POV-Ray : Newsgroups : povray.general : Lost macro request Server Time
6 Nov 2026 21:46:06 EST (-0500)
  Lost macro request (Message 1 to 15 of 15)
Subject: Lost macro request
Date: 8 Nov 1999 12:40:23
Message: <38270b07@news.povray.org>
I can't find my copy of the macro that placed your name in front of the
camera. Has anyone got a copy they can e-mail me? And who made it?
Subject: Re: Lost macro request
Date: 8 Nov 1999 13:00:46
Message: <38270F57.9F4A5247@pacbell.net>
I don't recall such a macro but there is a utility that will imprint an
image with your name at:
http://www.public.usit.net/lsellers/raytracing.html
Ken Tyler -  1200+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Date: 8 Nov 1999 13:00:59
Message: <38270FBF.83DF8D3F@gci.net>
I think that I got my copy from ????
I know that I made adjustments and then
sent it back to him and the ng's but his name
escapes me. I will dig my copy off the HD and
email you.
Mr. Art
Date: 8 Nov 1999 13:36:52
Message: <38271844@news.povray.org>
Thanks! That was it. I am going to merge it with a couple of other things
and make an include that will fully document my images and animations. I
will post it when (if) I ever get it done.
mr.art <mr.### [at] gcinet> wrote in message news:38270FBF.83DF8D3F@gci.net...
> email you.
> Mr. Art
Subject: Another Lost macro request
Date: 8 Nov 1999 17:58:57
Message: <382755b1@news.povray.org>
OK, another one. I found the macro to get the time using the #fopen
directive, but I can't find the gettime.bat that it uses. Almost certainly
lost with the hard drive.
It was a batch file to write to a file called gottime.txt I wrote a batch
file to pipe the "time" command to that file but it doesn't seem to write it
correctly. I get a type mismatch error, probably because of the minus signs
in the text string.
Subject: Re: Another Lost macro request
Date: 8 Nov 1999 18:02:49
Message: <38275699@news.povray.org>
I meant to say the minus signs in the "date" command...
...maybe there isn't a way around that.
Bill DeWitt <the### [at] earthlinknet> wrote in message
news:382755b1@news.povray.org...
it
signs
> in the text string.
Date: 8 Nov 1999 18:16:51
Message: <382759e3@news.povray.org>
>name escapes me. I will dig my copy off
>the HD and email you.
>Mr. Art
Lets see...
I originally made it as an include file.
Then you (Mr. Art) made it into a macro.
Bill, if you want to make it back into
an include file I can send you the
original include file if you are
interested.
What exactly will your include file be
doing?
Greetings,
Rune
Updated October 17: http://rsj.mobilixnet.dk
Containing 3D images, stereograms, tutorials,
The POV Desktop Theme, 350+ raytracing jokes,
miscellaneous other things, and a lot of fun!
Date: 8 Nov 1999 18:31:37
Message: <38275d59@news.povray.org>
> interested.
Well, I already rewrote it but I would like to see your original if you
don't mind.
> doing?
I want to Stamp date, time, frame #, file name and copyright information in
small text at the bottom of each frame or image. I am setting up a stack of
.ini files and batch files and .inc files to do this. Any suggestions would
be appreciated.
Date: 8 Nov 1999 18:44:26
Message: <3827605a@news.povray.org>
I have that. Here 'tis:
@echo off
echo " > gottime.txt
echo | more | time | find "Current" >> gottime.txt
echo "; >> gottime.txt
c:\progra~1\pov-ra~1.1\bin\pvengine.exe /render
c:\progra~1\pov-ra~1.1\scenes\gettime.pov
exit
Save as Gettime.bat
news:38275699@news.povray.org...
certainly
batch
write
> it
> signs
> > in the text string.
Date: 9 Nov 1999 00:01:34
Message: <3827aaae@news.povray.org>
I forgot the quotes, it works great now.
Next question, is there anyway to get the name of the file that is being
parsed and #declare it as a text string to be read in that file? So that I
can lable my images with the file name without having to type it in
everytime I render an incremented file name?
Uh, more importantly, is there a fix for the Help file? Mine is almost
unusable as it is...
omniVERSE <inv### [at] aolcom> wrote in message
news:3827605a@news.povray.org...
> @echo off
> exit
> Save as Gettime.bat
> Bob
> certainly
> batch
> write
> > it
> > signs
> > > in the text string.
Date: 9 Nov 1999 09:13:04
Message: <38282bf0@news.povray.org>
You could certainly put it in the same file you're putting the time in.
If you make it an argument to the batch file, you can output it to the
file and run the script without having to type it twice, e.g.:
@echo off
echo " >> gottime.txt
echo %1 >>gottime.txt
echo "; >>gottime.txt
c:\progra~1\pov-ra~1.1\bin\pvengine.exe /render %1
exit
The original version of this batch file doesn't work on NT, by the
way, so I haven't been able to test it.
These are my opinions.  I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
Date: 9 Nov 1999 11:16:47
Message: <382848ef@news.povray.org>
Thanks, that's what I've been doing, using the "%s" string substitution. I
was hoping there was a more direct way.
Ron Parker <ron### [at] povrayorg> wrote in message
news:38282bf0@news.povray.org...
I
> @echo off
> exit
Date: 11 Nov 1999 16:12:41
Message: <382B309F.93A67035@my-dejanews.com>
Sorry, but what the heck is this?
_________________
greg, an ignorant non-command-line pov'er.
> @echo off
> exit
> Save as Gettime.bat
> Bob
> certainly
> batch
> write
> > it
> > signs
> > > in the text string.
Date: 11 Nov 1999 17:07:40
Message: <382B3E2A.340A0343@earthlink.net>
	It is a dos batch file to copy the system time to a text file so that I
can read it with povray and use it in the scene.
Date: 11 Nov 1999 20:51:19
Message: <382b7297@news.povray.org>
Thanks for answering Greg, Bill.  Yep, indeed, a simple DOS command-line
batch file is all.  The other part needed is the gettime.pov, or contents
thereof, and I've also made a INI to go with to make it all work as
intended.
I'll upload the zip of these three files to p.b.s-f group shortly, since the
original was meant for running from DOS and these allow to run from POV.
news:382B3E2A.340A0343@earthlink.net...
