I've been trying to create a macro that would seamlessly connect two
toruses, just like John VanSickle's Connect macro does for spheres. I can't
seem to get it right, however, so I'd be very grateful if someone with more
math skills than me could help me.
Here's something to work with:
#macro TorusConnect(SP,SMaR,SMiR,EP,EMaR,EMiR)
#local D=vlength(EP-SP);
#local Rd=(SMaR+SMiR)-(EMaR+EMiR);
#local D2=sqrt(D*D-Rd*Rd);
cone { SP+(EP-SP)/D*(SMiR-EMiR)*(SMaR+SMiR)/D, (SMaR+SMiR)*D2/D,
EP+(EP-SP)/D*(SMiR-EMiR)*(SMaR+SMiR)/D, (EMaR+EMiR)*D2/D }
This, obviously, doesn't work but it does come quite close; it just leaves a
tiny edge at the connection point.
¤ Sebastian Strand
¤ E-mail: the### [at] bigfoot com
¤ URL: http://www.zeb.f2s.com/
¤ ICQ: 771208
Hi Sebastian
I like problems like the one you presented here, so I have tried
to do some thinking.
I have not seen John VanSickle's Connect macro, but I think that
I understand your problem anyway. I have tried to figure it out by
examining your variable names:
(I did however not understand your description of what the problem
with your macro was.)
Correct me if I'm wrong:
You have two toruses that are parallel to each other.
The centres of these are at two given locations (some distance apart).
And you want to connect the "outsides" of these with a cone.
So if I this is your problem, then I have a suggestion for a solution.
Se my POV-ray file below.
(I have tried to make it easy to understand, and because of this it
became quite long. Abut about half of it can be removed if you don't
need my comments, debug macros and objects)
I have tried to solve the problem with vector math.
My solution is not perfect, because if the centres of both your toruses
lies on a line through origo, then my solution will not work.
(If I have time I'll might try to remove this weakness.)
(And because I didn't understand what the problem with your macro
was, I don't know if my macro is any better than yours.)
Tor Olav Kristensen
mailto:tor### [at] hotmail com
> #end
> ¤ Sebastian Strand
> ¤ ICQ: 771208
// Connecting two torus-"outsides" with a cone
// Copyright 2000 by Tor Olav Kristensen
#version 3.1;
// Some useful constants
#declare Origo = <0, 0, 0>;
#declare Nullv = <0, 0, 0>;
#declare Unitv = <1, 1, 1>;
// Just some of my macros
/* // Remove this line for debugging
#macro vCos(UU, VV)
// Returns cosinus of the angle between two vectors
(vdot(UU, VV)/(vlength(UU)*vlength(VV)))
#end // macro vCos
#macro vangle(UU, VV)
// Returns the angle in radians between two vectors
// 0 <= returned angle < pi
acos(vCos(UU, VV))
#end // macro vangle
#macro VectorAngles(Vector)
// Returns two angles.
// The first is the angle between Vector and the Y-axis
// The second is the angle between the projection
// of Vector to the XZ-plane and the X-axis
#local VAngles = Nullv;
#if (vlength(Vector) > 0)
#local VAngles = y*vangle(Vector, y);
#if (VAngles.y > 0)
#local Sign = 1;
#if (Vector.z < 0)
#local Sign = -1;
#local VAngles = VAngles + Sign*x*vangle(Vector*(x+z), x);
#end // if
VAngles
#end // macro VectorAngles
#macro vtilt(Thing, TVector)
// Returns the object Thing "tilted" in the
// direction of TiltVector
#local RotateAngles = VectorAngles(TVector);
object {
Thing
rotate degrees(RotateAngles.x)*y
rotate -degrees(RotateAngles.y)*z
rotate -degrees(RotateAngles.x)*y
#end // macro vtilt
*/ // Remove this line for debugging
#macro vproject(UU, VV)
// Projection of the vector UU in the direction
// of the vector VV.
