POV-Ray : Newsgroups : povray.general : Different error messages for same POV-file Server Time
27 Oct 2026 01:43:20 EDT (-0400)
  Different error messages for same POV-file (Message 1 to 24 of 24)
Subject: Different error messages for same POV-file
Date: 13 Mar 2000 07:44:48
Message: <38CCE1C6.4947A712@hotmail.com>
Hello
I'm trying to make some macros to enable me to
experiment with different rotation matrix's. (That I
later will apply to 3D vectors to get the desired
rotation of the vector.)
I know about the built in rotate functions in POV-Ray.
I just want to learn about rotation matrix's.
Each matrix is built up as an array of 3 3D-vectors
each. And my macros again operate on these arrays.
My problem is that I get several different error
messages when I try to Run the file below in this
message (I did not alter it between the Runs).
Can anyone please tell me if I am doing anything wrong
in my macros? (variable passing, variable declarations,
variable name conflicts etc.)
I am using POV-Ray v3.1g.watcom.win32 (Pentium II
optimized) and I am using a 100 MHz Pentium PC with
32 MB RAM, running Windows 98.
Regards
Tor Olav
mailto:tor### [at] hotmailcom
Here is some of the error messages:
  Warning Stream to console.......On
  #local PP = array[3]
  #local QQ = array[3]
  #local PP = Mtrans(NN)
  #local NN <----ERROR
C:\My documents\POVray-bilder\Matrix03_.inc:39: error: undeclared
identifier expected but float function 'clock_delta' found instead.
identifier expected but float function 'tan' found instead.
identifier expected but float function 'on' found instead.
identifier expected but float function 'abs' found instead.
identifier expected but float function  found instead.
  #local PP = Mtrans(NN <----ERROR
C:\My documents\POVray-bilder\Matrix03_.inc:54: error: Cannot pass
uninitialized identifier as macro parameter.
Initialize first.
  #local NN = array[3]
  #local NN[0] = <MM[0] <----ERROR
C:\My documents\POVray-bilder\Matrix03_.inc:40: error: Attempt to access
uninitialized array element.
Here is the POV-file that generates the errors:
// Copyright 2000 by Tor Olav Kristensen
#macro S3Prod(U, V, W)
  vdot(U, vcross(V, W))
#macro Mcof(MM)
  #local NN[0] = vcross(MM[1], MM[2]);
  #local NN[1] = vcross(MM[2], MM[0]);
  #local NN[2] = vcross(MM[0], MM[1]);
  NN
#macro Mdet(MM)
  S3Prod(MM[0], MM[1], MM[2])
#macro Mtrans(MM)
  #local NN[0] = <MM[0].x, MM[1].x, MM[2].x>;
  #local NN[1] = <MM[0].y, MM[1].y, MM[2].y>;
  #local NN[2] = <MM[0].z, MM[1].z, MM[2].z>;
  NN
#macro Mmult(MM, NN)
  #local QQ[0] = <vdot(MM[0], PP[0]), vdot(MM[0], PP[1]), vdot(MM[0],
PP[2])>;
  #local QQ[1] = <vdot(MM[1], PP[0]), vdot(MM[1], PP[1]), vdot(MM[1],
PP[2])>;
  #local QQ[2] = <vdot(MM[2], PP[0]), vdot(MM[2], PP[1]), vdot(MM[2],
PP[2])>;
  QQ
#macro Mscale(s, MM)
  #local NN[0] = s*MM[0];
  #local NN[1] = s*MM[1];
  #local NN[2] = s*MM[2];
  MM
#macro Minv(MM)
  #local s = 1/Mdet(MM);
  #local NN = Mcof(MM)
  #local QQ = Mscale(s, PP)
  QQ
#declare MMi =
array[3] {
  <  2,  0,  6>,
  <  8,  1, -4>,
  <  0,  5,  7>
#declare QQi = array[3]
#declare QQi = Minv(MMi)
#declare RRi = array[3]
#declare RRi = Mmult(MMi, Minv(MMi))
Subject: Re: Different error messages for same POV-file
Date: 13 Mar 2000 11:42:40
Message: <38CD1A4C.548C1ABE@spiritone.com>
What do you have for the version number in the scene. That can effect which
features are enabled or not. Also, are you using MegaPov? I usuall have to
add #version unofficial MegaPov 0.4; to my scenes to get those to work.
