POV-Ray : Newsgroups : povray.general : While we are talking about changes Server Time
27 Oct 2026 01:47:19 EDT (-0400)
  While we are talking about changes (Message 1 to 46 of 46)
Subject: While we are talking about changes
Date: 12 Mar 2000 07:56:22
Message: <38cb93f6@news.povray.org>
How hard could it be to have POV primitives come with default values? So
that if you simply wrote box{} you would get an unpigmented box of unit size
at the origin. Since most people use a unit, at origin object, then scale
and translate, it could save tons of typing.
    Of course they should be able to be over-rode...
    Most of the reason I use the insert menu is so that I don't have to type
in the default values myself. Not sure how that would work on cones
though...
Subject: Re: While we are talking about changes
Date: 12 Mar 2000 09:58:31
Message: <38CBAF9C.7C199D2B@attglobal.net>
Hum....  I do get your point and in some cases it could be a good idea,
but
box {
    scale < 2, 2, 2 >
    translate < 5, 5, 5 >
is actually more characters than
box {
    < 5, 5, 5 >
    < 7, 7, 7 >
Of course, what's the use of default values if they can't be
over-ridden?
> though...
Call me old school, but i prefer typing than getting my and hand over to
the mouse and select primitives from the menu.
Something I'd like to be able to do is automatically place objects
relative to others without having to do all the trig myself, but I guess
that could go in a modeler.  The POV-team probably has enough headaches
to resolve as it is.
Francois Labreque | The surest sign of the existence of extra-
     flabreq      | terrestrial intelligence is that they never
        @         | bothered to come down here and visit us!
  attglobal.net                                  - Calvin
Date: 12 Mar 2000 10:21:42
Message: <38cbb606$1@news.povray.org>
> but
> box {
>     scale < 2, 2, 2 >
> box {
>     < 5, 5, 5 >
>     < 7, 7, 7 >
    True, but how often do you do things like that? I almost -always- make
objects at origin then scale and translate. The few times I don't are
usually when I want to connect a cylinder or cone to certain points.
Date: 12 Mar 2000 15:10:51
Message: <38CBFF1A.8C37A179@merlin.net.au>
> > but
> > box {
> >     scale < 2, 2, 2 >
> > box {
> >     < 5, 5, 5 >
> >     < 7, 7, 7 >
I nearly always create objects at their final size, apart from non equal
scaling.
But then I'd do sphere{0,5 scale<1,2,1>} rather than sphere{0,1
scale<5,10,5>}
PoD.
Date: 12 Mar 2000 15:11:48
Message: <slrn8cnv23.3rs.ron.parker@linux.parkerr.fwi.com>
Who is this "most people" you talk about?  Most modelers do that, but
I would think most people make the box where they want it.  I know I
do.
Date: 12 Mar 2000 15:16:33
Message: <38CBFB91.1EA01060@istar.ca>
> do.
One of the major reasons that I use Moray, instead of hand coding, is
that I can't get my brane to work in the mode that will understand the
box code.
No matter how much I work on it, it's always a struggle. Having a default
I can scale is easier to understand. I can easily visualize a box scaled
to <1, 2, 5>, but a box defined by corners <-0.5, -1, -2.5>  <0.5, 1,
2.5> is not something I can see in my mind.
Date: 12 Mar 2000 15:51:47
Message: <38CC0243.2F0296E5@pacbell.net>
Both methods require repetitious use before you become comfortable with
them. When I was first learning Pov I bounced back and forth between
various modellers I was evaluating and hand coding. Personally I found
more power in the hand coding environment but had I found a modeller
I was comfortable with I might have swung the other way. Regardless
I still think that with practice you would learn to use the various
control points of a box with the same ease that you do the scale feature
in your modeller of choice.
Besides defining a unit box is no more difficult than
box{-.5,.5}
Defining a unit sphere
sphere{0,1}
Defining unit cylinders you have a choice of which axis to align it to
cylinder {x*-.5, x*.5, 1}
cylinder {y*-.5, y*.5, 1}
cylinder {z*-.5, z*.5, 1}
etc.
Date: 12 Mar 2000 17:19:00
Message: <38CC1A53.5AAB654B@erols.com>
> do.
