POV-Ray : Newsgroups : povray.general : ANNOUNCE: Moray V3.2 Public Beta 1 Server Time
27 Oct 2026 05:12:14 EDT (-0400)
  ANNOUNCE: Moray V3.2 Public Beta 1 (Message 1 to 3 of 3)
Subject: ANNOUNCE: Moray V3.2 Public Beta 1
Date: 5 Jan 2000 10:55:32
Message: <3873686A.D3434A7A@pacbell.net>
Reposted from the Moray group on this server -
Hi all,
this is to announce that I have uploaded a beta version of Moray V3.2
(1.9MB). Get it from:
  ftp://ftp.stmuc.com/pub/moray/moray32pb1.exe
This is a public beta version of Moray for Windows V3.2 and is
time-limited until the 31st of January 2000. We will provide either
another beta or the full release before then, so you will never be
without a running version. Since this will be a free upgrade, you
don't need to worry about the costs, either<g>.
Note that this is an upgrade and can only be installed over an
existing installation. Note also that scene files saved with this beta
will not be readable by Moray V3.1 anymore, so there's no going back
with scene files that have been worked on with this beta.
Since this is a beta, please note that it is your responsibility to
save early, save often and make backups!.
While we're pretty sure that there are no serious bugs in this beta,
we cannot guarantee that it won't crash. We will do everything in our
power to correct any bugs that crop up in the beta phase and will
release timely updates, depending on how critical the found bugs are.
Please report bugs either by posting here (in the Moray group) or by
using the included SoloBug reporter.
Have fun!
- Lutz
  email : lut### [at] stmuccom
  Web  : http://www.stmuc.com/moray
Subject: Re: ANNOUNCE: Moray V3.2 Public Beta 1
Date: 5 Jan 2000 11:14:08
Message: <38756d8c.30508979@194.174.214.110>
Hi Ken, you recently wrote in povray.general:
Boy, you're quick. But then we knew that already<g>.
As an addition to aid you in deciding whether to download the beta:
What's New in Build 5235
This is a list of major new features that are included in
Moray V3.2 Beta (Build 5235). Please see REVISION.TXT for a
detailed list of all changes, including bug fixes.
- Added a Search Path Tab to the View|Configuration dialog that
  allows you to do maintenance your Search Paths without resorting
  to the Registry Editor. Only built-in Search Paths can be
  maintained, any file types that plugins define cannot be edited.
- Added a object creation Toolbar.
- Added a coordinate entry possibility to the sweep editors.
- Changes in the Material Editor and Material Library:
  - Added a Toolbar and improved the menu
  - The previews are now persistent
  - All previews can be rendered at once (Editor and Library)
  - Library contents can be viewed as thumbnails
  - Library contents can be multiply selected
- Made View|Dependencies display all files, whether they are in
  a Search Path or not. If you click on Ignore instead of Browse
  the file will be ignored (it is displayed grayed out).
- Added a "Create ZIP" function to the View|Dependencies dialog.
  It packs up all the files needed for the scene.
- Added Detail level for UDOs in Scene|Settings and in individual
  UDO objects. By default, UDOs use the global detail level set
  in Scene|Settings. You can override the global setting for an
  individual UDO on its Modify Tab. Also improved the loading
  speed of UDOs for those huge Rhino meshes.
- The spinning of the scene with the mouse in the 3D view when the
  camera is selected can now be done by right-dragging in the 3D
  view without needing to select the camera.
- Removed all Polyray output and support.
- Many Plugin SDK changes.
- Lutz
Date: 6 Jan 2000 06:15:54
Message: <38747979.12610F4@student.uni-siegen.de>
Hah! Got it. Now download it fast.....
Markus
