I have a while loop which runs through numbers calculating a coordinate and
radius of a sphere. What I'm trying to do is have these coordinates and
radii be entered into a sphere_sweep in order to serve as its sphere list.
I tried placing the while loop in the sphere_sweep code but received an
error message. Is there any way to do this with an array? I'm
inexperienced with arrays so any help would be appreciated.
Thanks, I only try bothering the group as a last resort:)
-Chris-
Hmm, that should work... What's the message? and check your syntax :-)
David Fontaine <dav### [at] faricy net> ICQ 55354965
error: no matching } in sphere_sweep, < found instead
#declare Rand01 = seed(34747);
#macro Tree_Root(X,Y,Z,R,L,Next)
#declare counter=0;
sphere_sweep {
linear_sphere_sweep,
10,
#while(Next>0)
<X,Y,Z>,R
#declare R=R/1.05;
#local X=X-rand(Rand01)*2;
#local Y=Y-rand(Rand01);
#local Z=Z-rand(Rand01)*2;
#declare Next=Next-.1;
#declare counter=counter+1;
union{
Tree_Root(0,0,0,2,1,1)
pigment{color rgb <1,0,0>}}
-Chris-
David Fontaine <dav### [at] faricy net> wrote in message
news:39372DF5.AAB80A80@faricy.net...
and
list.
> Please visit my website: http://www.faricy.net/~davidf/
Chris S. wrote in message <3937ceeb@news.povray.org>...
> #declare counter=0;
> sphere_sweep {
> 10,
> #while(Next>0)
> <X,Y,Z>,R
You need a comma after R for each entry except the last.
Gail
* gsh### [at] monotix co za * Reality.dat not found *
* http://www.rucus.ru.ac.za/~gail/ * Attempting to reboot universe *
* The best way to accelerate Windows NT is at 9.8 m/s^2 *
It is a float precision problem (in decrementing of Next by 0.1). Because of it
your loop goes through 11 iterations instead of 10. It' will work fine if you
change Next to 10 and decrement it by 1 insted of 0.1
Note that this is not a bug; floating point math is just not infinitely precise,
and 0.1 is a problematic number, since it can't be presented accurately in
binary notation (just like 1/3 in decimal).
Margus Ramst
Personal e-mail: mar### [at] peak edu ee
TAG (Team Assistance Group) e-mail: mar### [at] tag povray org
Wow, that was it. Problem fixed, thanks.
-Chris-
Margus Ramst <mar### [at] peak edu ee> wrote in message
news:3937FD1B.D6427D09@peak.edu.ee...
of it
you
precise,
> Margus Ramst
An example taken from the help file:
sphere_sweep {
b_spline_sphere_sweep, 4,
<-5, -5, 0>, 1
<-5, 5, 0>, 1
< 5, -5, 0>, 1
< 5, 5, 0>, 1
sphere_sweep_depth_tolerance 1.0e-3
Ah, I remember that crap... took me a while to figure it out when it happened to me.
It could happen to you, to. *points finger* ;-)
> #declare counter=0;
> sphere_sweep {
> 10,
> #while(Next>0)
> <X,Y,Z>,R
> #declare R=R/1.05;
> #end
>#end
>union{
It's a rounding error.
If you subtract .1 from 1 10 times you get a number that's not quite
exactly zero, because floating point arithmetic is never exact. So,
after the tenth iteration "Next" turns out to be very slightly greater
than zero, so "#while(Next>0)" is still true, and the eleventh iteration
produces the error.
Dirty fix: #while(Next>0.01)
Clean fix: #while(counter<10)
This is a better fix because it will work even if you call the Tree_Root
macro with the sixth parameter not equal to 1.
Mike Williams
Gentleman of Leisure
Mike Williams <mik### [at] nospam please> wrote:
: If you subtract .1 from 1 10 times you get a number that's not quite
: exactly zero, because floating point arithmetic is never exact.
False. For some values floating point arithmetic is very exact.
For example, 1.0+1.0 is exactly 2.0, no less, no more.
However, for some other values it might not be. For example 0.1+0.1 may not
be exactly 0.2 (although 0.5+0.5 is exactly 1.0).
>sphere_sweep {
> <-5, -5, 0>, 1
> <-5, 5, 0>, 1
> < 5, -5, 0>, 1
> < 5, 5, 0>, 1
Oh. Has the syntax changed recently. I remember
having to put commas in. <Notes to read help file again>
Gail
> >sphere_sweep {
> > <-5, -5, 0>, 1
> > <-5, 5, 0>, 1
> > < 5, -5, 0>, 1
> > < 5, 5, 0>, 1
I believe either way works. I'm just saying that that was not the
problem...