The place where this "feature" of all modellers I've seen gets me is
with the cylinder.  Whenever I use a cylinder, it's along the lines of
  cylinder { <3,2,4>,<1,1,3>,.5 }
which with most modellers has to be done by calculating the scaling and
rotation outside of the program, and then entering them by hand.  This
is why I don't use them.
John
ICQ: 46085459
Date: 12 Mar 2000 18:17:51
Message: <38CC24C4.EED45E45@faricy.net>
Francois Labreque wrote:
> box {
>     scale < 2, 2, 2 >
> box {
>     < 5, 5, 5 >
>     < 7, 7, 7 >
or you could do box { 5 7 } :-)
___     _______________________________________________
 | \     |_          <dav### [at] faricynet> <ICQ 55354965>
 |_/avid |ontaine        http://www.faricy.net/~davidf/
"The only difference between me and a madman is that I'm not mad." -Dali
Date: 12 Mar 2000 20:20:07
Message: <38cc4247@news.povray.org>
> do.
    Perhaps I am mistaken. I supposed that since the docs recommend it, new
users are often told to do it, and it make sense to do so in terms of
declarations, that most people would do so.
    Personally, BTW, I don't care about character count. My insert menu box
looks like:
/////////////// box ////////////////////////
box {
     < -0.5, -0.5, -0.5 >,
     <  0.5,  0.5,  0.5 >
     scale      < 1.0, 1.0, 1.0 >
     rotate     < 0.0, 0.0, 0.0 >
     translate  < 0.0, 0.0, 0.0 >
     texture { DefaultTexture }
        } // end box
    ... I do it like this so that I have to type less. I mouse delete
anything I don't need and modify the rest to my requirements.
       If I am putting it in a loop or something I will chop it down, but
otherwise...
Date: 12 Mar 2000 21:02:00
Message: <38CC4C86.FEEF8B6C@peak.edu.ee>
> do.
Only if you want it aligned to the major axes.
I usually consider it a good idea to create objects at the origin and then apply
the necessary transformations. I feel it gives more control over the final
placement of the object, and the look of the texture.
Margus
Date: 12 Mar 2000 22:44:40
Message: <slrn8copjd.40d.ron.parker@linux.parkerr.fwi.com>
>> do.
That's true; I do create boxes that won't be axis-aligned at the origin, but
I still create them the correct size.
Date: 13 Mar 2000 12:56:13
Message: <38CD2BF2.67B80C5A@gci.net>
Does anyone remember the shapes.inc file?
Make changes there and use predefined shapes from there.
> box{-.5,.5}
> sphere{0,1}
> etc.
> Ken Tyler -  1300+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Mr. Art
"Often the appearance of reality is more important
than the reality of the appearance."
Bill DeWitt 2000
Date: 13 Mar 2000 13:24:38
Message: <38CD32E2.D57FA27F@pacbell.net>
Actually for something like using a unit sized box I find it easier
to type
box{-.5,.5}
rather than
#include "shapes.inc"
object {cube}
Date: 13 Mar 2000 19:03:49
Message: <38cd81e5@news.povray.org>
Francois Labreque <fla### [at] attglobalnet> wrote in message
news:38CBAF9C.7C199D2B@attglobal.net...
Now there's something I could have used at times - translate_relative as opposed to
the
existing translate_absolute.
Alf
http://www.peake42.freeserve.co.uk/
http://ourworld.compuserve.com/homepages/Alf_Peake/
Date: 13 Mar 2000 20:06:56
Message: <38CD8FD4.C05F19C3@attglobal.net>
> > box {
> >     scale < 2, 2, 2 >
> > box {
> >     < 5, 5, 5 >
> >     < 7, 7, 7 >
OK.  The choice of numbers wasn't probably the best to illustrate my
point, but I think it came across nevertheless.   Anyway, most of my
boxes look more like this:
box {
    < 2.875, 5.5, 3.6333333 >
    < 7.142857, 9.3, 4 >
Which is wayyyyyyyyy easier than
box {
    scale < 4.267857, 3.8, 0.2666666 >
    translate < 7.642857, 9.8, 4.5 >
Francois Labreque | It is by caffeine alone I set my mind in motion, it
     flabreq      | is by the beans of Java that thoughts acquire speed,
        @         | the hands acquire shaking, the shaking becomes a
  attglobal.net     warning, it is by caffeine alone I set my mind in
motion.
