I have a wonderful picture of bark that I'd like to use as a texture
in a scene... yet I couldn't find any way to do this. Is there any way
to make a JPEG a texture in POV-Ray (or any other picture format for
that matter)? If not, is there any other way that I could make a
semi-convincing bark texture?
-Thanks in advance!
> -Thanks in advance!
The official version of POV-Ray has no support for the jpg format. You
could however convert the jpg image into something lile a .tga image
file then use the image map pigment feature to apply your bark image
as a texture. I have had reasonable success using this method.
example -
image_map { tga "bark.tga" interpolate 2 }
Ken Tyler - 1300+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Wouldn't it be great if POV could at least read in JPEG?
["TonyB" <ben### [at] panama phoenix net>]
Well, libjpeg is fairly easy to interface so adding JPEG support
should be trivial, however: jpeg is lossy, and artifacts like that
can really disturb an otherwise good scene. JPEG should only be used
for the final image, not for textures.
Besides, you'd only save disk space, not ram, and disk is cheap.
A penny for your thoughts.
Mine are more expensive.
For those cases where you have an image in jpeg and no other form,
converting it to a non-lossy format like TGA doesn't restore what was
lost. So Ross' situation is one example of where it might be useful for
textures.
-Mark Gordon
Seeing as you have Win98, (english version, if that matters) you might also have
a viewer program called kodakimg. Start/Run... kodakimg and open the jpg
then File/Save as... Bmp for use in POV-Ray as a 'sys' file. I haven't done
anything with the sys type for a long time so maybe it's working well now
(sounds ominous, huh).
"Ross Taylor" <rta### [at] kear net> wrote in message
news:3878BC1B.3A912449@kear.net...
> -Thanks in advance!
> Bob
> > -Thanks in advance!
nah...
Just install Gimp and use that to convert stuff to PNG files. At least you get
compression as good or better than a .ZIPped BMP, plus it's cross-platform.
"My new computer's got the clocks, it rocks
But it was obsolete before I opened the box" - W.A.Y.
>textures.
Exactly my point. Most of the textures on the 'net are JPEG (AFAIK), so you
could just download them and use them directly, and programs like 3DS2POV
wouldn't have to convert the textures to other formats for you, making the
conversion faster and easier.
You have to covert from jpeg to a supported format like targa.
Then it works but is not a heightfield. I gather one needs magapov for
that.
> >textures.
Lets not run down jpeg without qualifications. Depending on the image and
how it was saved the loss might not be noticable.
In other words, don't throw away what might be useful until you have tried
it.
> > >textures.
> it.
Exactely my pointelly . or something.
Well, the new JPEG2000 standard look really promising, and also supports
lossless(!) compression. just a side point, I know, I know, but it would
still be a very nice thing to have that support in POV (output to jpeg
lossless, input from any jpeg) (no, I don't want lossy compression out
of POV, that would also increase the amount of beginner level questions
about why the image looks so bad (aso aso))
Well. there was a link in /. this month, didn't bookmark it though....
//Spider -- [ spider@bahnhof.se ]-[ http://darkmere.wanfear.com/ ]
And the devil in black dress watches over
My guardian angel walks away
Life is short and love is always over in the morning
Black wind come carry me far away
--"Sisters of Mercy" -- "Temple Of Love"
> > it.
The bad news is that in 1996 (95?) when I wrote my quick and dirty HTML guide I
mentioned that fractal compression was coming to browsers.
I'll believe it when I see it.
[On Wed, 12 Jan 2000 21:25:22 -0500, Matt Giwer <jul### [at] ij net>]
| HTML guide I mentioned that fractal compression was coming to browsers.
There's a big difference here. No successful fractal compression
algoithm exist. There surely is a great potential here, but no
algorithm for effectively turning an image into a set of fractal
functions.
JPEG2000 however uses well known algorithms, and an implementation
already exists. It's written in Java, so you could have
JPEG2000 images in your browser today.
http://ltswww.epfl.ch/~neximage/decoder/index.html
Yeah.. I was one of those who hooked to the .fif compression program
when it came, really impressive.. then I lost the writer/viewer (not
public thing) and ignored it, I know there was a plugin for NS 3.0 and
.fif, buit it never got much spread...
> functions.
There are.
Do a web search for the .fif format, Fractal Image Format I belive it
is. Graphic Workshop could/can read it, and it was great for photos, but
I've lost all references to it over the years.
>> functions.
>There are.
There is a shareware program, Fractal Imager, at http://www.iterated.com
that can encode and decode FIF format files.
Some drawbacks with fractal image compression are:
The algorithms are patented, and the owners of the patents are not
making them freely available. In particular, they've only made the
algorithms available on a small number of operating systems.
The time taken to encode a file is quite noticeable - as much as 68
seconds for an 800x600 image on my 500MHz machine, and probably quite a
bit longer on the machines that were commonly available on 1995.
Mike Williams + #
Gentleman of Leisure
Spider wrote:
I
I checked. It was 94.
> functions.
As I saw it, the problem was the decompression routine was free. The
compression routine was hardware only at about $300 or so. Out of my interest
and league for a one function card.
In fact a quick look says I have such a plugin on Netscape but I don't
remember ever coming across such a file -- nor do I remember ever installing
such a thing so it likely came with.
Most likely not. can't find a thing about it in the plugin
report on my machine. I also went to the Netscape Plugin
Finder page but found no reference.
Mr. Art
"Often the appearance of reality is more important
than the reality of the appearance."
Bill DeWitt 2000
[On Wed, 12 Jan 2000 23:00:14 +0000, Mike Williams <mik### [at] nospam please>]
On top of that, it doesn't do a much better job than good old jpeg,
and I suspect jpeg2000 would be superior.
> >> functions.
> >There are.
Ahh. I knew it was there somewhere.
I think I mentioned this in the other post, and I agree, it is a bad
thing. But there is such a thing as successful fractal compression :p
The lack of support(platforms), and the somewhat bothersome interface(at
least IMO back then) is also a drawback.
Yes... it was time consuming, but then I thought the quality was quite
remarkable, and filesizes in comparsion were quite small as well.
I ran it on a 486 DX2 - 66, as far as I can remember.. It was a mess..
but it ran :)
