I have been putting a perspective grid in my scene that floats just clear of
the floor.
I use it as a visual measuring tool in the final image.
Currently I have used a grid composed of small cylinders but find that the
processing time is substantial and I am looking for an alternate idea.
Has anybody made a similar grid?
> the floor.
You might try a crossing gradient on a very thin box instead.
Something untested like this:
box { -1,1
pigment { gradient x
color_map {
[.45 rgbf 1][.45 rgb 1][.55 rgb 1][.55 rgbf 1]
scale .1
finish { ambient 1 diffuse 0 }
pigment { gradient z
color_map {
scale .1
finish { ambient 1.5 diffuse 0 }
scale <20,.1,20>
Ken Tyler - 1200+ Povray, Graphics, 3D Rendering, and Raytracing Links:
> the floor.
I haven't, but if I were to do one, I'd use a plane with a gradient
layered texture, like:
gradient x
pigment_map {
[ 0.9 color rgbf 0 transmit 1 ]
[ 0.9 color Blue ]
gradient z
color_map {
[ 0.9 color Blue ]
Jerome
* Always listen to experts, * Jérôme M. BERGER
* they'll tell you what can't * mailto:ber### [at] iname com
* be done and why... * http://www.enst.fr/~jberger
* Then do it. *
I would recommend a thin box instead of a plane because the bounding is more
efficient and they render faster.
You're right, but then I would use a very *thick* hollow box instead
(btw the plane should be hollow too). It should be thick enough so that
the bottom edge is below everything in the scene. A thin box would
increase the trace level (and therefore the render time) a lot...
Jerome
* Then do it. *
On Tue, 09 Nov 1999 12:24:15 -0800, "Jerome M. BERGER"
> Jerome
Not if the thickness is 0, like box { <-1000,0,-1000>, <1000,0,1000> }
which, though odd, is perfectly legal.
Peter Popov
ICQ: 15002700
> > Jerome
Thanks Peter, I was just going to bring that up. It basicaly will make a box
with a thickness the same as a triangle or a disk object.
I didn't know you could do that... Doesn't it raise coincident surface
problems, though? Or does POV handle it in a specific way?
Jerome
* Then do it. *
> Jerome
It handles it just like a triangle with no problems with coincident surfaces.
Renders much faster than a plane does too. Try it you'll like it :)
Actually it was you who taught me this, so thank you too :)
Peter Popov
ICQ: 15002700
> > Jerome
Still has to be hollow it seems, I've just run a test and it loks like
the "other side" of the box is "inside" no matter what your point of
view is...
Here are the results of my test renders of a simple scene:
with fog without fog
0.0001 units box 113s 70s
1000 units box 64s 46s
0 units box 62s 44s
plane 59s 40s
Note that since I didn't specify "hollow", the 0.0001 units box is the
only one which showed the fog properly. Other than that, all four
solutions were identical visually.
I don't know how POV handles boxes and planes internally, but if I were
to make a raytracer and optimize boxes and planes as far as I can, the
planes should be faster (and neither would be bounded, I mean what's the
point of bounding a box when it's already the faster finite shape you
can compute?).
These results were obtained with uvpov6.1 but I don't think official
POV would make much of a difference.
Jerome
* Then do it. *
