POV-Ray : Newsgroups : povray.general : CSG Union causes major slow-down Server Time
6 Nov 2026 05:08:38 EST (-0500)
  CSG Union causes major slow-down (Message 1 to 26 of 26)
Subject: CSG Union causes major slow-down
Date: 20 May 2000 03:15:56
Message: <39263bac@news.povray.org>
I made a scene of a stone wall. The stones were created as individual
objects (a couple hundred of 'em), and the scene rendered properly in about
30 minutes at 1024x768 resolution. I decided to make a single "BrickWall"
object (using a macro) that was a union of all the individual stones, and
suddenly it took almost NINE HOURS to render the same scene, although it
looked the same! Did I do something wrong? Is there a solution to this
problem? I would like to keep the union so that I can easily manipulate
multiple stone walls in my scene.
Dave
Subject: Re: CSG Union causes major slow-down
Date: 20 May 2000 03:50:36
Message: <392643cc@news.povray.org>
BTW, I should have mentioned that peak memory used is only about 12MB with
the CSG Union version, and my computer has 128MB RAM. There's no disk
thrashing going on, but maybe this is a CPU cache issue?
Date: 20 May 2000 05:05:44
Message: <i1lciskkd7l89lm1gfa3ocom0298vrtu35@4ax.com>
On Sat, 20 May 2000 00:46:43 -0700, "Dave Blandston"
No, not at all. It's related to bounding. Are you using manual
bounding? Is automatic counding on? Most importantly, is union
splitting on? How about removing user bounds (if any)? Are vista and
light buffers on?
What is most probably happening is that for some reason (a bad
combination of settings) POV is checking each ray against all objects
in the scene. As a quick test, try these command line options:
+mb0 +ul +uv +ur +su
If this does not work, read the docs :) especially the chapter about
automatic bounding control and removing user bounds.
HTH
Peter Popov ICQ : 15002700
Date: 20 May 2000 10:58:42
Message: <3926a822$1@news.povray.org>
I have this problem rendering thousands of blades of grass, I've never found
a solution that really works, though Peter's suggestion sometimes has a
small effect.
Mick
"Peter Popov" <pet### [at] usanet> wrote in message
news:i1lciskkd7l89lm1gfa3ocom0298vrtu35@4ax.com...
with
> light buffers on?
> HTH
> Personal e-mail : pet### [at] usanet
> TAG      e-mail : pet### [at] tagpovrayorg
Date: 20 May 2000 11:17:30
Message: <3926ac8a$1@news.povray.org>
Thank you, sirs. At least it's nice to know what's going on now - I was
baffled - haven't even thought about bounding since version 2.
Dave
"Mick Hazelgrove" <mha### [at] redhotantcom> wrote in message
news:3926a822$1@news.povray.org...
found
> small effect.
> Mick
> with
> > light buffers on?
> > HTH
Date: 20 May 2000 12:05:13
Message: <3926B770.3CD55E5E@club-internet.fr>
I have had this problem once.
Use 'merge' instead of 'union' and manually bound it with a bounded_by { sphere
or box } as closely as possible.
POV will consider your wall as a single block and not as thousand of bricks.
It worked when I had thousands of spheres to render. Hope it will for you too.
Fabien Hénon
> Regards,
> Dave
Date: 20 May 2000 13:21:43
Message: <3926c9a7@news.povray.org>
I'm not sure I follow you. Do you mean that you bounded the entire merge
object? I tried that (with the "-ur" switch), and didn't see a noticeable
change in render speed.
BTW, I posted a picture of the brick wall on p.b.i.
Dave
"Fabien Hénon" <ffj### [at] club-internetfr> wrote in message
news:3926B770.3CD55E5E@club-internet.fr...
 sphere
bricks.
too.
> Fabien Hénon
about
"BrickWall"
and
> > Regards,
> > Dave
Date: 21 May 2000 04:02:42
Message: <dn5fisgoep4af6t4kirl1398iuq92fj07r@4ax.com>
On Sat, 20 May 2000 18:04:00 +0200, Fabien Hénon
Merge is internally represented as a complex CSG. It takes more memory
and generally takes longer to render than the equivalent union. This
is not true in some special cases but this shouldn't be one of them.
Wrong (I think). It just represents it as a complex CSG to remove the
inner surfaces.
If the spheres were transparent and stacked, maybe. I doubt it will
help in the stones macro case.