Josh
Tor Olav Kristensen wrote:
> Hello
> Regards
> Tor Olav
> http://www.crosswinds.net/~tok/tokrays.html
<snip>
Josh English
eng### [at] spiritonecom
Date: 13 Mar 2000 12:45:08
Message: <38CD2959.151A5E04@gci.net>
I know that these are not directly part of the problem,
but, s seems to be flagged as a reserved word in MegaPOV.
> Hello
><snip>
>   MM
> #end
> #macro Minv(MM)
>   QQ
> #end
Mr. Art
"Often the appearance of reality is more important
than the reality of the appearance."
Bill DeWitt 2000
Date: 13 Mar 2000 17:17:52
Message: <38CD6815.BAB28BB6@hotmail.com>
Hi Josh
Thanks for replying.
I had not put any #version declaration in the file.
But now I did try to insert
#version 3.1;
at the beginning of the file, but the problems persists.
I still get wildly changing error messages for the same file.
(I even got new ones.)
No, I am using plain POV-Ray v3.1g for Windows
Regards
Tor Olav
> > Hello
> > Regards
> > Tor Olav
Date: 13 Mar 2000 17:34:20
Message: <38CD6BF2.D5D56C4D@hotmail.com>
Hello mr. art
Right now I did try to replace the s with other
variable names, but it didn't stop those ever-
changing error messages.
I'm just using plain POV-Ray (v3.1g) for Windows
(Not MegaPOV).
I looked up reserved identifiers and keywords in
the help file, but I could not find 's' listed
for this plain version of POV-Ray.
Regards
Tor Olav
> > Hello
> ><snip>
> >   MM
> > #end
> > #macro Minv(MM)
> >   QQ
> > #end
> Mr. Art
> Bill DeWitt 2000
Date: 13 Mar 2000 23:09:26
Message: <38CDBDFA.B52B3077@erols.com>
I have sometimes gotten error messages that seemed like the
wrong error message.  If I recall correctly, it turned out that
the actual error was at some point earlier than what the parser
flagged.
ICQ: 46085459
Date: 14 Mar 2000 03:39:23
Message: <38CDFB03.F82A8CEA@aetec.ee>
> Hello
Hello.
Just a thought: try to add semicolons to lines, where they are
missing...
Date: 14 Mar 2000 17:29:10
Message: <38CEBC39.582A511F@online.no>
Hello John
I too have got error messages pointing to the
wrong point in my code when my error(s) were
hidden somewhere earlier.
In these cases I just had to start commenting
out code, changing variable names and moving
things around until the error messages points
at my real error.
I suspect that this may also be the case here,
and I have therefore tried to play around with
my code before posting to this newsgroup... But
I haven't had any luck smoking out my(?) errors
yet.
But I have found out that if I replace the last
line of these four:
with
#declare RRi = Mmult(MMi, QQi)
then the error messages disappear.
This may be my solution for this time, but the
problem still bothers me, because I want to be
able to replace macros like e.g. this one:
#macro Minv(MM)
  QQ
with macors like this one:
#macro Minv(MM)
  Mscale(1/Mdet(MM), Mtrans(Mcof(MM)))
Lately I have also found that it seems that
the more I do of the substitutions like the
one above, the more it seems likely that I
start getting those random changing error
messages I have described earlier.
(It seems like I can do some substitutions
without being punished.)
And now I don't know how to proceed in my
hunt for these errors.
Am I the only one who is getting changing
error messages when running the code I
enclosed in my initial posting?
Regards
Tor Olav
> flagged.
> ICQ: 46085459
Date: 14 Mar 2000 18:09:40
Message: <38CEC5B6.C3C921B1@online.no>
Hi Vahur
> > Hello
> Hello.
> missing...
Hmm...
I have been a little bit worried about my use of semicolons.
Earlier I have seen that too many missing semicolons can
cause crashes of POV-Ray (on my Windows 98 machine at home,
and if I remember right, also on my Windows NT4 machine at
work).
Therefore I have looked through my code to make sure that I
had put them where I thought they should be.
But your reply (thank you btw.) made me check both my code
and the help file once again.
Here are my (rather lengthy) findings:
When POV-Ray parses my file, I do not get any warning
messages like this one:
warning: All #versions and #declares of float, vector, and
color require semi-colon ';' at end.
