POV-Ray : Newsgroups : povray.general : Inverse Kinematics Neck Include File out now ! Server Time
27 Oct 2026 04:23:43 EDT (-0400)
  Inverse Kinematics Neck Include File out now ! (Message 1 to 14 of 14)
Subject: Inverse Kinematics Neck Include File out now !
Date: 24 Jan 2000 15:47:21
Message: <388cba59@news.povray.org>
My Inverse Kinematics Neck Include File
is out now! It's available from here:
http://rsj.mobilixnet.dk/3d/ikn/ikn.html
The Inverse Kinematics Neck Include File (or just
ikn.inc) allows you to create smooth strings of
objects which you can use for long necks, long
tails, and many other things. You use it by
specifying, as a minimum, end points, forward and
up vectors at these points, the thickness in both
ends, and the length of the neck. After that you
include ikn.inc, and it will, amongst other
things, create an array with transformations
ready to apply to objects of your choice.
See povray.binaries.images for sample images and
for more information, and see
povray.binaries.animations for a 347 KB 5 seconds
long animated gif.
I've documented the include file, but I don't
think the documentation is very good, so if anyone
feel they could explain it better it would be
great.
I hope you find the IKN include file useful, and
please give me some feedback!
Greetings,
Rune
Updated January 24: http://rsj.mobilixnet.dk
Containing 3D images, stereograms, tutorials,
The POV Desktop Theme, 350+ raytracing jokes,
miscellaneous other things, and a lot of fun!
Subject: Re: Inverse Kinematics Neck Include File out now !
Date: 24 Jan 2000 15:51:12
Message: <388CBA9A.B52BDB0B@xs4all.nl>
> long animated gif.
> great.
> Greetings,
> Rune
Got it!
Thanks.
Now to find some time to figure out how it works.
oooooooo
Remco
Date: 24 Jan 2000 15:53:22
Message: <388CBB21.382CA33F@xs4all.nl>
> > long animated gif.
> > great.
> > Greetings,
> > Rune
> Got it!
> Thanks.
> oooooooo
> Remco
O, by the way, very nice demo-animation!
Date: 24 Jan 2000 15:59:51
Message: <388cbd47@news.povray.org>
>> Got it!
>> Thanks.
>> oooooooo
>> Remco
That was some quick responses!
Thanks!
Greetings,
Rune
Date: 24 Jan 2000 16:50:28
Message: <388cc924@news.povray.org>
"Rune" <run### [at] inamecom> wrote in message
news:388cba59@news.povray.org...
    Everyone here has had the same response... "Ooo... Coooolll!!"
    I now have a couple of hundred projects that I want to do with it.
Date: 24 Jan 2000 17:13:49
Message: <388cce9d@news.povray.org>
> is out now!
Thanks Rune! I can't wait to get home to try it out. =)
Date: 25 Jan 2000 16:12:06
Message: <388e11a6@news.povray.org>
>> is out now!
>it out. =)
When you have had a closer look at it, let me
know what you find good and bad about it! :-)
Greetings,
Rune
Date: 25 Jan 2000 16:12:07
Message: <388e11a7@news.povray.org>
>"Ooo... Coooolll!!"
Yes, thanks! It really makes it worth it!
I hope it's really so useful to you all that
you appear to think it is ...!
Hope to see these projects in p.b.i then!
Greetings,
Rune
Date: 25 Jan 2000 16:12:09
Message: <388e11a9@news.povray.org>
Thanks for the positive reactions!
I would still like some feedback when
you've had a closer look at the package.
Positive and negative feedback is equal
appreciated as long as it is constructive!
I forgot to thank all those who came with
suggestions while I was making the include
file! It helped me a lot!
Also thank to LinkMaster for, uninvited as
always, to put the link out on the povray
links page.
Greetings,
Rune
Date: 25 Jan 2000 19:57:00
Message: <388e465c@news.povray.org>
OK. I was trying it out, and found that the second example file won't finish
parsing, but rather reports the following:
o Calculating transformations...
ikn.inc:237: warning Illegal matrix column: Scale by 0.0. Changed to 1.0.
         ikn_x[_c].x,ikn_x[_c].y,ikn_x[_c].z,
         ikn_y[_c].x,ikn_y[_c].y,ikn_y[_c].z,
         ikn_z[_c].x,ikn_z[_c].y,ikn_z[_c].z,
         ikn_p[_c].x,ikn_p[_c].y,ikn_p[_c].z
      > <----ERROR
ikn.inc:237: error: Singular matrix in MInvers.
Was it something I did or am doing wrong? Thanks in advance, Rune. Great
work. Now I'm going to make my own test files. My head is bubbling with
ideas. :)
Date: 26 Jan 2000 16:28:20
Message: <388f66f4@news.povray.org>
>second example file won't finish parsing, but
>      > <----ERROR
If you simply ran the sample file without having
changed anything, you couldn't have done anything wrong.
I don't know what causes the problem, and I can't
reproduce it myself. :-(
Which version and system of POV-Ray are you using?
(Though, I don't know what difference it should make.)
Have anybody else had the same problem?
>ideas. :)
Ok! I look forward to hearing more from you!
Greetings,
Rune
Date: 26 Jan 2000 22:32:55
Message: <388fbc67@news.povray.org>
Windows. I tried every version of POV that I have, from Official to Super to
UVPOV to MegaPOV, none of them worked. :( All reported the same error.
Date: 26 Jan 2000 23:00:25
Message: <388fc2d9@news.povray.org>
I was just making another test scene of my own and also ran into the
inconvenience I explained, so this is a serious problem, at least on my
machine, that impedes me from using your wonderful include file fully. I'll
post the example in .binaries.scene-files.
Date: 27 Jan 2000 17:08:20
Message: <3890c1d4@news.povray.org>
>own and also ran into the inconvenience I
>least on my machine,
I got the errors too when I ran your scene.
I have found the problem:
The lacking IKN documentation (my fault).
Here's an attempted explanation:
The neck is basically just a spline.
If the endpoints and forward vectors all
lie on the same one-dimensional line in
space, the INC doesn't know how to bend the
neck because it can only work within that
one-dimensional line. Am I making sense?
>#declare ikn_z2=z; // anything but z or -z works
Exactly. You can change ikn_z2 from z to z+0.1*x,
and the neck will work, though it will bend
in an unnatural way. Change it even more, and
it will look more natural, but then it isn't
anymore what you were trying to achieve in
the first place...
>include file fully.
I'm afraid you'll never be able to use to
"fully" then. There just are certain
limitations. Hope you can live with it :-)
I still don't know though, why one of the
sample scenes (nr. 2?) included in the IKN
package generates an error on your computer.
Keep the feedback coming! :-)
Greetings,
Rune
