.
Disnel
Subject: Re: POV variables in parametric function
Date: 9 Jun 2000 18:33:49
Message: <NVmYYAAdBXQ5EwNZ@econym.demon.co.uk>
Wasn't it Vaclav Cermak who wrote:
>Hi,
You can predefine your function using any kind of variable you like. If
you don't predefine the function you can't used "parametric" variables
(such as x, y, z and r) but you can use other scalar variables.
E.g. you can't say:
   parametric {
      function sin(z), . . .
because you can't use a parametric variable in that position.
You *can* say
   #declare A = 0.5;
   parametric {
      function sin(A*u), . . .
because non-parametric variables are allowed.
You can also say
   #declare F1=function(sin(z))
   parametric {
      function F1(u,v,0), . . .
but the result probably won't behave in the way you expect.
I guess that what you probably want for the handrail to a spiral
staircase is something like the following: R1 is the radius of the
staircase; R2 is the radius of the handrail tube; F controls the
frequency of the helical turns.
  #declare R1=1;
  #declare R2=0.1;
  #declare F=5;
  parametric {
    function R1*sin(F*v)+R2*sin(u),
             v,
             R1*cos(F*v)+R2*cos(u)
      <-pi,-1>,<pi,1>
      <-R1-R2,-1,-R1-R2>,<R1+R2,1,R1+R2>
But you could have achieved this result more easily with the built-in
"helix1" isosurface.
Mike Williams
Gentleman of Leisure
Date: 12 Jun 2000 08:30:24
Message: <3944D6D8.30926DF0@itam.cas.cz>
It works, thanks
Disnel
