POV-Ray : Newsgroups : povray.general : Multiprocessor versions of POV? Server Time
16 Oct 2026 20:34:26 EDT (-0400)
  Multiprocessor versions of POV? (Message 1 to 30 of 30)
Subject: Multiprocessor versions of POV?
Date: 29 Feb 2000 15:51:58
Message: <38BB7303.BFC9E8CE@t-online.de>
I know, this might have been asked quite often. But is there a listing
of POV versions running on multiprocessor platfoms?
I'm especially thinking of a dual celeron solution.
What OS do I need (NT,Linux,...)?
Any suggestions. Anyone already made experiences with this matter?
Karl
Subject: Re: Multiprocessor versions of POV?
Date: 29 Feb 2000 18:05:30
Message: <38BC5036.469E2968@pacbell.net>
> Karl
You can find some information about running POV-Ray on multiple processors
here -
http://www.students.tut.fi/~warp/povVFAQ/languageVFAQ.html#multiprocessor
Date: 1 Mar 2000 12:47:08
Message: <38BC9930.97F9A65C@t-online.de>
> here -
> Ken Tyler -  1300+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Thanks Ken.
Again you saved me. This article is mostly about NT. It seems to be easy
to let two copies of POV render the same time (O.K. some restrictions).
But this might be useful for animations. One copy renders the even
frames and the other copy of POV renders the odd frames.
Anyone here made experiences with linux or with a multithreaded version
of POV?
Karl
Date: 1 Mar 2000 15:23:06
Message: <WcW8OD1M+fXfjwxh2zRS8HSKneHD@4ax.com>
On Tue, 29 Feb 2000 08:19:31 +0100, Karl Pelzer
>Karl
Being the lazy bum that I am, I'll just copy & paste from a reply I
send to the exact same question a couple of days ago. Here we go...
POV-Ray is indeed currently incapable of making use of SMPs.
There have been PVM ports of POV-Ray but I don't think a 3.1 one
is available let alone MegaPOV.
But, there is always a workaround :) If you can't take advantage of
multithreading, do so with multitasking. Run two instances of POV
and give each of them a separate portion of the image. Depending
on the image, one part may take significantly longer to render than
the other, imposing some difficulties. There are three basic ways to
split up the work:
1. Give the top half of the image to one instance of POV and the
bottom half -- to the other one.
2. The same, but use left/right halves instead.
3. Make one instance render the odd lines and the other instance --
the even lines. To do so, type this in the command line (the INI file
won't work because both files share a single povray.ini):
+uf +kfi0 +kff1 +ef0
and this in the command line of the second instance of POV:
+uf +kfi0 +kff1 +sf1
This will make two images, say output0.tga and output1.tga . The
first one will contain the even lines and the second one will contain
the odd lines. Open the images in a paint program and deinterlace
them.
I hope this works OK for you.
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 1 Mar 2000 16:08:19
Message: <38BD871A.ADBEC198@t-online.de>
Peter Popov wrote:
<large snip>
<snip>
Thanks.
But honestly I'm not satisfied yet. Your solution goes into the same
direction as the ideas found with Ken's link.
Thanks again though!
Karl
Date: 1 Mar 2000 16:49:28
Message: <38bd9068$1@news.povray.org>
THERE IS NO MULTITHREADED VERSION OF POV-RAY.  PERIOD.
If you really must know why, go read one of the dozens of threads over in
povray.programming, or even in this very group, that cover that topic in
excruciating detail.  The short version, though, is that coding properly
for multiple threads isn't as easy as Microsoft wants you to believe it is.
Besides, process switches are nearly as fast as thread switches, so what's
the problem with the solutions presented so far?
These are my opinions.  I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
Date: 1 Mar 2000 17:44:10
Message: <j5u9ODjR7eqs7lL9pnZaG+YUUIyx@4ax.com>
On 1 Mar 2000 16:49:28 -0500, ron### [at] povrayorg (Ron Parker)
Gee, these keyboards are getting crappier every day. Ron's caps lock
key got stuck, and the darn thing isn't even three months old.
I believe the problem lies in basically having to redesign everything
from scratch, which the Team would not be likely to do solely for the
sake of multi-threadedness.
Memory consumption? I believe two threads can share the same memory
(for reading at least) but not so for two processes.
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 1 Mar 2000 23:06:23
Message: <slrn8brq92.v8.ron.parker@parkerr.fwi.com>
Actually, that keyboard is more like two years old.  But believe it
or not, I didn't use caps lock to type that line.