                               - Unknown
Date: 13 Mar 2000 23:55:10
Message: <38cdc62e@news.povray.org>
> box {
    Modeler syndrome.
Date: 14 Mar 2000 05:22:03
Message: <38ce12cb@news.povray.org>
Ron Parker <ron### [at] povrayorg> wrote in message
news:slr### [at] linuxparkerrfwicom...
> do.
I'm suprised - I'm trying to write a short newbie tutorial on object
transformations, and one of my general rules is always create objects with a
known point at <0,0,0>. Don't you lose track of where you objects are going
to end up if you scale them? (or at least find it harder).
Date: 14 Mar 2000 07:56:49
Message: <38CE3751.867149E3@inapg.inra.fr>
I completely agree. When I was a newbie, my permanent problem was that
I defined objects "directly" and always lost them after a few translates and
rotates.
I often had to "pile" transform statements to obtain a desired effect, and lost
a
lot of time looking for disappearing primitives (no VFAQ then !).
This problem was solved when I started creating them at <0,0,0>
and applied the transforms afterwards. I find it easier to apply textures too.
This can't be a general rule, though. Chain-like objects can be often created
more
easily using absolute coordinates (when using loops at least) since the end
points
of a primitive can be used as the starting points of the next.
G.
Date: 14 Mar 2000 08:26:51
Message: <38ce3e1b@news.povray.org>
If you create it where you want it, you don't need to scale it.  I don't see
the problem here.
Okay, to be honest, I still follow the rule of creating things at the origin.
But if I'm going to make a simple stool, I do this:
 union {
   box {<-6, 36, -6>,<6,37,6>}
   intersection {
     box {<-8,0,-8>,<8,36.5,8>}
     cylinder { <-5,0,-5>, <-4,36.5,-4>, .5 }
     cylinder { < 5,0,-5>, < 4,36.5,-4>, .5 }
     cylinder { <-5,0, 5>, <-4,36.5, 4>, .5 }
     cylinder { < 5,0, 5>, < 4,36.5, 4>, .5 }
That is, I create the parts of the stool where they should be, relative to the
fixed point on the stool that I have chosen to have at the origin (in this case,
a point on the floor directly under the center.)  To me, this looks a lot
cleaner than trying to create and translate and rotate and scale all those
components to get the desired result.  I will still translate and rotate the
stool to put it where I want it (but I won't scale it, because it's already to
scale.)
The exception, of course, is when I need an ellipsoid or a torus.  Those have to
be created at the origin.  (In fact, I wish there were an alternate syntax for
toruses that took a center and an axis so I could work with them without having
to wave my left hand around to figure out the rotations.)
These are my opinions.  I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
Date: 14 Mar 2000 09:03:36
Message: <38ce46b8@news.povray.org>
having
    I have almost convinced my family and friends that waving your hands in
the air, staring into space and  even pounding one hand against your temple
while apparently grasping at and manipulating something invisible with your
eyes tightly shut is the way we communicate with the POVray Program Goddess.
Date: 14 Mar 2000 13:48:07
Message: <LojOOAF6Bt=BBCR99yXbnfP3kaeF@4ax.com>
On 12 Mar 2000 15:11:48 -0500, ron### [at] povrayorg (Ron Parker)
>do.
I usually do as well, but it might be handy for include files that are
trying to be as universal as possible. Having all you include-file
objects oriented in a similar manner can be handy in the main scene
file.
Later,
Glen Berry
Date: 14 Mar 2000 17:25:17
Message: <Pine.LNX.4.10.10003141415170.23069-100000@belial.reno.nv.us>
> >do.
> file.
so my method of making ALL my objects at 0,0,0 and then translating them
where I want them is umm....non-standard?:) (I swear I make everything at
0,0,0 then translate and rotate to where it looks right) I find it easier
but then hehehe :)
> Later,
> Glen Berry
Date: 14 Mar 2000 17:35:14
Message: <38CEBF21.4A94A0A0@pacbell.net>
> but then hehehe :)
Not at all. Your method has considerable merit and is quite popular.
There are a lot of good reasons for specifying objects at the origin
and then manipulating them from there.
