POV-Ray : Newsgroups : povray.general : Refraction question. Server Time
26 Oct 2026 22:10:13 EDT (-0400)
  Refraction question. (Message 1 to 3 of 3)
Subject: Refraction question.
Date: 21 May 2000 14:19:54
Message: <392828ca@news.povray.org>
I have some problems with refraction. If I put an object inside another;
both transparent; the innermost turns black! When only partially inside, the
part inside still is black, but the bart outside looks fine. Here's a
detailed description:
I wanted to make an image with a glass and water inside it. The glass has
ior 1.44 and the water an ior of 1.33. The glass is a merge-thing:
merge {
    intersection { a cylinder with a smaller cylinder }  // this makes a
cylinder with one end open and kind of hollowed out; just like a real glass
("water-container".)
    torus // at the rim of the glass
        pigment { color rgbf 1 }
        finish { some phong, no reflection }
    interior { ior 1.44 }
And the water is placed inside:
intersection {
    a plane, tilted to make a sloped surface on the water
    a cylinder, slightly smaller than the inside of the glass
    texture { same as glass }
    interior { ior 1.33 }
There is a checkered gound plane, too... :)
The problem is, that although the water-object is fully visible, it is
black! Also, when I change the ior of the glass to 1, the problem still
persists. Also, when I extend the water to be higher than the glass, the
part outside the glass is fully transparent.
Things I've tried, but didn't make me any wiser:
*max_intersections increase.
*removal of the glass - water looks fine.
*transmit instead of filter (ecxactly the same results)
*render it in megapov (blind shot, there...)
I cannot figure this out, and it really makes me angry at my computer! Can
anyone explain these results or maybe solve my problem, before I smash my
screen! (nonono...I won't.)
Simen Kvaal.
Subject: SV: Refraction question.
Date: 21 May 2000 14:43:41
Message: <39282e5d@news.povray.org>
"Simen Kvaal" <sim### [at] studentmatnatuiono> skrev i meddelandet
news:392828ca@news.povray.org...
the
[snip]
Hmm, you haven't raised max_trace_level? If not, then I'm sure that's the
culprit...
Sebastian Strand
   E-mail: thezeb -at- bigfoot -dot- com
    URL: http://www.zeb.f2s.com/
Subject: Re: Refraction question.
Date: 21 May 2000 18:14:03
Message: <39285fab@news.povray.org>
Thank you! I read the docs about max_trace_level, and at first I didn't
catch the difference from max_intersections. This solved my problem, and
thank you and Chris Huff for pointing it out for me! :) I am _so_ happy, and
my computer screen survived once again. ;-)
Simen.
>culprit...