Pretty much.  Mainly, the problem lies in the overuse of global variables.
Since that's such a bad idea anyway, we're working on getting them under
control for "a future release" but it still might not be easy to do
multiple threads, due to the fact that there is no standardized way to
do multiple threads across all supported operating systems.
Two threads in the same process share all the same memory; this is
the main problem: they can trample on each other's global variables.
Having variables local to a specific thread is actually somewhat
complicated, at least in Windows.
Two processes should be able to share an executable image, but I
wouldn't be the least bit surprised to hear that this isn't implemented
on Windows-based operating systems, or at least those before W2K.  I
know I was surprised to find out there's essentially no memory
protection on executable code (though I went through the motions and
VirtualProtect'd the pages I needed to modify anyway, just for the
sake of safety.  They may one day actually make that code do something.)
Two processes can opt to share a read/write region of memory, at least
in Windows, by using memory-mapped files, but this is fraught with
danger in that some versions of Windows will map them to the same
address in different processes (9x, Millennium) and some will map
them to completely different addresses (NT 4 and 2000).  This is a
problem if you elect to store any pointers in the shared memory, as
they'd only be valid in one process.  The workaround is relatively
simple, but it's still a pain to have to think about such things.
Worse, if you do your development on 9x, you'd never know the problem
existed.  Even Microsoft has fallen prey to this caveat in one of
their more specialized development tools.  (Though to be fair, the
tool was for working with a feature that didn't exist on NT in a
publicly released version at the time.  Unfortunately, I was using
an unreleased (i.e. not even beta) version, and I needed the tools.)
Date: 2 Mar 2000 01:25:06
Message: <38be0942@news.povray.org>
On a dual processor NT machine (NT v4) you can run 2 copies of POVRay at the
same time with minimal interference.  To minimize CPU thrashing I'd suggest
you use the set affinity command via the task manager processes tab.
Jim
Check out my web site  http://www.kressworks.com/
Ron Parker <ron### [at] povrayorg> wrote in message
news:slr### [at] parkerrfwicom...
Date: 2 Mar 2000 07:28:14
Message: <38BE5D1A.FFD217AB@pacbell.net>
My keyboard is 16 years old and works as well today as when I first
purchased it. About once every 2 years I pop all the keys off and
throw them into the dishwaser but other than that it has seen no
other maintenance.
True story - date code on my keyboard is 1984 (the year the world
was really supposed to end)
Date: 2 Mar 2000 08:15:21
Message: <38be6969@news.povray.org>
    Ehh? Did I miss something?
Date: 2 Mar 2000 08:18:40
Message: <38BE68E6.B34DA813@pacbell.net>
George Orwell's book  "1984". Required reading in my English Lit. class
in high school.
Date: 2 Mar 2000 08:22:03
Message: <38be6afb$1@news.povray.org>
> in high school.
    One of my favorites, but I don't remember anything about the world
ending in it...?
Date: 2 Mar 2000 08:52:46
Message: <38BE723F.2080B213@gci.net>
The main character gave in to "the system" and might as
well have been dead, for all the free thought he had. i.e. he
had none. He seems to have been the last character to dare
do anything that "Big Brother" didn't like. He just became
a mindless cog in a vast machine. This sounds too much like
the end of the world to anyone who likes to be different.
> > in high school.
> ending in it...?
Mr. Art
"Often the appearance of reality is more important
than the reality of the appearance."
Bill DeWitt 2000
Date: 2 Mar 2000 09:28:20
Message: <38BE7AED.C9B3DC7E@student.uni-siegen.de>
> other maintenance.
Too much work. Take a dish large enough to hold the keyboard.
Fill it with Screen cleaning foam. Dip the keyboard in it for
about two hours and take it out -> clean.
Markus
Date: 2 Mar 2000 09:45:46
Message: <38BE7D40.7C6D5B6D@pacbell.net>
> > other maintenance.
> Markus
Your method has merits but with my method I also take the time to blow
out the dust bunnies, dead skin cells, and the stray hair of two that
accumulate underneath the keys and occasionaly cause erratic behavior.
I will add that my keyboard was manufactured in Germany and I have to
say that the German reputation for solid engineering is evident in
this product.
Date: 2 Mar 2000 09:56:42
Message: <38BE813D.275DC1B2@gci.net>
I have had keyboards that didn't last two years.
Mostly because the letters wore off.
> other maintenance.
Mr. Art
Bill DeWitt 2000
Date: 2 Mar 2000 10:44:21
Message: <38BE945E.ED27DB78@merlin.net.au>
> Markus
I had a keyboard with coffee spilled in it once.