((VV)*vdot(UU, VV)/vdot(VV, VV))
#end // macro vproject
#macro TorusConnect(SP, SMaR, SMiR, EP, EMaR, EMiR)
// SP: S Point (Center of one torus)
// SMaR: S Major Radius
// SMiR: S Minor Radius
// EP: E Point (Center of other torus)
// EMaR: E Major Radius
// EMiR: E Minor Radius
// And suffixes; v: Vector, p: Point, R: Radius
// Note: Origo, SP and EP may not be colinear
#local Upv = vcross(EP, SP);
#local Dv = EP - SP;
#local Outv = vnormalize(vcross(Dv, Upv));
#local SMaRv = SMaR*Outv;
#local EMaRv = EMaR*Outv;
#local SMaRp = SP + SMaRv;
#local EMaRp = EP + EMaRv;
#local Slopev = EMaRp - SMaRp;
#local SlopeNv = vnormalize(vcross(Slopev, Upv));
#local SMiRv = SMiR*SlopeNv;
#local EMiRv = EMiR*SlopeNv;
#local SMiRp = SMaRp + SMiRv;
#local EMiRp = EMaRp + EMiRv;
#local EndSp = SP + vproject(SMiRv, Dv);
#local EndEp = EP + vproject(EMiRv, Dv);
#local EndSR = vlength(SMiRp - EndSp);
#local EndER = vlength(EMiRp - EndEp);
#local sr = 0.3;
#local Storus = torus { SMaR, SMiR }
#local Etorus = torus { EMaR, EMiR }
#local Storus = object { vtilt(Storus, Dv) translate SP }
#local Etorus = object { vtilt(Etorus, Dv) translate EP }
union {
sphere { SP , sr }
sphere { SMaRp, sr }
sphere { SMiRp, sr }
sphere { EndSp, sr }
object { Storus }
sphere { EP , sr }
sphere { EMaRp, sr }
sphere { EMiRp, sr }
sphere { EndEp, sr }
object { Etorus }
cone { EndSp, EndSR, EndEp, EndER }
#declare CenterPoint1 = <1, 4, 2>;
#declare MajorRadius1 = 5;
#declare MinorRadius1 = 0.5;
#declare CenterPoint2 = <2, 0, 3>;
#declare MajorRadius2 = 2;
#declare MinorRadius2 = 1;
object {
TorusConnect(CenterPoint1, MajorRadius1, MinorRadius1,
CenterPoint2, MajorRadius2, MinorRadius2)
pigment { color Yellow }
#declare PlaneNormal = vnormalize(vcross(CenterPoint1, CenterPoint2));
plane { PlaneNormal, 0 pigment { color White } }
background { color Grey }
light_source { 1000*PlaneNormal, White }
location 15*PlaneNormal
look_at Origo
#macro TorusConnect(p1,mj1,mn1,p2,mj2,mn2)
#local Dist = sqrt(pow(p1.x-p2.x,2)+pow(p1.y-p2.y,2)+pow(p1.z-p2.z,2));
#local Ang1 = atan2((mn1+mj1-mn2-mj2)/Dist,1);
#local Ang2 = asin((mn1-mn2)/sqrt(pow(Dist,2)+pow(mn1+mj1-mn2-mj2,2)));
cone { p1+vnormalize(p2-p1)*mn1*sin(Ang1+Ang2),mj1+mn1*cos(Ang1+Ang2)
p2+vnormalize(p2-p1)*mn2*sin(Ang1+Ang2),mj2+mn2*cos(Ang1+Ang2)
If you want the math behind it I can give it to you :-)
And if you want a second cone differenced out of it to smoothly connect the
interior as well, most of the work is already done.
___ _______________________________________________
| \ |_ <dav### [at] faricy net> <ICQ 55354965>
|_/avid |ontaine http://www.faricy.net/~davidf/
"The only difference between me and a madman is that I'm not mad." -Dali
> can't seem to get it right, however, so I'd be very grateful if
> someone with more math skills than me could help me.
Question: Do the torii share the same axis?
If the answer to is yes, the macro goes like this:
#macro TorusConnect(StartPoint,StartMajorRadius,StartMinorRadius,
EndPoint,EndMajorRadius,EndMinorRadius)
#local pS=StartPoint;
#local pE=EndPoint;
#local rSJ=StartMajorRadius;
#local rSN=StartMinorRadius;
#local rEJ=EndMajorRadius;
#local rEN=EndMinorRadius;
#local sL1=vlength(pE-pS);
#local vA=vnormalize(pE-pS);
#local sL2=vlength(<sL1,rEJ-rSJ,0>);
#local sL3=sqrt(sL2*sL2-(rEN-rSN)*(rEN-rSN));
#local sC1=sL1/sL2;
#local sS1=(rSJ-rEJ)/sL2;
#local sC2=sL3/sL2;
#local sS2=(rSN-rEN)/sL2;
#local xS=rSJ+(sC1*sC2-sS1*sS2)*rSN;
#local yS=(sC1*sS2+sC2*sS1)*rSN;
#local xE=rEJ+(sC1*sC2-sS1*sS2)*rEN;
#local yE=sL1+(sC1*sS2+sC2*sS1)*rEN;
cone { pS+vA*yS,xS,pS+vA*yE,xE }
I've tested it and it appears to work. Note that it makes a solid
connector, with no hole in the middle to connect the holes in the torii.
There's no error-checking, so don't give it any strange parameters.
I'll probably toss this into the Thoroughly Useful Macros file,
probably once I get the connecting hole added.