So everything apparently looked fine, but I thought that
maybe my array declarations should have some semi-colons as
well (even if array declarations aren't mentioned in
messages like the one above.)
In the help file for Windows didn't have any luck finding
explicit instructions about whether I should use semi-colons
after array declarations or not.
But I found two code examples of array declarations:
The first one
8< snip
 #declare MyArray = array[10];
 #declare MyArray[5] = pigment{White}  //all other elements must be
                     //pigments too.
8< snip
used semi-colon, and the second one
8< snip
 #declare MyGrid = array[4][5]
 #declare YourArray = MyArray  //this is ok
8< snip
did not.
So now I thought that I should try to insert some of them
after my array declarations.
So I did, but now the parser started complaining about these
semi-colons:
#declare NNi = array[3]; <----ERROR
error: object or directive expected but ; found instead.
... So now I am totally confused about semi-colons!
Regards
Tor Olav
Date: 14 Mar 2000 22:35:42
Message: <38CF057C.6499B18E@peak.edu.ee>
> work).
This is new to me. You mean the machine crached? Or just POV quit parsing?
Usually, missing semi-colons should only produce warnings (at least in the
current version). Only in some macros have I seen actual errors caused by them.
Semi-colons should only go after declarations of floats and vectors (colours can
also be thought of as vectors).
If you are declaring an array, it should not have a semi-colon:
#declare MyArray=array[10]
If the docs said otherwse, this is a typo. However, if you are declaring an
element of an array, and that element is a float or a vector, it should have a
semi-colon:
#declare MyArray[0]=11.5;
See docs section "Declaring identifiers" for further reference.
Margus
Date: 15 Mar 2000 21:18:55
Message: <38D04719.6BCA95E9@erols.com>
> Hello John
> at my real error.
> yet.
> line of these four:
> with
There appears to be a bug in macro argument parsing.  Sometimes when
I #declare a value using a macro, the semicolon at the end of the
declare statement is flagged as an error, and when it's absent a
warning message is displayed.
John
ICQ: 46085459
Date: 15 Mar 2000 21:18:56
Message: <38D04348.E90DFF94@hotmail.com>
> > work).
I mean that as far as I remember, POV-Ray stopped executing and Windows
gave me an error message like:
This application has performed an illegal operation...
(When I restarted POV-Ray, reloaded the offending POV-file and tried
to run it again, I got the same crash. And when I thereafter added all
the
necessary semi-colons POV-Ray executed correctly again.)
Earlier I had not got used to typing semi-colons at the end of float
and vector declarations, so I saw these error messages once or twice a
month or so, but now I usually forget very few of the semi-colons, so I
seldom see these crashes.
If it happens again I will provide you with the offending POV-file.
Btw. Do you have any idea of how POV-Ray manage to give me several
different error messages after successive runs (without me altering
my code or any settings in POV-Ray) ?
For me this seems like POV-Ray is in error ...
(Or could my error trigger several error messages, where only a
random selected one is printed each time?)
The funny thing is that none of the keywords ('clock_delta', 'tan',
'on') that POV-Ray claims it found in a wrong place, appears in my
POV-file.
error: undeclared identifier expected but float function 'clock_delta'
found instead.
> semi-colon:
Thanks for clarifying!
> Margus
Regards
Tor Olav
Date: 16 Mar 2000 17:18:02
Message: <chrishuff_99-E1521E.17195916032000@news.povray.org>
In article <38D04348.E90DFF94@hotmail.com>, Tor Olav Kristensen
I really wish POV-Ray would accept, if not require, semicolons at the
end of declarations. It should be a simple modification to make, at
least for someone who understands the declaration code(I don't).
> POV-file.
> found instead.
It sounds like POV is using(internally, not in your scene) a variable
that doesn't get initialized...this would qualify as a bug even if that
isn't the cause.
Chris Huff
e-mail: chr### [at] yahoocom
Date: 16 Mar 2000 17:23:40
Message: <38D15EDC.6F76A0B0@pacbell.net>
Why ?
Date: 16 Mar 2000 17:44:44
Message: <chrishuff_99-D4B263.17464216032000@news.povray.org>
In article <38D15EDC.6F76A0B0@pacbell.net>, lin### [at] povrayorg
> Why ?
So we don't have to remember which times a semicolon is required?
Currently, it is not consistant. You have to memorize the special
cases:float, vector, color... It would be easier to just allow a
semicolon at the end of every #declare and #local. If they were
required, it might even simplify the parser and make things a little
faster.