Date: 21 May 2000 17:03:26
Message: <39284ED4.87CC92A0@club-internet.fr>
I tried on my side with a test scene with 1000 spheres..., but I have not seen
any changes either.
Sorry about that.
I guess the solution I suggested only works with a previous version of POV 3.0
or 2.2 ( I forgot, it was a long time ago).
Fabien Hénon
> Regards,
> Dave
>  sphere
> bricks.
> too.
> > Fabien Hénon
> about
> "BrickWall"
> and
> > > Regards,
> > > Dave
Date: 21 May 2000 18:35:18
Message: <5dogis0qqnuaig9coemjn6vu6kdm80ribn@4ax.com>
On Sat, 20 May 2000 00:12:07 -0700, "Dave Blandston"
Dave,
I didn't have much time to test your code but here's the little I have
found so far:
1. Antialiasing slows it down immensely
2. Manuallly bounding each NewBrick object in a unit box gives a
10-20% speedup
POV reports 2 frame level objects and these are the two walls. I
haven't ventured deep in your code (though, I must admit, it is among
the top five I've seen, style-wise) but I found that a wall is a CSG
intersection of a box and the union of the mortar and bricks. This
makes it one object in terms of bounding so even with the vista buffer
on POV has to test 30% of the images on the screen against all stones,
which are CGSs of superellipsoids and height fields. I am pretty sure
that if, instead of intersecting above box with the union of the
bricks, you make a union of the intersections of this box with every
single brick, it will speed up the render considerably, because every
brick will then be bounded individually and rays will only be tested
against it when necessary.
There might be other optimisations to make, like using clipped_by
instead of intersection etc. but if what I propose works as I hope it
would, you'll have more time to experiment with extra speedup tweaks.
Hope it works...
Date: 22 May 2000 00:56:02
Message: <3928bde2@news.povray.org>
Peter,
You are amazing. That's the solution! The walls now render in a "normal"
amount of time! I would never have figured that out by myself. Thanks so
much for helping me out. I just want to give you a big, wet kiss. If you
will send me your T-shirt size and address I want to make a cool Metallica
Creeping Death/Crypt T-shirt for you.
Thank you sir,
Dave
news:5dogis0qqnuaig9coemjn6vu6kdm80ribn@4ax.com...
> found so far:
> 10-20% speedup
> Hope it works...
Date: 22 May 2000 03:55:44
Message: <3928e800@news.povray.org>
Fabien Hénon <ffj### [at] club-internetfr> wrote:
: POV will consider your wall as a single block and not as thousand of bricks.
  The fact that it looks like a single block doesn't mean it is internally
represented as an internal block.
  Actually it's represented as a series of intersections of inverted objects
or something like that.
Date: 22 May 2000 07:03:28
Message: <392914DB.18D4D4D8@student.uni-siegen.de>
> light buffers on?
I have made the experience once in the exact same setup.
I realised that you have to "help" POV-Ray a little bit
with the bounding (I made the bricks in a nested loop
and then decided to manually bound every "line" of the
wall and then the whole wall). After that it was as
fast as w/o CSG.
Markus
Date: 22 May 2000 18:22:46
Message: <ricjis0hc0m5ugl7jdgd2549aa029dqgh4@4ax.com>
On Sun, 21 May 2000 21:52:05 -0700, "Dave Blandston"
>Peter,
>Thank you sir,
>Dave
<speechless>
*blush*
</speechless>
Date: 23 May 2000 01:07:08
Message: <392a11fc@news.povray.org>
Mike Williams' enhancement sped things up even more. Thanks to everyone who
helped out...
The sample scene in p.b.i. (DBStones.pov) sped up a LOT. It was taking my
computer almost 9 hours to render @ 1024x768 aa.3 before y'all's
suggestions, and back to under 30 minutes after the optomizations. The
actual scene that I made the macro for, however, saw a less significant
improvement, but it still renders in about 5-6 hours. Radiosity and/or media
in the scene is out of the question, though, as long as the stones are used.
Render time becomes astro-freakin'-nomical. No moonbeams shining in through
the crypt window. :(
Dave
Date: 23 May 2000 22:01:44
Message: <slrn8imemk.359.ron.parker@linux.parkerr.fwi.com>
Actually, it is internally represented as a merge.  Difference is the
operation you're thinking of.  Merge takes no more memory than the
equivalent union, and whether it takes more time depends on whether
it takes longer to do intersection checks or to compute texture
(including reflected and transmitted rays) which depends on what
type of objects you're working with.