Date: 14 Mar 2000 19:01:35
Message: <Pine.LNX.4.10.10003141548460.23081-100000@belial.reno.nv.us>
> > but then hehehe :)
Good!:) btw since we're kinda on the subject, how can I shorten the
box {<-0.5,-0.5,-0.5>,<0.5,0.5,0.5> }
see I always make my boxes that big then scale the suckers to whatever I'm
doing, the thing is typing all those 0.5's can be tiring (I get around
that with cut and paste, but still if there is some shortform...I'd love
to know it :)
Date: 14 Mar 2000 19:22:20
Message: <chrishuff_99-1EC352.19241414032000@news.povray.org>
In article
<Pin### [at] belialrenonvus>,
> whatever I'm doing, the thing is typing all those 0.5's can be tiring
> (I get around that with cut and paste, but still if there is some
> shortform...I'd love to know it :)
You could use this:
#declare Box = box {<-0.5,-0.5,-0.5>,<0.5,0.5,0.5> }
And then make your boxes with
object {Box
Or you can leave the 0's out:
box {<-.5,-.5,-.5>,<.5,.5,.5> }
And to shorten it further, you can use the feature of POV that promotes
floats to vectors when necessary:
box {-0.5, 0.5}
or
box {-.5,.5}
This isn't as easy to immediately understand, though, and is just as
long as using a Box variable.
If you really want to eliminate keypresses, try this:
#macro Box()
You would use the macro this way:
Box()
...object stuff, textures, etc go here...
You could use a shorter name for the macro, but you can't eliminate the
parentheses.
Chris Huff
e-mail: chr### [at] yahoocom
Date: 14 Mar 2000 19:22:43
Message: <38CED846.32BBF0E5@pacbell.net>
Some typical shorthand primitives:
box{-.5,.5) // a unit box at the origin
sphere {<0,0,0>,1 }
sphere{0,1) // a unit sphere at the origin
cylinder {<-.5, 0, 0>, <.5, 0, 0>, 1 }
cylinder{x*-.5,x*.5,1} // 1 unit long in the x direction with a dia of 1
cone {<0, -.5, 0>, 1, <0, .5, 0>, 0 }
cone{y*-.5,1,y*.5,0} // 1 unit high with a base of 1 and a point of zero
                     // centered at the origin
Date: 14 Mar 2000 20:31:02
Message: <Pine.LNX.4.10.10003141653180.23088-100000@belial.reno.nv.us>
On Tue, 14 Mar 2000, Chris Huff wrote:
> In article
> You could use this:
> object {Box
Doh! I should have thought of that! :)
> box {-0.5, 0.5}
> or
> box {-.5,.5}
Yeah...ok
> #macro Box()
> #end
> Box()
> parentheses.
Kewl.....sorta like #define eh? but without the object{} thing... Can I do
that for CSG stuff too? I use CSG a LOT (pages of the stuff) this could
save some typing :)
> Chris Huff
> Web page: http://chrishuff.dhs.org/
Date: 14 Mar 2000 20:34:32
Message: <Pine.LNX.4.10.10003141723060.23088-100000@belial.reno.nv.us>
> sphere {<0,0,0>,1 }
so y* = 1 ? (or x* = 1?) or is it y (multiplied by) ?
Date: 14 Mar 2000 20:59:57
Message: <d+3OOOYLzvogwIMemnUDluXyUVic@4ax.com>
>> Box()
<SNIP>
>save some typing :)
You might save some typing, but keep in mind that it will take longer
to parse. This might not be a problem, unless you have several
elements in your scene described using macros.
Later,
Glen Berry
Date: 14 Mar 2000 21:04:46
Message: <38CEF035.DA6CE8F6@pacbell.net>
sphere{< 1,0, 0>, 1} = sphere{x, 1}
sphere{<-1,0, 0>, 1} = sphere{-x, 1}
sphere{< 1,1, 0>, 1} = sphere{x+y, 1}
sphere{<-1,1,-1>, 1} = sphere{-x+y+-z, 1}
Date: 14 Mar 2000 21:31:10
Message: <2bttcs8adcdpkhiu5ev192sth898isjab4@4ax.com>
On Tue, 14 Mar 2000 09:03:27 -0500 "Bill DeWitt"
  You are correct, Bill, but one can also go blind using that method
<g>.
Alan - ako### [at] povrayorg - a k o n g <at> p o v r a y <dot> o r g
Date: 15 Mar 2000 08:09:31
Message: <38cf8b8b$1@news.povray.org>
That's not a unit sphere.  It's a sphere of unit radius.
