What is the POV-Team going to do now that Watcom C++ is dying
Please don't go to MSVC++
See below for more info
http://techinfo.sybase.com/css/techinfo.nsf/DocId/ID=20510
Eerie. That announcment reads just like the Metecreations announcement
did. I guess that even though they are dropping support for the product
that does not mean that the POV-Team has to stop using it.
Wishing you Seasons Greetings, A Merry Christmas, and A Happy New Year !
Something weird goin' down
Yeah but what about the lack of updated code generation (speed of it &
optimisations on it etc. - seems a little disheartening (is that a word????
Pabs <pab### [at] hotmail com> wrote:
: What is the POV-Team going to do now that Watcom C++ is dying
: Please don't go to MSVC++
Actually the MSVC compile of povray seems to be faster than the watcom
compile.
Who cares which compiler is used as long as it makes faster code?
I will agree with that as long as you amend that to read "makes faster
and more reliable code".
Having said that -
Does a comiler make code or does it make a program out of code ?
Why is called code ?
Isn't "code" really just programming instructions ?
A compiler produces object code or "machine code"...
It just depends on your definition of code... pseudo code, C++ code,
assembly code... MATRIX code... hehe Code is used to describe a lot of
different stages.
The "machine code" refers to the object code, the "code for a program"
usually refers to the language specific text instructions.
The disassembly (not decompile) of "machine code" is simply a list of
processors words like move, put, get etc.
Code is used in lots of places to mean different things, so the point could
be argued forever.
Back to the original thread though, I welcome any change in compiler or
language as long as it produces a more efficient program.
Weren't the original plans to move to MSVC++ anyway? (please correct me if
I'm wrong, don't want to mislead anyone there)
Lance.
The Zone - http://come.to/the.zone
Ken <tyl### [at] pacbell net> wrote:
: Having said that -
: Does a comiler make code or does it make a program out of code ?
: Why is called code ?
: Isn't "code" really just programming instructions ?
Ok, I should have said "machine code" instead of just "code", but I thought
that it was enough to let it be implicit.
Machine code are the bytes that the CPU can directly interpret.
The plans are to move towards C++ but whether MSVC will be the development
environment is unknown to me.
Ken Tyler - 1200+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Ken wrote:
if
Thanks for clearing that up.
Lance.
Yes. A compiler makes code out of code. Hope I've cleared that up...
Using MSVC++ as a compiler won't make much of a difference in the
program itself. The problem, if there is one, would be if they switched over
to MFC (Microsoft Foundation Classes). That is the single largest bloater of
code in the universe.
I suspect that they will write straight to API though so that the code
can be compiled from source in any C++ compiler. That would make more sense
considering the history so far.
Given the emphasis on portability in all the C versions, I couldn't see
anything like that happening.
PoD.
What about Borland (Inprise ;-)) C++ compiler? No one mentions it. Is it not
of the same class as Watcom and MS?
Sander
Nieminen Juha <war### [at] punarastas cs tut fi> schreef in berichtnieuws
385e58f5@news.povray.org...
> compile.
No, it isn't. It's about twice as expensive and does not optimize
as good. Watcom has long been the compiler producing the fastest code,
no overtaken by MS.
Markus
Markus Becker wrote in message <3860EE66.F112F868@student.uni-siegen.de>...
not
>no overtaken by MS.
How does GCC compare for optimizing code?
Mark
As far as I know, they are about equal. (MS and GCC)
Markus
> Markus
One point on the PNG mailing lists came up with the non-optimizing VC++
and GCC. Someone compared some straight C code versus some
hand-optimized assembly language, and gcc on the straight code did a
better job than the hand-optimized assembly code under gcc or VC++. So,
for some things it might even beat VC++.
"My new computer's got the clocks, it rocks
But it was obsolete before I opened the box" - W.A.Y.
Jon A. Cruz <jon### [at] geocities com> wrote:
: gcc on the straight code did a
: better job than the hand-optimized assembly code
This only means that the person who made the assembly code didn't know
what he was doing.
You can always make the same and often better code than a program can.
It requires LOTS of knowledge about the cpu, though.
On Wed, 22 Dec 1999 16:29:42 +0100, Markus Becker
>no overtaken by MS.
Does anyone have any benchmarks on the Intel Performance Toolkit C++
compiler that comes with vTune? I have it here, and I've been
building 3.5 with it (note that that doesn't say anything about what
the final official version will be built with.) If nobody has
benchmarks, I might be persuaded to build an MS version and an Intel
version and compare, but I'd have to wait to do the tests because I
don't have a Pentium running Windows here at home (this box is a
K6/233.)
On 27 Dec 1999 05:10:49 -0500, Nieminen Juha
That's knowledge most mere mortals don't have when it comes to P5/P6
optimization.
Ron Parker <par### [at] fwi com> wrote:
:> You can always make the same and often better code than a program can.
:>It requires LOTS of knowledge about the cpu, though.
: That's knowledge most mere mortals don't have when it comes to P5/P6
: optimization.
You are terribly right.
A long time ago, in the age of 286's and even 386's the architecture of
the CPU was so simple that making a superduper-optimized asm code which
was at least twice as fast as any C code, was quite easy.
Nowadays, however, the CPU's have evolved to such an extent and they are
so extremely complicated, that the same tricks of the old asm coding do not
hold anymore. To beat a good C-compiler it would require so much knowledge
about the CPU (and often other hardware) that it's almost impossible for
the average asm-coder.
The compiler has two main advantages over a human coder: It will remember
everything taught to it and it will compile extremely fast.
Nowadays it doesn't make much sense to code in assembler for the big
computers. I have not written a line of asm in many years. A pitty, really.
Fortunately we still have the embedded systems...
The new complexity is also reason to pity the compiler writers!
-Mark Gordon
Pity or respect ?
Ken Tyler - 1300+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Ken wrote:
> Pity or respect ?
I respect them if they write good compilers. I pity them regardless.
-Mark Gordon
not
> no overtaken by MS.
Which version of the compiler are you referring to? Be careful, your
(Markus') above statement by itself is not objective and comes close to
being merely flame-bait. Which version of the compiler are you referring to?
Did you do an apples-to-apples comparison yourself?
I test compiled povray 3.0 a while back using Borland C++ 4.5 (IIRC) and it
*was* slightly slower than the normal binary downloaded from povray.org. I
would be interested to see the results of a comparison using the Borland
C++Builder 4.0 compiler compared with binaries produced by other compilers.
I am writing a flight dynamics model for the open source flight simulator
called FlightGear (www.flightgear.org). My C++ source code is compilable
under the CygWin compiler (egcs 2.91-xx), all Borland compilers, gcc under
Linux, cc under IRIX, and - with some hacks - under MSVC++ 6.0 (which does
not #define M_PI in its headers like every other header file set does).
Compliance to standards is important to me, and MS skirts the edge - and
sometimes steps over the edge - in my experience.
You are right when saying that Borland is not in the same class as Watcom
and MS. For my needs, they are way above the rest of the crowd. They may not
have a compiler which produces the fastest *povray* executable, but until I
see a fair comparison using the latest versions of all compilers tested,
statements like yours claiming poor optimization and slow binaries will be
taken with a grain of salt (no offense meant).
jb
I was comparing Borland C++-Builder 4 with MSVC++ 6 and Watcom 11.b
all (at that time) the latest.
When it comes to interface design and how good the class library is,
definitely yes. But I like the MS-IDE better.
Markus