Chris Huff
Date: 16 Mar 2000 18:10:24
Message: <38D169C7.81AB9F18@pacbell.net>
> > Why ?
> faster.
#declare Bob =
object {
  #declare Axel = box{-.5,.5}
  #declare Col1 = rgb<1,1,1>;
  #declare Col2 = rgb<0,0,0>;
  #declare XXX = pigment{checker color Col1 color Col2}
  #declare a = 0;
    #while (a<1)
      object{Axel translate a pigment{XXX}}
    #declare a=a+1;
object{Bob}
Which semi-colon closes the Bob declaration in the example above ?
I know it is obvious to us but this is a simple example which might
confuse the hell out of the parser.
Or do you make yet another special rule so that semi-colons don't
apply to declared objects and CSG operations because they already
use curly braces to define their ending ?
Does this make sense #declare foo = object {bar};  ?
Date: 16 Mar 2000 18:48:26
Message: <chrishuff_99-7F0265.18502216032000@news.povray.org>
In article <38D169C7.81AB9F18@pacbell.net>, lin### [at] povrayorg
wrote:
> > wrote:
> > > > the
> > > Why ?
> > faster.
> #declare Bob =
> object {
>   #declare a = 0;
>     #while (a<1)
>     #declare a=a+1;
>   #end
> object{Bob}
The last one.
I doubt it, it shouldn't be hard to do. Actually, it most likely
wouldn't require much extra work at all. And you missed two, one in the
declaration of Axel and the other in XXX.
And just to nit-pick, your while loop is indented wrong, the #while
should be on the same level as "#declare a = 0;", and "object{Axel..."
should be on the same level as "#declare a=a+1;". And it would probably
be a good idea to use capitals instead of lowercase, "A" insead of "a",
to avoid conflicts with future reserved words/characters. And those
#declares(other than the loop counter) really should be outside the
object, no purpose is served in putting them there. And your #while()
loop will only loop once, kind of useless that way. :-)
The } defines the end of the object, not the declaration, so the
semicolon should remain. Maybe also allow an "implied union" without a
"union {}" wrapper(just specify multiple objects between the "=" and the
";"), but I don't think that would be very useful and it would make
things harder to read.
And yes, that code makes sense.
Chris Huff
Date: 16 Mar 2000 22:02:19
Message: <38D1A00E.197487CE@pacbell.net>
I will indent my code anyway I see fit and I think you are over complicating
things.
Date: 17 Mar 2000 10:04:22
Message: <38d24976@news.povray.org>
Ken <tyl### [at] pacbellnet> wrote:
: I know it is obvious to us but this is a simple example which might
: confuse the hell out of the parser.
  Language parsers (C++, Java...) do it all the time (ie. several nested
blocks which end with ';') so it's not so difficult after all. For example:
class Test
{ int x;
Date: 17 Mar 2000 10:05:19
Message: <38d249ae@news.povray.org>
Chris Huff <chr### [at] yahoocom> wrote:
: And just to nit-pick, your while loop is indented wrong
  Don't tell him how to indent. He will not listen anyways :)
Date: 17 Mar 2000 10:08:31
Message: <38D249E9.62CF25D3@pacbell.net>
You sure got that one right.
Date: 17 Mar 2000 15:24:50
Message: <38D29BC3.8ACD0FC9@merlin.net.au>
#declare Foo = Bar;
Now replace Foo with whatever variable you want and replace Bar with
whatever you want to initialise it with.
Doesn't that make more sense than having lots of rules about when to put
the semicolon?
PoD.
Date: 17 Mar 2000 22:42:00
Message: <38D2F9B2.2E69D588@hotmail.com>
> > found instead.
> isn't the cause.
Do you think this may be the same bug that appears when running the
file I enclosed in my posting "POV-file that crashes POV-Ray"
17. March ?
Regards
Tor Olav
Date: 17 Mar 2000 22:52:48
Message: <38D2FC3B.2972B2A1@hotmail.com>
I have now found a way to do several nested
calls of macros that passes arrays to each other
(like in the last macro below), without
getting error messages and without having to
make global declarations of local variables.
I will post my "solution" here if anyone is
interested.
Regards
Tor Olav
> ...I want to be
> #macro Minv(MM)
>   QQ
> #end
> #macro Minv(MM)
> #end