In this case, a ray will never hit internal walls anyway, so there is
probably no difference in speed.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
These are my opinions.  I do NOT speak for the POV-Team.
Date: 23 May 2000 22:04:33
Message: <slrn8imert.359.ron.parker@linux.parkerr.fwi.com>
Nope.  It could be, but it's not, and changing it didn't help the speed
any so it remains the way it was, as a separate CSG type.
Date: 24 May 2000 03:56:35
Message: <392b8b33@news.povray.org>
Ron Parker <ron### [at] povrayorg> wrote:
: Nope.  It could be, but it's not
  How is it represented then?
  I remember this was a question in the 'hard-core povrayer test'. Someone
said it's represented as an intersection of inverted objects or something
similar, if I remember correctly.
Date: 24 May 2000 09:02:01
Message: <slrn8inlcu.3k4.ron.parker@linux.parkerr.fwi.com>
It's represented as a merge.  There are special cases in the code for
merges.  IIRC, it could be represented as the inverse of the intersections
of the inverses of the constituent objects, but it isn't.
Difference is represented as an intersection.  Perhaps that's what you're
thinking of.
Date: 24 May 2000 09:17:50
Message: <392bd67d@news.povray.org>
: It's represented as a merge.  There are special cases in the code for
: merges.  IIRC, it could be represented as the inverse of the intersections
: of the inverses of the constituent objects, but it isn't.
  What is the algorithm for the ray-intersection test for merges (briefly
and clearly exaplained, if possible :) )? I'm interested in knowing it.
Date: 24 May 2000 09:50:04
Message: <slrn8ino73.3kd.ron.parker@linux.parkerr.fwi.com>
1. Find all intersections.
2. Pop an intersection off the stack.  If none remains, no intersection
   with this object occurred.
3. Test to see if that intersection is inside any subobject other than the
   one it is on the surface of.  If so, throw it away and go to 2.
4. That's it.  Do whatever you do with the intersection you now have.  Don't
   forget to flush the stack, put the seat down, and turn off the light.
Date: 24 May 2000 11:05:52
Message: <392befcf@news.povray.org>
: 1. Find all intersections.
: 2. Pop an intersection off the stack.  If none remains, no intersection
:    with this object occurred.
: 3. Test to see if that intersection is inside any subobject other than the
:    one it is on the surface of.  If so, throw it away and go to 2.
  Yes, pretty simple.
  How do you know that the point is inside an object? You ask that
object "hey! is this point inside you?"?
Date: 24 May 2000 11:08:25
Message: <slrn8insq0.3lt.ron.parker@linux.parkerr.fwi.com>
Yes, exactly.  That's one of the reasons meshes (in the official POV)
can't be used in CSG: they don't have a proper implementation of that
method.
Date: 24 May 2000 17:54:09
Message: <8cjoisstppknvq3haptng1li5qvb46ilue@4ax.com>
On 23 May 2000 22:01:44 -0400, ron### [at] povrayorg (Ron Parker)
I know a difference is an intersection with the inverse. What I meant
was that merge { object { A } object { B } } is equivalent to
union
{ intersection { object { A } object { B inverse } }
  intersection { object { B } object { A inverse } }
Merging may have actually helped (the problem has been solved by
manual bounding etc.) if it helped POV bound the individual stones. I
can't say more without testing it.
Date: 24 May 2000 18:26:36
Message: <slrn8iomfp.47a.ron.parker@linux.parkerr.fwi.com>
>union
This is the symmetric difference, equivalent to
difference {
  union {object {A} object {B}}
  intersection {object {A} object {B}}
(except for the coincident surface problems the latter causes) and
logically similar to exclusive-or.
I think merge is actually equivalent to
intersection {
  inverse
but it's not represented that way internally.  The code actually has
special cases for merge, unlike for difference.
Date: 24 May 2000 18:39:22
Message: <camois8n5q8olrde0t17m70nh1dres8o2t@4ax.com>
On 24 May 2000 18:26:36 -0400, ron### [at] povrayorg (Ron Parker)
>intersection {
>  inverse
It certainly looks like it, yes. Thanks for the info.
Yes, I saw your reply to Warp after I posted :)