Date: 15 Mar 2000 16:28:42
Message: <38D007E5.B3C1CEB1@merlin.net.au>
In POV speak
 y = <0,1,0>
so
 y*0.5 = <0,1,0>*0.5 = <0,0.5,0>
also .5 = 0.5
PoD.
Date: 15 Mar 2000 19:27:55
Message: <Pine.LNX.4.10.10003151620180.23797-100000@belial.reno.nv.us>
Ahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh ok :)
Date: 15 Mar 2000 19:30:33
Message: <Pine.LNX.4.10.10003151622230.23797-100000@belial.reno.nv.us>
> In POV speak
>  y = <0,1,0>
> so
> also .5 = 0.5
gotcha! Once I use this a few times, it'll stick :) (grabs some crazy
glue...)
> PoD.
Date: 16 Mar 2000 02:26:07
Message: <38D08CBF.FC42361A@ij.net>
> but then hehehe :)
	Should you get into animation, that is the only way to do it.
Just make variables rather than absolutes for everything that
moves.
<A href="http://www.giwersworld.org">A free internet for a free
people.</a>
Date: 16 Mar 2000 13:23:39
Message: <38D12716.8E565F19@ma.usb.ve>
Well, the sphere with unit radius is commonly referred to as the unit
sphere.
alberto
Date: 16 Mar 2000 15:27:57
Message: <38d143cd@news.povray.org>
> sphere.
    That's why I make all my spheres with a 0.5 radius, so they will be more
reasonably called 'unit' spheres. So that like a unit box, if I copy one
exactly one unit away, they will just touch.
Date: 16 Mar 2000 17:22:45
Message: <38D15DC6.F25A6395@faricy.net>
> > box {
>     Modeler syndrome.
Why, do you use box { <2+7/8,5+1/2...?
Date: 16 Mar 2000 17:25:52
Message: <38D15E7D.F05B85D9@faricy.net>
> box {
> box {
I suppose it depends what you're using it for. If you want a box of a
certain size at a certain location, use the latter. If the endpoints of the
box are of significance, use the former. Like when I do LEGO stuff, the
endpoints are the extent of the piece, so I use the first one...
Date: 16 Mar 2000 18:30:33
Message: <38d16e99@news.povray.org>
"David Fontaine" <dav### [at] faricynet> wrote :
> >     Modeler syndrome.
You stopped before it got hairy. Mouse placement of objects gives you odd
decimal values like the 3.6333333 or 7.142857. Often you see modeler files
that have values like 12.0023 in scenes that clearly do not have that kind
of a problem with tolerances.
    In this example, with any camera more than a unit or two away from the
object, 3.63 would have done, and probably 3.6 would be as good.
    You see the same thing in textures done with sliders, rgb < 0.992342,
0.0, 0.0 > = red, AFAICT.
Date: 16 Mar 2000 18:34:14
Message: <38D16F56.230DD80D@pacbell.net>
That is one of the reasons I hate using a mouse in a 3D graphics
environment. Their precision sucks big time.
Date: 16 Mar 2000 19:39:08
Message: <Pine.LNX.4.10.10003161800230.31231-100000@belial.reno.nv.us>
Yeah........hand scripting is so precise...there is something elegant
about it :)
I mean a box thats 1,1,1 units in size is elegant....but 1.00345, 1.00673,
1.00892 ? looks messy (well at least I think so)
Date: 16 Mar 2000 19:41:42
Message: <Pine.LNX.4.10.10003161804560.31234-100000@belial.reno.nv.us>
> > but then hehehe :)
> moves.
Thats good to know....:)
> people.</a>
Date: 16 Mar 2000 22:16:33
Message: <38D1A38B.A800E1BA@attglobal.net>
> > >     Modeler syndrome.
What is so odd about 3.63333333 ( 4 - 11/30 ) or 7.142857 ( 7 + 1/7 )?
I might be a bit picky about precision, but not everything in this
universe is neatly placed along unit coordinate lines!
That's why I haven't used modelers in a looong time.
Agreed.
Only to the untrained eye :)
  attglobal.net   | warning, it is by caffeine alone I set my mind in
motion.
                               - Stolen from Badger's .sig file
