POV-Ray : Newsgroups : povray.general : texture Server Time
16 Oct 2026 23:56:52 EDT (-0400)
  texture (Message 1 to 20 of 20)
Subject: texture
Date: 2 Jan 2000 11:40:26
Message: <386F7F06.3D483E9A@t-online.de>
Hy,
I modelled a screw and now tried to get a good material but I wasn't
successful. It should look like the metal at www.lightflowtech.com
gallery picture 2. I think it should be possible with povray.
Can someone help me to adjust the different parameters ? Thanks a lot
Subject: Re: texture
Date: 2 Jan 2000 13:02:34
Message: <chrishuff_99-43251E.13023702012000@news.povray.org>
In article <386F7F06.3D483E9A@t-online.de>, Christof Schuler
<chr### [at] t-onlinede> wrote:
> Hy,
I fixed up a scene that is pretty close, although the metal texture
looks more plain(because of the lack of surroundings). I will post it in
povray.text.scene-files.
Chris Huff
e-mail: chr### [at] yahoocom
Date: 2 Jan 2000 17:41:35
Message: <386FD3AB.ED043CBB@t-online.de>
Thanks a lot,
but there is an error
 reflect_metallic <----ERROR
povray doesn't know this word.
Christof
Date: 2 Jan 2000 18:16:16
Message: <386fdc40@news.povray.org>
That's a new "patch" keyword when using MegaPOV custom version of POV-Ray.
http://nathan.kopp.com/download.htm
"Christof Schuler" <chr### [at] t-onlinede> wrote in message
news:386FD3AB.ED043CBB@t-online.de...
> Thanks a lot,
> Christof
Date: 2 Jan 2000 18:22:01
Message: <chrishuff_99-A1F884.18220302012000@news.povray.org>
In article <386FD3AB.ED043CBB@t-online.de>, Christof Schuler
Oops, that is an unofficial feature from MegaPOV. Sorry about that...
Just comment it out. In this case, the effect it gives is pretty subtle.
Chris Huff
Date: 3 Jan 2000 03:43:21
Message: <387060B4.C5A0900A@t-online.de>
Hy,
I rendered it with 1280x1024 aa0.3 (metallic_reflection comment out) but
-sorry- it was disappointing. Is the reason the missing MegaPov ? Do you
have perhaps a picture on a web-page ?
Thanks a lot
christof
Date: 3 Jan 2000 10:46:35
Message: <chrishuff_99-057DC0.10463903012000@news.povray.org>
In article <387060B4.C5A0900A@t-online.de>, Christof Schuler
> Hy,
Well, that is part of the problem, it looks slightly less realistic
without it. But the biggest problem is the lack of surroundings. The
image on the web site has some stuff around it, this only has the
checkered plane.
And it isn't an exact copy, it still needs some tweaking. The normal and
pigment need a little adjustment. It is just something to get you
started in the right direction...
Chris Huff
Date: 19 Feb 2000 09:55:45
Message: <38AEAF0D.CAB00F8E@t-online.de>
Hy,
it took some weeks, but I decided to download MegaPov 0.4 and succeded
in "installing". And really: it is much much better than PovRay allone.
Not as good as Lightflowpath, but I hope it will become as good as it in
the next version with MegaPov included.
Christof
Date: 19 Feb 2000 10:31:49
Message: <chrishuff_99-D9A293.10330519022000@news.povray.org>
In article <38AEAF0D.CAB00F8E@t-online.de>, Christof Schuler
What is it exactly about Lightflow that you like? I don't have Windows
and there doesn't seem to be a PPC Linux version, so I can't run
it(well, I could under SoftWindows, but...). I have looked at the web
page a little, and just don't see what is so nice about it...
If there is a specific function or feature that you like and which POV
lacks, it might get added in...
Chris Huff
Date: 19 Feb 2000 10:54:38
Message: <38aebcbe@news.povray.org>
The fast displacement mapping looks's nice.
Lance.
The Zone - http://come.to/the.zone
Date: 19 Feb 2000 12:38:58
Message: <chrishuff_99-D2A463.12401519022000@news.povray.org>
But is probably only possible due to the objects being tesselated to
triangles...
However, I think it would be a useful feature to have the isosurface
object optionally be reduced to a triangle mesh. You could even use a
mesh version of the isosurface to bound one with the original solving
methods...this might give the displacement features you want.(while the
isosurface object doesn't need to be reduced to triangles to allow
displacement, it might render faster that way)
Anything else?(other than network and multithreaded stuff...)
The only things I could find were NURBS and lens effects. And lens
effects could be written for the post_process feature for MegaPOV(some
things like blur are already included).
