POV-Ray : Newsgroups : povray.general : re hammerpatch Server Time
10 Sep 2025 07:20:26 EDT (-0400)
  re hammerpatch (Message 1 to 4 of 4)
Subject: re hammerpatch
Date: 28 May 2000 06:28:07
Message: <3930f4b7@news.povray.org>
How can you
1. Add a point into a line
2. join points
Thanks
Mick
Subject: Re: re hammerpatch
Date: 28 May 2000 13:57:25
Message: <MPG.139b6b80f9fa27ce9896ca@news.stmuc.com>
> How can you
Same way as in sPatch.  Select the Patch tab, select the add point tool,
click on one of the points already existing on the line and work from
there, or the other route is to select the line you want to add the point
to, using TAB.  Delete the line, add a new point halfway along the line
and then weld it to the existing points at each end of the old line.
Did that make any sense?
> 2. join points
Same way as in sPatch <grin>
Using the move tool, move the point over the point you want to weld it
to, then, whilst holding down the LMB, click the RMB.
Bye for now,
     Jamie.
Date: 28 May 2000 18:08:17
Message: <3931995D.D041B0FF@aol.com>
You might want to know that pressing the 'a' button on the keyboard selects
the 'add point' tool.
Jamie Davison wrote:
> > How can you
> > 2. join points
> Bye for now,
>      Jamie.
Samuel Benge
E-Mail: STB### [at] aolcom
Visit my isosurface tutorial at http://members.aol.com/stbenge
Date: 29 May 2000 15:39:56
Message: <MPG.139bb939fb00dd169896cb@news.stmuc.com>
In article <3931995D.D041B0FF@aol.com>, STB### [at] aolcom says...
Not on my copy it doesn't :)  I reallocated it to the 'insert' key.
Ahh...  The ability to define your own keymappings, and thus sPatch takes
another slight knock on the road to being dislodged from my heart <big
grin>
I suppose I should have made it clearer on the description of welding
points that it was the move *points* tool that you use, since trying to
do it with the move camera viewpoint tool is a tad annoying (yes, I got
confused the first time I played with hamaPatch :)
Bye for now,
     Jamie.
