POV-Ray : Newsgroups : povray.general : Bug in Bezier-spline prisms? Server Time
11 Sep 2025 19:25:31 EDT (-0400)
  Bug in Bezier-spline prisms? (Message 1 to 3 of 3)
Subject: Bug in Bezier-spline prisms?
Date: 4 Nov 1999 15:55:32
Message: <3821f2c4@news.povray.org>
I'm not sure if this is a bug, or an undocumented feature, or if I'm
merely doing something wrong, but when I attempt to create subprisms
within a prism made of Bezier splines, I receive the message:
   warning: Prism not closed. Ignoring it.
However, each of the subprisms appears to be correct; I can comment out
bits and render each subprism separately, and the result is what I
expect it to look like.  But when I put them together again, they still
fail to work.
Here's a small example file, showing one linear_spline prism and one
bezier_spline prism, each with an outer and inner subprism.  The former
prism works exactly as the documentation says it should.  The latter
does not.
Any ideas on what I'm doing wrong, or can Bezier-spline prisms simply
not contain subprisms?
//------------------------------ Cut here ------------------------------
#declare LinearPrism = prism { linear_spline linear_sweep 0, 5, 10,
  <0,10>, <10,0>, <0,-10>, <-10,0>, <0,10>,  // outer prism
  <0, 5>, < 5,0>, <0, -5>, < -5,0>, <0, 5>   // inner prism
  pigment { colour rgb <1,1,0> }
#declare BezierPrism = prism { bezier_spline linear_sweep 0, 5, 32,
  <  0, 10>, < 10, 10>, < 0, 0>, < 10,  0>,
  < 10,  0>, < 10,-10>, < 0, 0>, <  0,-10>,
  <  0,-10>, <-10,-10>, < 0, 0>, <-10,  0>,
  <-10,  0>, <-10, 10>, < 0, 0>, <  0, 10>,  // outer prism
  <  0,  5>, <  0,  0>, < 5, 5>, <  5,  0>,
  <  5,  0>, <  0,  0>, < 5,-5>, <  0, -5>,
  <  0, -5>, <  0,  0>, <-5,-5>, < -5,  0>,
  < -5,  0>, <  0,  0>, <-5, 5>, <  0,  5>   // inner prism
  pigment { colour rgb <0,1,1> }
object { LinearPrism translate x*-11 }
object { BezierPrism translate x* 11 }
camera { location <0,30,-30> look_at <0,2.5,0> }
light_source { <-10000,10000,-10000> colour rgb <1,1,1> }
plane { y, 0 pigment { colour rgb <1,1,1> }}
Jeff Lee         shi### [at] gatenet         http://www.gate.net/~shipbrk/
Subject: Re: Bug in Bezier-spline prisms?
Date: 4 Nov 1999 16:39:23
Message: <3821fd0b@news.povray.org>
No consolation but I too know of this happening, I think I must have tried
every way possible I knew how to remedy it and failed. Hope a POV-Ray sage
has some wisdom to share about it.
Jeff Lee <shi### [at] gatenet> wrote in message
news:3821f2c4@news.povray.org...
> fail to work.
> does not.
> file://------------------------------ Cut
Date: 5 Nov 1999 00:03:21
Message: <38226519@news.povray.org>
It's a bug.  The bezier spline prism code verifies that the end point
of each spline is the same as the start point of the next spline, and
that the last point is the same as the first.  This is fine for simple
prisms, as you discovered, but it breaks for subprisms.  Either that
or you're not supposed to be able to use subprisms with bezier splines,
but I find that difficult to believe.  (If so, it's a doc bug.)
Here's how to fix it:  The loop needs to be rewritten first, so as to
remove the hokey one-size-fits-all method of checking the end against
the start.  After that we need to remember what point we started at
and check that point against any seeming discontinuities and at the
end of the array.  If we see what looks like a discontinuity, but it
matches the starting point we saved, save the starting point of the
new loop and start checking again.
remainder of original message follows for the benefit
of those reading this in .bugreports for the first time.
>fail to work.
>does not.
These are my opinions.  I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
