I just ran into something strange. While trying to
pass a color vector through a macro, the color changed!
The code is simple
#include "Colors.inc" #include "finish.inc"
#declare CapColor=<1,0,0,0,0>;
#macro Cap(Color)
difference
union {
cylinder{<0,0,0>,<0,.0889,0>,.17}
cylinder{<0,.0889,0>,<0,.1333,0>,.2}
cylinder{0,y*.0667,.12 translate y*.1333}
pigment{ rgbft Color} //Will promote to a 5 component vector
camera { location <0,5,-5> look_at 0 angle 40 }
light_source { 0,White translate -z*40 rotate <30,-10,0> }
background { White}
object { Cap(CapColor) }
If I #declare CapColor= a three or four component vector, it works fine.
But as a five component vector something doesn't work so well.
Can anyone give some insight on this?
It certainly looks like a bug. I don't know of any way of printing the
values of the vector when it has five components so I can't see what's
happening. There seems to be no way to access the 5th component of a vector
and #write doesn't work for 5-dimensional vectors for some strange reason.
5-dimensional vectors are obviously handled differently from 4 or less
dimensinal vectors, and perhaps the bug is related to that.
In article <383e7611@news.povray.org> , Nieminen Juha
No, you can just treat it as a color:
#macro Cap(Color)
difference
union {
#warning "Vector <"
#warning str(Color.red,0,3)
#warning ", "
#warning str(Color.green,0,3)
#warning ", "
#warning str(Color.blue,0,3)
#warning ", "
#warning str(Color.filter,0,3)
#warning ", "
#warning str(Color.transmit,0,3)
#warning "> "
light_source { 0,rgb 0 translate -z*40 rotate <30,-10,0> }
background { rgb 0}
Thorsten
e-mail: tho### [at] trf de
In article <383E7213.7DF63B99@gci.net> , "mr.art" <mr.### [at] gci net> wrote:
I can't reproduce it. My output is as expected (see my other post). Which
version of POV-Ray are you using?
Thorsten
I have used the Official version 3.1g, the Superpatch, and UVPOV 6.1a
All with the same results.
Printing the vector information like you suggested in your other
post gave these results vector<0.000,1.875,0.000,0.000,0.000>
for the color vector <1.000,0.000,0.000,0.000,0.000>
I am using Win98, PII 400,128meg Ram
> Thorsten
Here is more data to ponder:
#declare CapColor=<1,1,0,0>; outside the macro becomes <1,1,0,0> inside
But
#declare CapColor=<1,1,0,0,0>; becomes <0,1.875,0,1.875,0> inside
> Thorsten
Try this for simplest code :
// #declare CapColor= <1,0,0,0,0>;
#declare CapColor= color <1,0,0,0,0>;
#warning "Vector <" #warning str(CapColor.red ,0,4)
#warning ", " #warning str(CapColor.green ,0,4)
#warning ", " #warning str(CapColor.blue ,0,4)
#warning ", " #warning str(CapColor.filter ,0,4)
#warning ", " #warning str(CapColor.transmit,0,4)
#warning "> "
sphere{0,0 pigment{color 0}}// keeps the error messages away
uncomment one or the other of the #declare statements.
#declare CapColor= color <1,0,0,0,0>; gives correct results
#declare CapColor= <1,0,0,0,0>; doesn't
So the problem seems to be not in the #macro stuff at all
but in the assignment process.
> But
In article <383EDDEB.174731B4@gci.net> , "mr.art" <mr.### [at] gci net> wrote:
Yes, I can now verify your problem. It is a bug in the source code. A
detailed bug report has been posted to povray.bugreports.
Thorsten
Thorsten Froehlich
e-mail: mac### [at] povray org
I am a member of the POV-Ray Team.
Thank you. I know that the easy workaround
is to use the keyword color in front of the vector.
But if someone had tried to 5d vectors for another
use, it could mess them up some. So, once again,
thank you.
Mr. Art
> Thorsten
> Thorsten Froehlich
On Fri, 26 Nov 1999 15:40:53 -0600, "Thorsten Froehlich"
Thank you for posting the fix, Thorsten.
Alan - ako### [at] povray org - a k o n g <at> p o v r a y <dot> o r g
> The code is simple
[snip]
fine.
I think that second-last sentence is the clue: you don't actually want a
5-component vector, you want a colour. Therefore, if you declare your
CapColor as a colour variable, eg: #declare CapColor = rgbft <1, 0, 0,
0, 0>; you should find that everything works as expected.
the
vector
reason.
less
If the variable you want to pass is declared as a colour then everything
behaves as expected. Taking into account other seemingly 'strange'
behaviour (eg. what happens when you specify checker colours without
commas, or try certain colour arithmetic) I don't think I'd classify
this as a bug. Declaring a variable as a colour (using the color
prefix, or rgbft, etc.) also allows you to correctly access the filter
and transmit components using dot notation (although colours are not
supported by the #write function).
Does this mean that when povray expects a vector and it finds a 5-dimensional
one, it promotes it to a 4-dimensional vector?
Well,
#declare Test=<0,0,0,0,0>;
#declare Test=<0,0,0,0>;
generates: error: Attempted to redefine colour identifier as 4d-vector
identifier.
But,
#declare TestPig=pigment{rgb Test}
generates no error. My assumption is it discards what it doesn't need.
In article <3842979b@news.povray.org> , Nieminen Juha
5-dimensional
No, it tries to use memcpy to convert an array of doubles to an array of
floats ... look at the report posted in povray.bugreports and the source of
this strange error will be obvious. Fortunately it doesn't copy more bytes,
but less!
Thorsten
In article <3842ACC3.D70701F8@gci.net> , "mr.art" <mr.### [at] gci net> wrote:
Nope, the error is very obsure from a non-programmer perspective.
In short it copies only some parts of the vector.
Thorsten
