POV-Ray : Newsgroups : povray.general : DXF file parsing in POV? Server Time
27 Oct 2026 01:47:20 EDT (-0400)
  DXF file parsing in POV? (Message 1 to 9 of 9)
Subject: DXF file parsing in POV?
Date: 21 Mar 2000 12:52:05
Message: <38d7b6c5$1@news.povray.org>
Hi. I'm wondering if this is possible.I've spent a some time trying with no
success. I'm trying to extract the position of POINT objects from the DXF.
The file will look like this (note: comments were added for clarity, they
are not in actual DXF file):
  0
SECTION
  2
ENTITIES
  0
POINT           // start of point object
  8
DEFAULT
  5
1E
 10
9.99498             // x coord
 20
9.993288             // y coord
 30
0.045681             // z coord
  0
POINT
  8
DEFAULT
  5
1F
 10
9.983854
 20
etc, etc.
TIA for any help or other feedback.
Dave.
mic### [at] sympaticoca
Subject: Re: DXF file parsing in POV?
Date: 21 Mar 2000 13:27:13
Message: <38D7BF68.A977525@pacbell.net>
POV-Ray has no internal support for .dxf files but many conversion programs
exist that will convert from dxf2pov. 3DWin and Crossroads for example -
http://www.povray.org/links/3D_Programs/Conversion_Utilities/
Date: 21 Mar 2000 14:39:11
Message: <38d7cfdf$1@news.povray.org>
Sorry, I wasn't clear enough in my original post. Using the file i/o
commands(fopen, read, etc) I want to read in the float values for a POINT
objects position and apply it to a POV objects translation.
Thanks, Dave.
Date: 21 Mar 2000 19:00:55
Message: <sAzYOMfLHCuOXhzliiH8kG4jyUQ9@4ax.com>
On Tue, 21 Mar 2000 17:54:54 GMT, spa### [at] junkmailcom (David Curtis)
<snip>
The file i/o function require that values are separated by commas
(whitespace doesn't count) and strings are enclosed in double quotes.
If you convert your DXF file to obey these rules, you'll be able to
read it into POV.
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 21 Mar 2000 19:22:09
Message: <38d81231$1@news.povray.org>
In article <sAzYOMfLHCuOXhzliiH8kG4jyUQ9@4ax.com>, Peter Popov <pet### [at] usanet>
>read it into POV.
Thanks for your help. If I have to write a converter I'll just extract the
coordinates at that point and write them to a suitable file.
Dave.
Date: 22 Mar 2000 04:08:02
Message: <38d88d72@news.povray.org>
If you are using a UNIX (this includes Linux), it's rather easy to add the
commas and the quotes with the proper sed-command.
Date: 22 Mar 2000 21:15:21
Message: <38d97e39@news.povray.org>
Just out of curiosity, what are you reading them in for?
David Curtis <spa### [at] junkmailcom> wrote in message
news:38d7b6c5$1@news.povray.org...
no
>   0
> SECTION
>   2
> ENTITIES
>   0
>   8
> DEFAULT
>   5
> 1E
>  10
> 9.99498             // x coord
>  20
> 9.993288             // y coord
>  30
> 0.045681             // z coord
>   0
> POINT
>   8
> DEFAULT
>   5
> 1F
>  10
> 9.983854
>  20
> etc, etc.
> Dave.
Date: 22 Mar 2000 21:46:30
Message: <38D9852A.7C1AC983@nigels.com>
	Kindof defeats the original aim of "DXF file parsing"
	if you have to massage the data....
Nigel Stewart (nig### [at] nigelscom)
Research Student, Software Developer
Y2K is the new millenium for the mathematically challenged.
Date: 23 Mar 2000 05:18:39
Message: <38d9ef7f@news.povray.org>
In article <38d97e39@news.povray.org>, "cadman" <NOS### [at] graffitinet> wrote:
I wanted to get a curve from Rhino into POV that I could put objects along.
I had ditched the idea of parsing in POV and wrote a C program to convert the
DXF to a comma delimited file with the coordinates.
Dave.
