Hello all,
Has anyone tried to create a large sphere that uses a realistic
water look.
I am trying to create a world that is covered with water, but all my
attempts have been far from perfect.
The planet is a sphere 7000 units in diameter, with a scale of 1
unit per kilometer.
One attempt looked good from afar, but from "ground" level, was a
disaster.
Basically what I am trying to do is a scene based on the Arthur C
Clarke novel, Songs Of Distant Earth, which features a planet in the
early stages of developement, is almost all covered with water except
for a small archipelago where the story takes place.
I have scaled the scene big, so that I can bring the camera down to
ground level to view the islands and, hence the need for a realistic
ocean.
If you can help, thank you in advance.
,-._|\ Alex McMurray
/ Oz \ ale### [at] melbpc org au Melbourne PC User Group.
\_,--.x/Melton. Vic. 3337 Australia
v
Oceans have been done aplenty. The trouble you might have most is to
get the correct appearance for both near and far. That will possibly
entail doing texture shifting with distance. In other words, adding the
camera distance value into textures in order to change them in a
predictable way. And that might or might not be feasible.
"Alex McMurray" <ale### [at] melbpc org au> wrote in message
news:392B7B3F.FF63CDF4@melbpc.org.au...
| water look.
my
| unit per kilometer.
| disaster.
Bob Hughes wrote:
> That will possibly entail doing texture shifting with distance. In other
> words, adding the
> Bob
Thanks Bob, That was something I never thought of. I have had success using
camera distance values for other scenes, if I can find time to sit at the
confuser for a while, I will give it a go.
I was hoping to be able to animate a lift off from "ground" level up to an
orbiting platform, but I may not be able to if I use texture shifting.
\_,--.x/ P.O. Box 215 Melton. Vic. 3337 Australia
v
Alex McMurray wrote in message <392B7B3F.FF63CDF4@melbpc.org.au>...
>water look.
>disaster.
You could try a physically realistic model, by making the ocean look good
from ground level, then doing extreme antialiasing for shots from higher up.
It might take a little while to render, though....
Mark
Perhaps you could do a LOD (level of detail) shift as you go through the cloud
layer and the ground is briefly obscured. That's supposing a) you can keep the
two detail levels looking similar and b) you are planning a cloud layer.
Generally, what looks good at ground level _could_ be made to look good from
space, since that's how it works in nature :)
Margus Ramst
Personal e-mail: mar### [at] peak edu ee
TAG (Team Assistance Group) e-mail: mar### [at] tag povray org
> Margus Ramst
Hmmm, the suggestions by both you and Serge may be just what I am
looking for,
along with Bobs. My son who is a little better at this kind of thing
than I am,
offered to help. For me it will be a bit of a learning curve as I have
only done
LOD shifts with objects and not textures, but it should not be all that
much
different.
Maybe I should be nature to do it for me!! ;)
\_,--.x/ Melton. Vic. 3337 Australia
v
> Mark
I am hoping to animate this at a later stage and with extreme AA, it may
be very
time consuming, but it is worth a try, you never know, there may even be
a work
around.
Thank you Alex.
BTW Bob, your trace function for cameras over HF's was just what I was
looking for. I have had a animation on the backburner for a while now,
because of a lack of knowledge or just plain laziness.
Thanks Alex.
v
