POV-Ray : Newsgroups : povray.general : Camera in union? Server Time
27 Oct 2026 08:35:13 EDT (-0400)
  Camera in union? (Message 1 to 17 of 17)
Subject: Camera in union?
Date: 30 Oct 1999 17:25:59
Message: <381B623D.F2F721CF@gci.net>
Is it possible to include a camera statement in a union?
I want to place the camera in the head of a figure, but
POV gives an error for this.
I am using POVray 3.1g for Windows.
Subject: Re: Camera in union?
Date: 31 Oct 1999 02:28:32
Message: <381befa0@news.povray.org>
Don't think so.  'camera' can be declared though only for inclusion into
another 'camera' statement.  I have tried in CSG before like you and got
that error.
mr.art <mr.### [at] gcinet> wrote in message news:381B623D.F2F721CF@gci.net...
Subject: SV: Camera in union?
Date: 31 Oct 1999 08:58:25
Message: <381c4b01@news.povray.org>
Don't think so.. it doesn't work out...
You could #declare the head locations in something like this (don't know if
it correctly written, haven't tested it out)
#declare Location = <0,5,0>;
camera{
location {Location}
look_at {Loaction+z*2}      (is this right?)
sphere{Location ,1 pigment {White}
I think you can make something similar with a rotate statement.
Date: 31 Oct 1999 11:06:03
Message: <381C68C7.24B1F1DB@gci.net>
Thanks for the replies. I had had hopes.
Maybe it could be a project for a patch
someday.
Date: 2 Nov 1999 17:48:09
Message: <381f6a29@news.povray.org>
I don't think it is possible.
I would #declare a transformation, and apply it to
both the camera and the object:
// start of code
#declare Transformation =
transform {[scale, rotate and translate here...]}
   [camera settings here]
   transform Transformation
object {transform Transformation}
// end of code
Greetings,
Rune
Updated October 17: http://rsj.mobilixnet.dk
Containing 3D images, stereograms, tutorials,
The POV Desktop Theme, 350+ raytracing jokes,
miscellaneous other things, and a lot of fun!
Date: 3 Nov 1999 11:25:15
Message: <382061B8.102F1907@gci.net>
Thanks for all the info. The process
of keeping track of the location of one object
in a union of moving parts that can itself be
positioned most anywhere needs a function
or something. I mean, the render engine has that
info anyway, why not #declare PosHead = vlocation(Head,0)
for the location and #declare NormHead =vlocation(Head,1)
for the normal info for the Head?
Personally, I think being able to "mount" a camera on an object
and letting it get moved as the object gets moved is the best option.
Date: 3 Nov 1999 11:54:31
Message: <382068c7@news.povray.org>
There can be difficulties in how the 'sky' vector gets applied I think.  Say
the camera is on a Ferris Wheel that also turns around the y axis too, if
the camera doesn't rotate along with it (stays aligned to the ground plane
for instance, as if seated in real ride) then nothing is apt to go wrong. If
it follows the Ferris Wheel path as though afixed to it then it might flip
from one orientation to the next.
I'm not sure of the associated problems but I have seen what appears to need
consideration as far as the sky vector goes.
mr.art <mr.### [at] gcinet> wrote in message news:382061B8.102F1907@gci.net...
Date: 3 Nov 1999 13:59:40
Message: <slrn8210q0.v8.ron.parker@ron.gwmicro.com>
Because the render engine doesn't actually have that information,
perhaps?  For example, if you uniformly scale, translate, and
rotate a sphere it will just modify the radius and the center
and will keep the transform set to the identity.
Okay, maybe it can have that information in some cases if it assumes the
initial "position" (whatever that means) of the object was zero and the
initial "orientation" was Y, but designing objects that way is just a
guideline, not a requirement.
In short, such a function would be impractical and fragile.
These are my opinions.  I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
Date: 3 Nov 1999 15:49:19
Message: <3820A06C.D0051EB@yahoo.com>
However, the ability to "attach" a point to the object, and have the
point be automatically transformed with the object, would be nice. Of
course, it would require that the object be #declare'd or #local'd.
#declare Head =
OBJECT {
    blahblah
    #attach Center = < 0, 1, 0>;
#transform Head, TRANSFORM;
#declare HeadCenter = Head.Center;
or
camera {location Head.Center look_at < 0, 0, 0> angle 35}
Notice the #attach command, which would attach a point to the object,
and the #transform command, which would transform an object without
redefining it. #declare would make a new object, with it's own
#attach'ed variables, and the variables would be initialized to the
original, so #declare could be used to do the same thing without this
addition.
