POV-Ray : Newsgroups : povray.general : Declaring blob components ? Server Time
27 Oct 2026 02:37:44 EDT (-0400)
  Declaring blob components ? (Message 1 to 16 of 16)
Subject: Declaring blob components ?
Date: 27 Feb 2000 21:19:56
Message: <38B88C1C.8C4FE0D2@earthlink.net>
Basically how do i declare a blob component such as a cylinder...?
It will not seem to accept the strength as a valid cylinder entry...?
I want to declare a component and use i.e. MyCylinder to rotate ti
around the central components w/ out rewriting the entire component...?
Subject: Re: Declaring blob components ?
Date: 27 Feb 2000 22:21:21
Message: <38B9E9BC.87AB090C@gci.net>
You could use macros
#macro MyCylynder(...) -y,+y,RB-.02 #end
#local S1=-50;#local S2=-100;
blob	{
		threshold .0001
		cylinder{0,y*.06,RB,20}
		cylinder{MyCylynder,S1 translate -x*.06}
		cylinder{MyCylynder,S1 translate -x*.06 rotate +y*120}
		cylinder{MyCylynder,S1 translate -x*.06 rotate -y*120}
		cylinder{MyCylynder,S2 translate <0,RB,-(RB-.01)> rotate +y*030}
		cylinder{MyCylynder,S2 translate <0,RB,-(RB-.01)> rotate +y*090}
		cylinder{MyCylynder,S2 translate <0,RB,-(RB-.01)> rotate +y*150}
		cylinder{MyCylynder,S2 translate <0,RB,-(RB-.01)> rotate +y*210}
		cylinder{MyCylynder,S2 translate <0,RB,-(RB-.01)> rotate -y*030}
		cylinder{MyCylynder,S2 translate <0,RB,-(RB-.01)> rotate -y*090}
		sphere	{0,RB,-100 scale <1,.65,1> translate -y*(RB*.35)}
Mr. Art
"Often the appearance of reality is more important
than the reality of the appearance."
Bill DeWitt 2000
Date: 28 Feb 2000 01:48:37
Message: <38B8CB14.67017D76@earthlink.net>
Thank you i will try ( try is the operative ) this my macro skill is none at this
point.
But still worth a try...
It still is not a declaration where i can change all the declared components at
once. Or can i... Like i said i have no understanding of the macro.. Well almost
none...
> blob    {
>                 threshold .0001
> Mr. Art
> Bill DeWitt 2000
Date: 28 Feb 2000 02:49:17
Message: <38BA2810.885CA53B@pacbell.net>
> point.
> none...
There is now a tutorial available on using and making POV-Ray macros that may
help you understand them better -
http://www.hoboes.com/html/NetLife/POV/Scripting/
Date: 28 Feb 2000 06:39:44
Message: <vjnkbscr3cs69bp1vtn2nng23es5su4ehj@4ax.com>
Here is something using the same technique as mr.art's reply, but more self
explanatory.
It may do what you are looking for.
#macro Cy(PitchRad) <PitchRad,0,0> <PitchRad,1,0> Rad, Strength #end
#local Rad =1;
#local Strength =2;
#local Ang=0;
blob {
      #while (Ang<360)
      cylinder { Cy(4) rotate y*Ang  }
      #local Ang=Ang+20;
      pigment {Red}
dav### [at] cwcomnet
http://www.hamiltonite.mcmail.com
Date: 28 Feb 2000 06:51:30
Message: <38ba6142@news.povray.org>
I'm having the same problem as Moon47.
Do I take it from the various answers given that it is not possible to
declare a whole blob component?
Date: 28 Feb 2000 14:47:41
Message: <q6klbskh7njnqkf39c6mhvk9q8b0hdrfo4@4ax.com>
On Mon, 28 Feb 2000 11:51:17 -0000, "Tom Melly" <tom### [at] tomandluforce9couk> wrote:
What do you mean by "whole blob component"?
Blobs can be as complicated as you can devise them.  You only have to see H.E.Day's
images
to see the power of blobs.  Run the code I gave in my answer to Moon74 to see just one
blob.
In one blob you can keep on adding spheres and cylinders with positive and negative
strengths to add or subtract from the final shape.  These spheres and cylinders can
also
be distorted by uneven scaling. The individual components in a blob can be given
different
textures and this can all add up to a fiendishly complicated object.
On top of this you can use csg to carve out or to add bits.
Alright, I've convinced myself, I must start to use blobs :-)
Date: 28 Feb 2000 17:04:28
Message: <38B9A1BE.4600D82C@earthlink.net>
Thank you o' linker of links...
Once again saving the day...
The link buster...
The magical...
The wonderful..
The illustrious...
Ect... Ect... Ect...
Ken wrote:
> > point.
> > none...
> Ken Tyler -  1300+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Date: 28 Feb 2000 17:08:10
Message: <38B9A29D.9969C220@earthlink.net>
I think they are hinting at that... =(
"If All Else Fails..."
"...Try Reading The Directions."
Famous quote from my none other than... My Father...
Date: 28 Feb 2000 17:09:54
Message: <38BAF1C9.BD6CF68C@pacbell.net>
> The link buster...
> The magical...
> The wonderful..
> The illustrious...
While I appreciate the praise ( who doesn't ? ) part of the credit should
also go to those writing the tutorials. Without their efforts I would have
nothing to link to.
Date: 29 Feb 2000 00:50:47
Message: <38bb5e37@news.povray.org>
David Wilkinson wrote in message ...
H.E.Day's images
see just one
>blob.
negative
cylinders can also
given different
One limit:  A single blob cannot have more than one million components.
Mark
Date: 29 Feb 2000 04:57:01
Message: <38bb97ed@news.povray.org>
David Wilkinson <dav### [at] cwcomnet> wrote in message
news:q6klbskh7njnqkf39c6mhvk9q8b0hdrfo4@4ax.com...
I mean that you cannot declare a blob component in the way that you can
declare a sphere or box. Instead you have to declare the individual vectors
and so on that make up a component.
Date: 29 Feb 2000 05:43:54
Message: <9j8nbskb20kp6fne8mopue11oknvsf2tem@4ax.com>
On Tue, 29 Feb 2000 00:54:08 -0500, "Mark Wagner" <mar### [at] gtenet> wrote:
<snip>.
>Mark
I'll just have to try and keep them simple then :-)
Date: 29 Feb 2000 05:53:06
Message: <bq8nbsoer1k6cndiri5fa8b280hp4uku1m@4ax.com>
On Tue, 29 Feb 2000 09:56:47 -0000, "Tom Melly" <tom### [at] tomandluforce9couk> wrote:
OK Tom, we're just differing on semantics. Because a blob is not a regular geomtric
solid
the information necessary to define a blob increases with the complexity of the shape.
Even with a box you have to define the vectors that define it.
Date: 29 Feb 2000 09:21:32
Message: <38BBDAAB.E43ABFEB@merlin.net.au>
solid
shape.
Any primitive can be #declared regardless of its complexity, but the
_components_ of a blob cannot.
There is a practical significance.  E.g. blob components can't be stored
in arrays.
PoD.
Date: 29 Feb 2000 21:19:25
Message: <38BB2EFF.1504033B@earthlink.net>
You're right now would be a good time to say that without this tutorial i
would not have finished my " Two Cents..." Post... A very awesome tutorial i
will make sure to than the author at first chance...
Thanks again... =)
> > The link buster...
> > The magical...
> > The wonderful..
> > The illustrious...
> nothing to link to.
