On Sun, 7 Nov 1999 22:05:09 -0500, TonyB wrote:
>#declare FrameNumber = clock/clock_delta;
Assuming your clock starts at zero and the first frame is numbered
zero, this is correct. The more general formula is
#declare Initial_Clock=(whatever is in your INI file);
#declare Initial_Frame=(whatever is in your INI file);
#declare FrameNumber = (clock-Initial_Clock)/clock_delta + Initial_Frame;
These are my opinions. I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
Nathan has added an ini_option command to set an ini option from the pov
code.
How about a reverse operation, ie. functions that return some values set
in the ini file (or wherever)? This way you could type:
#declare Initial_Clock = initial_clock();
or something like that.