Hope this helps,
John
ICQ: 46085459
Tor Olav Kristensen wrote:
> Hi Sebastian
But I thought wrong!
The macro did only work when the two radiuses were equal.
Here is another try. Se macro below.
Tor Olav
#local SlopeNv = vcross(Slopev, Upv);
#local dp = vlength(Slopev);
#local dMiR = SMiR - EMiR;
#if (dMiR = 0)
#local c = SMiR;
#local Bv = Nullv;
#else
#local b = dMiR*dMiR/dp; // Because dp/SMiR = SMiR/b
#local Bv = ((dMiR > 0) ? 1 : -1)*b*vnormalize(Slopev);
#local c = sqrt(dMiR*dMiR - b*b); // Because dMir*dMir = b*b + c*c
#local Cv = c*vnormalize(SlopeNv);
#local SMiRv = SMiR*vnormalize(Bv + Cv);
#local EMiRv = EMiR*vnormalize(Bv + Cv);
#local sr = 0.3;
union {
sphere { SP , sr }
object { Storus }
sphere { EP , sr }
object { Etorus }
Poor little me, trying to carve out a name for myself in the wonderous field
of macros, and everyone has to go and use VanSickle's...
Well I see yours is nice and lengthy compared to mine ;-)
field
Well, thanks to all three of you that presented a solution. I will now
proceed to try and decide which one to use, probably by testing which macro
parses quickest :)
¤ Sebastian Strand
the
I tried your macro, but it seems that the radius of the cone is slightly
smaller than it should be. There is a tiny visible edge at the connection
point when using highlights, and that same edge does not occur with
VanSickle's version.
¤ Sebastian Strand
¤ E-mail: thezeb -at- bigfoot -dot- com
Hi
> parses quickest :)
Try this:
#local a=EP-SP;
#local b=SMaR-EMaR;
#local c=SMiR-EMiR;
#local d=vdot(a,a);
#local e=d+b*b;
#local f=sqrt(d);
#local g=sqrt(e-c*c);
#local h=(f*g-c*b)/e;
#local i=(f*c+g*b)/e;
#local j=a/f;
cone { SMiR*i*j+SP,SMiR*h+SMaR,(EMiR*i+f)*j+SP,EMiR*h+EMaR }
#end // macro TorusConnect
Tor Olav
> field of macros, and everyone has to go and use VanSickle's...
I avoided using the trig functions. I also made local copies of the
arguments, so that if the user passes an expression as one of the arguments,
that expression will be evaluated. For instance, this macro
#macro MyMacro(A,B) (A-B) #end
can be invoked this way:
#local J=MyMacro(77*2,45*2-23*3);
which POV-Ray will evalaute as:
#local J=77*2-45*2-23*3;
which is almost certainly *not* what the user wanted.
John
Hi John
Will this also make it parse faster?
What if one uses () around the passed arguments when one uses them
in i.e. multiplications and divisions?
And if so, would it be sufficient to do this in the cone statement in the last
torus-connect macro i posted?
Like this:
cone { (SMiR)*i*j+SP,(SMiR)*h+SMaR,((EMiR)*i+f)*j+SP,(EMiR)*h+EMaR }
() around SMiR and EMiR ...
By the way: Did you recognize any of the math in that macro?
Regards
Tor Olav
That depends on how much faster a label look-up is compared to the evaluation
of an expression. Most of the time a single variable or a constant is being
passed.
Same effect.
> Like this:
Yes, the parentheses force evaluation of the argument so that expressions
can be passed without causing an error. This is important if you are going
to had it out for other people to use.
It appears to be the same calculations as what I posted, although I may
have taken an unnecessary root here or there. I used long labels as the
arguments in the sample code so that people could tell which argument to
the macro was supposed to be the start point, the end point, etc., without
having to puzzle out the acronyms. In a real .INC file I use shorter
labels that follow the naming coventions I use in all of my scene code.
John
ICQ: 46085459
In article <38C9B210.6698DB45@erols.com>, John VanSickle
<van### [at] erols com> wrote:
> ... I also made local copies of the arguments, so that if the user
> passes an expression as one of the arguments, that expression will be
POV always evaluates the parameters, which is one of it's differences
with C macros.
See this section in the manual: 4.2.8.3 Are POV-Ray Macros a Function
or a Macro?
Chris Huff
e-mail: chr### [at] yahoo com
> with C macros.
> or a Macro?
Hmm, the docs back you up on this. I guess that I do it this way because
it fixed a bug I had somewhere...
ICQ: 46085459
Bzz, wrong!
Run this code:
#macro Test(a,b) a-b #end
#render concat(str(Test(2*5,2*4-2*3),1,0),"\n")
sphere{0,1} //So POV doesn't whine