Where is some specific information on the texturing capabilities? All I
could find was something saying there were over 40 patterns and blurred
reflection/refraction...
Chris Huff
Date: 20 Feb 2000 10:12:34
Message: <38b00462@news.povray.org>
Chris Huff <chr### [at] yahoocom> wrote:
: However, I think it would be a useful feature to have the isosurface
: object optionally be reduced to a triangle mesh.
  You make it sound easy, but I think it isn't. How do you tesselate a
f(x,y,z) function?
Date: 20 Feb 2000 10:47:56
Message: <38b00cac@news.povray.org>
You can spatially find points which lie on the surface by using several
methods.  The easiest is the spatial grid (in which you sample in rows and
columns down through the object at set intervals - you can build a shell of
the object by then joining all the points).
There are other methods for producing more accurate and efficient results
but I don't know how hard they are to implement.  Most of them use a simple
point test on the f(x,y,z) to determine if the point is inside or outside
the object.
Lance.
Date: 20 Feb 2000 10:53:05
Message: <chrishuff_99-7DA628.10542220022000@news.povray.org>
In article <38b00462@news.povray.org>, Nieminen Juha
> f(x,y,z) function?
I think there is an algorithm called "marching cubes" which might be
sufficient. I believe it is commonly used in metaball
modellers/renderers which don't do render directly like POV does.
I don't actually know anything about this "marching cubes" algorithm,
but the name alone gives me some ideas...I don't think it would be an
easy feature to implement in POV though. Maybe in 4.0...
Chris Huff
Date: 20 Feb 2000 11:07:55
Message: <slrn8b04qg.1ko.ron.parker@linux.parkerr.fwi.com>
Unfortunately, last time I checked that algorithm was patented.
Date: 20 Feb 2000 11:24:44
Message: <38b0154c@news.povray.org>
Ron Parker <ron### [at] povrayorg> wrote:
: Unfortunately, last time I checked that algorithm was patented.
  IMHO those who invent some algorithm and immediately patent it are fools.
  For example, let's take the fractal image compression algorithm. The author
patented it immediately after finding it. What happened? How many fractal
compression programs have you seen or used? How many programs has fractal
compressed image support? Just a handful. How much has the algorithm been
developed? Not very much, as far as I know. How much money has the author
received from licenses? I would guess that not very much.
  Let's take a free image format like PNG. It's very popular (perhaps the
most popular format in the internet after JPG) and gaining more popularity
every day. Most modern image processing programs support it. It's becoming
a de-facto standard in many places. Would this have happened if PNG was
patented? Certainly not.
  GIF was patented and began to lose popularity very fast.
  Patenting an algorithm will just make sure that it will not become popular
and that it will not be developed much further. It will also not get you
lots of money.
  I don't want to offend americans, but I think that they are fools because
they allow patenting of algorithms (or almost anything else). It's like
patenting hot water or a fork.
  Here you can have the copyright of a program, but you can't patent it.
Date: 20 Feb 2000 11:37:59
Message: <38b01867@news.povray.org>
popular
> lots of money.
    The first part of this statement may be correct, but I bet the rest is
false. Private industry and government uses things that we just don't have
access to, and probably don't really need. But they make money for the
people who need them and use them. If there is a manufacturing process that
uses a particular algorithm, patenting that will prevent someone else from
using it to run you out of business. So what if it's not "popular"? Popular
doesn't bring home any bacon unless you can convert it into cash. "Useful"
is much easier to convert into cash and if you want to make money by being
the -most- "useful", you don't -give- away your secrets.
    Making something useful and giving it away is a good tactic if your goal
is to make a name for yourself and then cash in on that name by getting a
job doing something else. But it is not the -only- good tactic.
Date: 20 Feb 2000 19:41:26
Message: <38B08A38.AA7AFE9D@peak.edu.ee>
AFAIK the marching triangles algorithm isn't.
Margus
Date: 20 Feb 2000 19:50:48
Message: <38b08be8@news.povray.org>
because
Yea, and look what happened to 128-bit encryption... *sigh*
Australians can rest assured that our "secure" internet transactions are
running on wonderfully weak 40-bit encryption.  Somehow I don't feel very
safe.
Lance.
Date: 22 Feb 2000 14:58:16
Message: <38B2EA45.FB3115E5@t-online.de>
It sounds a bit childish: but the screw (the steel) on the web-page is
very good, I first asked me if it is a photo.
I want to make pictures with steel.
The other thing is: import of CAD-data (surfaces and volumes) via iges,
step, vda, sat,  ..., I know, this is very complex but you asked me ..
Christof