Washed it in water and detergent, rinsed with distilled water and it
worked fine.
PoD.
Date: 2 Mar 2000 10:54:30
Message: <38be8eb5@news.povray.org>
Ken <tyl### [at] pacbellnet> wrote:
: True story - date code on my keyboard is 1984
  What!?! You are not using a Win95-keyboard? Shame on you!
  (My keyboard is about 6 years old)
Date: 2 Mar 2000 11:26:07
Message: <38be961f$1@news.povray.org>
My keyboards at home are neither win95-keyboards.  One is at
least six years old, and the other I don't know as I picked it
up for $6 at Goodwill.  Praps I'll look up the date codes next
time I think about it.
Date: 2 Mar 2000 12:37:49
Message: <38bea6ed@news.povray.org>
    Ah, not the end of the world, just the end of a particular world that
you prefer. Not to worry, happens to me every day.
Date: 2 Mar 2000 14:24:32
Message: <qqmn1oh5g5r.fsf@schlatt.fmi.uni-konstanz.de>
Nieminen Juha <war### [at] sarakerttunencstutfi> writes:
My keyboard is 8 years old and I will keep it until they
invent a keyboard with a larger space bar (i.e. without
these silly Windows-keys).
http://thomas.willhalm.de/ (includes pgp key)
Date: 2 Mar 2000 14:47:07
Message: <38BEC594.E3CDBBE@t-online.de>
O.K. I'll shut up now...
Karl
Date: 2 Mar 2000 15:20:49
Message: <4n2+OFLPD8NjyHvGifn62mWNk5Zo@4ax.com>
On 1 Mar 2000 23:06:23 -0500, ron### [at] povrayorg (Ron Parker)
I trust you :) I am yet to see a programmer use the caps lock key for
something shorter than 255 characters. The use of the shift key makes
typing constant names with underscores in them really easy.
And I wasn't serious about the keyboard either.
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 3 Mar 2000 03:53:23
Message: <38BF7DEE.5BB5EDB6@student.uni-siegen.de>
That's right. But from time to time I simply turn it upside down
to take out ashes, tobacco and whatnot ;-)
Markus, made in Germany
Date: 8 Mar 2000 22:00:02
Message: <38C7150E.B2AF98FD@mailbag.com>
Why do you need letters?
-Mark Gordon
Date: 8 Mar 2000 22:42:31
Message: <38C71DBD.FF035F34@gci.net>
Bad typing skills. And stop sounding like my wife.:)
> -Mark Gordon
Mr. Art
Bill DeWitt 2000
Date: 9 Mar 2000 19:59:56
Message: <486jcsg3gg6o75cbo8ulmvq3tpndb0n66g@4ax.com>
  Hi, Mr. Art. Don't buy another keyboard just because the letter wore
off - get a permanent fine point marker like the Sharpee brand and put
'em back on the keys.
  I've wore down the little 'nubs' used for touch typing on the 'F' and
'J' keys but a tiny dab of epoxy or maybe even silicone sealant (not
silicone bathtub caulk - it doesn't dry out enough) is enough to regain
the feel of the keyboard position.
  Ever try Mavis Beacon's typing programs? I used to have it on my old
system and it can be fun at times. I think there was one exercise that
measured typing speed in terms of a car speedometer. That was my
favorite.
Alan - ako### [at] povrayorg - a k o n g <at> p o v r a y <dot> o r g
Date: 9 Mar 2000 22:20:41
Message: <38C86A1D.F0E01E0A@gci.net>
I have tried to use Mavis Beacon's typing programs. And they have
helped.
But having large fingers and arthritis and mild carpeltunnel (sp?)
and more whining and more whining ...
Needless to say, I don't type very fast. So I never could get to the
speeds that could be bragged about. The only thing that I can do to help
is use a Dvorak keyboard. Keeps me from having to move the fingers as
much.
p.s. Take your time reading this as it took me some time to type it.:)
> favorite.
Mr. Art
Bill DeWitt 2000
Date: 10 Mar 2000 21:33:54
Message: <sb0mcs0g1p9qu2gnqps02o488u20evjtu7@4ax.com>
On Thu, 09 Mar 2000 18:21:01 -0900 "mr.art" <mr.### [at] gcinet> wrote:
>...But having large fingers and arthritis and mild carpeltunnel (sp?)
>and...
  Okay, I understand the situation better now. More practice may make
matters worse :(