If this is done, perhaps #attach should be #attach_point, which would
attach a transformable point to the object, and #attach would just
attach a variable of any type to the object. This could lead to some
interesting data structures, maybe there should be a void {} object type
which would just be a container for attached variables.
Alternatives for #attach that I can think of:
#link and #link_point
#bind and #bind_point
Any suggestions? Perhaps I will attempt to implement this, it shouldn't
be *that* hard.
Hmm, perhaps this should be in a thread of it's own...
Date: 3 Nov 1999 23:33:16
Message: <38210C5D.C6D21668@gci.net>
If I tried something like
#declare Head =
union    {
object{Nose translate -x*.5}
object{Ear translate <0,.2,-.45>}
object{Ear translate <0,.2,+.45>}
object{Eyes translate +y*.2}
rotate <0,45,20>
translate +y*3
I would expect that all parts would stay together.
And if I tried something like
camera{location 0 look_at -x rotate <0,45,20> translate +y*3}
I would expect that the camera would point to where
I had wanted it. I know from experience that you can even
scale a camera. It only effects location. The size of a camera is
not effected.
So why not put the camera on an object in a union?
Then I could do this
#declare VideoHead =
union{
object{Head}
camera{location 0 look_at -x translate -x*.51}
Anything that I could do that would then change the
position and/or scale of object{VideoHead} would
also change the camera location.
All these things POV does for every object.
And for the camera. I thought it natural that
the camera, as an object, could be included in
a union{}.
Date: 4 Nov 1999 06:04:25
Message: <382168D5.D7681D30@yahoo.com>
>I thought it natural that the camera, as an object, could be included
in a union{}.<
Well, the camera is not an object. Not really, somewhat like the
sky_sphere. You can do some of the same things to it, but that doesn't
make it an object. You can only have one of them, bounding and clipping
are useless, various other things.
Perhaps it should be an object, but then what do you do with multiple
cameras? Give each camera a name attribute, and specify the camera in
global_settings? It does seem a little inconsistant that the camera
isn't an object, but light sources are.
Date: 4 Nov 1999 08:26:41
Message: <slrn8232c1.v8.ron.parker@ron.gwmicro.com>
>a union{}.
You're right, I don't see any reason why it couldn't be, other than
because that's the way it is.  I was commenting on the "POV knows the
transform for every object" assertion, not on the (imho good) idea of
letting cameras be inside unions.
Date: 4 Nov 1999 09:40:45
Message: <38219aed@news.povray.org>
Ron Parker <ron### [at] povrayorg> wrote:
: You're right, I don't see any reason why it couldn't be, other than
: because that's the way it is.  I was commenting on the "POV knows the
: transform for every object" assertion, not on the (imho good) idea of
: letting cameras be inside unions.
  Thanx to this thread I found something that might be considered a bug.
  It started from the thought that if camera would be allowed to be in a
union, then it could be in any CSG. So what does this mean:
difference { camera { ... } sphere { 0,1 } }
  Then I thought: But hey! You can put a light source in a union. What
happens if you put it in a difference?
  I tried it and povray output this:
warning: Patch objects not allowed in intersection.
  Patch object?
Date: 4 Nov 1999 09:45:30
Message: <slrn82370a.v8.ron.parker@ron.gwmicro.com>
>  Patch object?
in point.h:
#define LIGHT_OBJECT (COMPOUND_OBJECT+PATCH_OBJECT+LIGHT_SOURCE_OBJECT)
The term "patch object" is probably a bit misleading, but I can't come
up with a better phrase off the top of my head.
Date: 4 Nov 1999 09:57:20
Message: <38219EAF.3B44079D@gci.net>
POV handles camera, as best as I can tell, by using the
last one encountered. The others are discarded in favor
of the last. I ran into that one a few years back and now
use an "active scene workspace" as a work around. Only
the camera that is in the scene that I am using is the last
one encountered.
> in a union{}.<
Date: 8 Mar 2017 13:55:00
Message: <web.58c0530e7524ba2b05bf450@news.povray.org>
Camera in a union would be handy in case you want to move the camera and all the
lights at the same time.
Mike
Date: 8 Mar 2017 15:05:00
Message: <web.58c062c67524ba2c437ac910@news.povray.org>
> Mike
Define camera location and look_at variables, and then define the camera and
everything else based on that one variable.
You can even define that variable right there at the beginning of your union{}
statement.  Then translating the union would move everything just like you want.
