POV-Ray : Newsgroups : povray.general : Array Question Server Time
26 Oct 2026 22:11:03 EDT (-0400)
  Array Question (Message 1 to 12 of 12)
Subject: Array Question
Date: 1 Jun 2000 21:56:02
Message: <39371432@news.povray.org>
I have a while loop which runs through numbers calculating a coordinate and
radius of a sphere.  What I'm trying to do is have these coordinates and
radii be entered into a sphere_sweep in order to serve as its sphere list.
I tried placing the while loop in the sphere_sweep code but received an
error message.  Is there any way to do this with an array?  I'm
inexperienced with arrays so any help would be appreciated.
Thanks, I only try bothering the group as a last resort:)
-Chris-
Subject: Re: Array Question
Date: 1 Jun 2000 23:50:03
Message: <39372DF5.AAB80A80@faricy.net>
Hmm, that should work... What's the message? and check your syntax :-)
Date: 2 Jun 2000 11:12:43
Message: <3937ceeb@news.povray.org>
error:  no matching } in sphere_sweep, < found instead
#declare Rand01 = seed(34747);
#macro Tree_Root(X,Y,Z,R,L,Next)
    #declare counter=0;
    sphere_sweep {
      linear_sphere_sweep,
      10,
      #while(Next>0)
        <X,Y,Z>,R
        #declare R=R/1.05;
        #local X=X-rand(Rand01)*2;
        #local Y=Y-rand(Rand01);
        #local Z=Z-rand(Rand01)*2;
        #declare Next=Next-.1;
        #declare counter=counter+1;
union{
Tree_Root(0,0,0,2,1,1)
pigment{color rgb <1,0,0>}}
-Chris-
David Fontaine <dav### [at] faricynet> wrote in message
news:39372DF5.AAB80A80@faricy.net...
and
list.
> David Fontaine     <dav### [at] faricynet>     ICQ 55354965
> Please visit my website: http://www.faricy.net/~davidf/
Date: 2 Jun 2000 15:14:23
Message: <3938078f@news.povray.org>
Chris S. wrote in message <3937ceeb@news.povray.org>...
>    #declare counter=0;
>    sphere_sweep {
>      10,
>      #while(Next>0)
>        <X,Y,Z>,R
You need a comma after R for each entry except the last.
Gail
* gsh### [at] monotixcoza              * Reality.dat not found         *
* http://www.rucus.ru.ac.za/~gail/ * Attempting to reboot universe *
* The best way to accelerate Windows NT is at 9.8 m/s^2      *
Date: 2 Jun 2000 15:28:41
Message: <3937FD1B.D6427D09@peak.edu.ee>
It is a float precision problem (in decrementing of Next by 0.1). Because of it
your loop goes through 11 iterations instead of 10. It' will work fine if you
change Next to 10 and decrement it by 1 insted of 0.1
Note that this is not a bug; floating point math is just not infinitely precise,
and 0.1 is a problematic number, since it can't be presented accurately in
binary notation (just like 1/3 in decimal).
Margus Ramst
Date: 2 Jun 2000 16:22:08
Message: <39381770@news.povray.org>
Wow, that was it.  Problem fixed, thanks.
-Chris-
Margus Ramst <mar### [at] peakeduee> wrote in message
news:3937FD1B.D6427D09@peak.edu.ee...
of it
you
precise,
> Margus Ramst
> Personal e-mail: mar### [at] peakeduee
> TAG (Team Assistance Group) e-mail: mar### [at] tagpovrayorg
Date: 2 Jun 2000 16:42:36
Message: <39381B41.50601093@faricy.net>
An example taken from the help file:
sphere_sweep {
  b_spline_sphere_sweep, 4,
  <-5, -5, 0>, 1
  <-5, 5, 0>, 1
  < 5, -5, 0>, 1
  < 5, 5, 0>, 1
  sphere_sweep_depth_tolerance 1.0e-3
Date: 2 Jun 2000 16:44:13
Message: <39381BA1.B2E34F7A@faricy.net>
Ah, I remember that crap... took me a while to figure it out when it happened to me.
It could happen to you, to. *points finger* ;-)
Date: 2 Jun 2000 16:48:43
Message: <4z$1BGAC1BO5EwZ6@econym.demon.co.uk>
>    #declare counter=0;
>    sphere_sweep {
>      10,
>      #while(Next>0)
>        <X,Y,Z>,R
>        #declare R=R/1.05;
>     #end
>#end
>union{
It's a rounding error.
If you subtract .1 from 1 10 times you get a number that's not quite
exactly zero, because floating point arithmetic is never exact. So,
after the tenth iteration "Next" turns out to be very slightly greater
than zero, so "#while(Next>0)" is still true, and the eleventh iteration
produces the error.
Dirty fix:   #while(Next>0.01)
Clean fix: #while(counter<10)
This is a better fix because it will work even if you call the Tree_Root
macro with the sixth parameter not equal to 1.
Mike Williams
Gentleman of Leisure
Date: 3 Jun 2000 08:14:10
Message: <3938f692@news.povray.org>
Mike Williams <mik### [at] nospamplease> wrote:
: If you subtract .1 from 1 10 times you get a number that's not quite
: exactly zero, because floating point arithmetic is never exact.
  False. For some values floating point arithmetic is very exact.
  For example, 1.0+1.0 is exactly 2.0, no less, no more.
  However, for some other values it might not be. For example 0.1+0.1 may not
be exactly 0.2 (although 0.5+0.5 is exactly 1.0).
Date: 5 Jun 2000 02:58:50
Message: <393b4faa@news.povray.org>
>sphere_sweep {
>  <-5, -5, 0>, 1
>  <-5, 5, 0>, 1
>  < 5, -5, 0>, 1
>  < 5, 5, 0>, 1
Oh. Has the syntax changed recently. I remember
having to put commas in. <Notes to read help file again>
Gail
Date: 7 Jun 2000 17:52:34
Message: <393EC318.8FE9C6C3@faricy.net>
> >sphere_sweep {
> >  <-5, -5, 0>, 1
> >  <-5, 5, 0>, 1
> >  < 5, -5, 0>, 1
> >  < 5, 5, 0>, 1
I believe either way works. I'm just saying that that was not the
problem...
