Is there any general image map tutorial / general strategies on placing
image maps on complicated objects? I've found it quite difficult making a
transparent .gif, finding the transparent color so the base texture can be
seen, and then scaling and placing the image on the object to make this
"decal" effect look plausible.
Thanks,
-Chris-
Chris Spencer wrote:
> Hi,
Make an orthographic render perpendicular to the image map and use it as a
base to edit the map.
___ _______________________________________________
| \ |_ <dav### [at] faricy net> <ICQ 55354965>
|_/avid |ontaine http://www.faricy.net/~davidf/
"The only difference between me and a madman is that I'm not mad." -Dali
Thanks for the reply, but you lost me. I searched the POV help file but I
couldn't find a good description or implementation of an orthographic
camera. How would this help placing an image map?
-Chris-
> > Hi,
a
be
In article <38e9e4ed$1@news.povray.org>, "Chris Spencer"
> I couldn't find a good description or implementation of an
> orthographic camera.
Section 4.4.2 "Types of Projection", in the manual. Not a real great
explanation, though. Also look at section 2.4.4.1 "Understanding The
Concept of Splines". That part of the tutorial has a short "spline
workshop" scene that includes an example of the orthographic camera.
And check out this demo scene:
POV-Ray:Scenes:camera:camera1b.pov
It doesn't really help in placing one, just in designing one and placing
the details. Well, it might help get the alignment right...
The idea is you render an image with the orthographic camera, and then
use that image to place the details on the image map. The image map is
projected like the orthographic camera by default, so you just have to
scale/translate it to the same position and size as the camera was.
To make a decal, take a view along one axis with the orthographic
camera, "paint" on the rendered image, making the overlay, and then
apply that image as the decal using an image_map.
Christopher James Huff - Personal e-mail: chr### [at] yahoo com
TAG(Technical Assistance Group) e-mail: chr### [at] tag povray org
Chris, I never really understood this part: am I correct an assuming that the
width of the view at the look_at point is the same with an orthographic
camera? If not, how do you determine the width of the view?
Hi David.
I think that width and height of the view are determined by the length
of right and up vectors of the camera.
Bouf.
"David Fontaine" <dav### [at] faricy net> wrote in message
news:38EAB254.324C5E88@faricy.net...
I just happen to be answering before Chris since I'm online at this time of
morning, so excuse me if I'm interrupting please.
'up' and 'right' define the dimensions of the orthographic view window, centered
on 'look_at' of course.
The good thing about it is you can use what will be your image map resolution
for the values, as in up 300*y right 400*x.
Watch out when positioning the camera so as not to put it right near <0,0,0> as
someone had pointed out a while back here at the newsgroups. Seems that the
orthographic camera can break down at too small a range from the look_at. You
should be able to safely put the camera at any typical distance (for
simplicity -10*z and looking to <0,0,0>).
This makes for a kind of hollow bar which runs a length away from the camera yet
stays the same width and height for the entire distance.
Ok, I understand everything up until the the part when I have to
scale/translate the image to the position corresponding to the ortho
camera's position. Thanks for the help with the camera.
Here's my code, the maped texture is labeled ImagemapTex:
background { color <1.000,1.000,1.000> }
// lights
light_source { // Light1
<200.000, 200.000, 200.000>
color rgb <1.000, 1.000, 1.000>
light_source { // Light2
<-10.000, 8.000, 100.000>
// camera, side view
#declare Angle = 30;
camera { // Camera SpotCam001
// orthographic
location < 0, 50, 0>
sky < 0, 0, 1> // Use right handed-system
up < 0, 0, 1> //< 0, 0, 1*25> // For orthographic camera
right <4/3, 0.0, 0.0> //<4/3*25, 0.0, 0.0> // For orthographic
camera
angle Angle
look_at < 0, 0, 0>
// textures
#declare ImagemapTex =
texture{
color Blue
finish{
ambient 0
texture{
pigment{
image_map{
png "decal_rombot_nametag01.png" // the file to read
(iff/gif/tga/png/sys)
map_type 0 // 0=planar, 1=spherical, 2=cylindrical, 5=torus
interpolate 0 // 0=none, 1=linear, 2=bilinear, 4=normalized distance
// [filter N V] // N=all or color index # (0...N), V= value
(0.0...1.0)
// [transmit N V] // N=all or color index # (0...N), V= value
(0.0...1.0)
// [use_color | use_index]
once
// image_map
// rotate <0,50,0> translate <0,50,0> ??? <--- I think this is where
I need help.
// objects
plane
z, // <X Y Z> unit surface normal, vector points "away from surface"
-10.0 // distance from the origin in the direction of the surface normal
texture { pigment { checker color rgb <1.0, 1.0, 1.0> color rgb <0.0, 0.0,
0.0> } }
sphere
<0, 0, 0> // center of sphere <X Y Z>
10 // radius of sphere
scale <1, 1, .75>
texture {ImagemapTex}
Oh wow, confusing me :-)
Anyway, all you're really needing is to center the image first then scale it to
the size you have set in the camera. Since the image starts off as 1 unit
square with lower left corner at <0,0,0> then you want to do 'translate
<-0.5,-0.5,0>' and then 'scale <25,25,1>' and finally 'rotate 90*x' for the
camera to see it.
That should be it I think. That plane {z,-10 is not going to show up though.
The camera will be looking parallel along it and therefore see nothing of it.
If I'm understanding this right then you are trying to get a spherical image
which is actually mapped on as planar to be seen orthographically which then no
longer has any spherical quality. Which is why I got confused. Anyone else?
it to
the
> camera to see it.
though.
it.
That worked out fine. The checkered plane was there for a later 3D view,
when the ortho camera was commented out.
I tried mapping the image as a spherical type, but it became incredibly
distorted. Planar seemed the best option and didn't distort much.
Thanks again,
-Chris-
then no
else?
it to
the
> camera to see it.
though.
it.
then no
else?
> Bob
Everything seems fine except for one miniscule problem. A mirror image of
the image map projected on the opposite side of the object. How do I
counteract this?
Thanks,
-Chris-
On Fri, 7 Apr 2000 14:17:09 -0700, "Chris Spencer"
>counteract this?
The usual approaches are two.
1. Split the object in two, apply the image map to one half, glue them
back together
2. Use a proper textur_map to constrain the image map. With a planar
map type a planar pattern works best, and a radial pattern is usually
used with the other map types (I am not considering UV mapping, mind
you).
Hope this helps.
Peter Popov ICQ : 15002700
Personal e-mail : pet### [at] usa net
TAG e-mail : pet### [at] tag povray org
