POV-Ray : Newsgroups : povray.general : MetaCreations Painter 3D Server Time
27 Oct 2026 08:37:19 EDT (-0400)
  MetaCreations Painter 3D (Message 1 to 19 of 19)
Subject: MetaCreations Painter 3D
Date: 28 Oct 1999 02:53:16
Message: <3817f2dc@news.povray.org>
Hello all!
MetaCreations apparently used to make a program called "Painter 3D" which is
a program for painting on 3-D models.  They don't really mention it much on
their web site so I suppose it is discontinued, but I found it being
liquidated at www.ubid.com and picked up a copy last week.  So far I have
successfully been able to take an object (well, a torus, heh) generated by
the Rhino eval, import it into Painter 3D, paint on it, and render the
result in UVPOV after converting the file.  It's kind of a convoluted
process and the program is a bit clumsy and also a bit slow, but it has tons
of tools and I just thought that some people here might find it a useful
addition to their toolset.  I got it for $22 and they seem to put more
copies up for auction every few days.  That's pretty cheap for what the
program has in it.  There are some copies available again for auction today,
current bid is $17.  It might even be usable as a decent 2D paint program.
Just a heads up on what I thought was a pretty good deal.  Oh, I have no
connection to ubid or metacreations and do not stand to benefit from this in
any way (except maybe if somebody else gets the program we can talk about it
here).
Subject: Re: MetaCreations Painter 3D
Date: 28 Oct 1999 16:23:11
Message: <3818B3BF.CBD214DD@netscape.net>
How does this program "paint?"  Is each face colored a single color, or can
paint the object as if it were real, and you had a spraycan in your hand?
Dan
Derek Zahn wrote:
> Hello all!
> here).
Date: 28 Oct 1999 17:06:29
Message: <3818bad5@news.povray.org>
There are two ways to paint on the object:  you can either paint directly in
a 3d preview window or by painting into an image map.  Either way you are
really just painting onto the image map... the image map has a type which is
planar or cylindrical or spherical or cubic or "UV".  It is just a bitmap
whose resolution you can configure to be whatever you want.  The faces of
the mesh are pretty much irrelevant to the pixels of the image map, although
you can turn on a grid which will show them as mapped in "uv" space... this
looks rather freaky, though.
Using the "draw directly on 3d object" mode, it would be pretty easy, for
example, to add makeup to a poser face (I don't have poser but I believe it
would be easy).
"paint the object as if it were real, and you had a spraycan in your hand"
describes pretty accurately what they were shooting for.
derek
Dan <evg### [at] netscapenet> wrote in message
news:3818B3BF.CBD214DD@netscape.net...
can
> Dan
> Derek Zahn wrote:
> > Hello all!
which is
on
have
by
tons
today,
program.
this in
about it
> > here).
Date: 29 Oct 1999 09:29:25
Message: <3819a135@news.povray.org>
Derek Zahn <der### [at] uswestnet> wrote in message
news:3818bad5@news.povray.org...
<snip>
it
> would be easy).
<snip>
I received this e-mail with this link from metacreations group
(Karen_Nilsen). I only use
Bryce once in a while, but it is always good to know about other products'
features.
>Please consider adding this tutorial to your site.  It shows how to use
>Painter, Bryce and Poser together.
http://www.metacreations.com/community/tips/thequeen/index.html
Marjorie Graterol
**Digital Art Synthesis**
http://www.emediez.com
Date: 29 Oct 1999 21:56:49
Message: <381a5061@news.povray.org>
Marjorie Graterol wrote in message <3819a135@news.povray.org>...
The tutorial is interesting, but it uses the paint program as a
post-processing step to color sections of the rendered image, which is kind
of frowned on here (and by me too I think).  The Painter 3d program I was
talking about is not a post-processing tool, although it is a version of
Painter and has the usual Painter tools.
derek
Date: 30 Oct 1999 03:01:26
Message: <381a97c6@news.povray.org>
Anyone know about Canoma? http://www.metacreations.com/products/canoma/
I just happened across it while net surfing.  Talk about a way to cheat at
3D modeling and texturing!
news:381a5061@news.povray.org...
kind
> derek
Date: 30 Oct 1999 04:06:53
Message: <381aa71d@news.povray.org>
omniVERSE <inv### [at] aolcom> wrote in message
news:381a97c6@news.povray.org...
    I've seen somehting like it before but it had a free version your could
keep. I lost it with everything else but I will try to find it again. Maybe
Ken has a link to it? If I could remember the name....
Date: 30 Oct 1999 04:17:25
Message: <381AA95C.789A6E14@pacbell.net>
If only I could read Bill's mind, mind, mind...
How about: http://home.pb.net/%7Estevecox/uvmapper.htm
UVMapper
 Have you ever said to yourself "I'd love to use this Wavefront model I found
 on the web, but it doesn't have a texture map, and without a program like
 Detailer or Painter I can't figure out how to color it?"  Well if you have,
 then UVMapper is the program for you.
 Features:
 * UVMapper is a Windows 95 (or better) texture map template creation
   utility.
 * There is now a PowerMac version available!
 * It will import/export Wavefront (obj) files and output 256 color Windows
   bitmap (bmp) files.
 * The user may specify the dimensions of the bitmap file from 1 x 1 pixels
   up to 8192 x 8192 pixels.
 * Create fully UV mapped primitives completely to your specification.
 * Preview the texture map template before exporting it to a bitmap file.
 * Apply texture maps to any OBJ model, even if it has no texture coordinate data.
   This program is freeware.  You have the right to use it for personal or
   commercial purposes. You do not have the right to redistribute it without
   written permission from the author, or to modify it in any way.
Ken Tyler -  1100+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Date: 30 Oct 1999 05:49:32
Message: <381abf2c@news.povray.org>
http://www.photomodeler.com/Lite
This is a freeware version of PhotoModeler that can be used to plot out
points onto multiple photos or drawings and create 3D models.  Might be what
you were thinking of.
I got the demo of Canoma to check it out, not sure how to use it but it
seems to lack abitlity to plot each point out manually and instead has
predefined shapes you place into the picture.  Maybe there's another way but
I didn't see any other.
Bill DeWitt <the### [at] earthlinknet> wrote in message
news:381aa71d@news.povray.org...
could
Maybe
Date: 30 Oct 1999 09:28:08
Message: <381af268@news.povray.org>
That's the one! I keep meaning to take some carefully posed digital photos
and see if it works...
news:381abf2c@news.povray.org...
what
but
> Bob
> could
> Maybe
Date: 30 Oct 1999 09:49:28
Message: <381af768@news.povray.org>
what
    I mean to say that I believe that thisis the way that some recent
commercials have done their effect. I forget the advertiser (which is a
comment on today's advertizing methods) but the effect was that two young
lovers meet in a plaze or something and time stands still. The camera
rotates around them -while they are still moving- but the rest of the
action, the falling leaves, the people in the background, are all frozen in
time. Quite cool and without detailed photogrammery I cannot think of a way
to do it.
    Big problem with this is that I don't believe that it exports to POV, if
I recall, if you want a POV file you have to send them your model and they
will export it for you... then they keep the model... I am downloading it
again and will comment further.
Date: 30 Oct 1999 10:47:22
Message: <381B0536.F73A37DB@geocities.com>
> what
> to do it.
That one's done a little differently. They have a series of high-speed
still-frame cameras that get triggered sequentially at a very high rate. This
was also used for the "bullet-time" in the Matrix. By having the cameras placed
in a cemi-circle around the subjects and firing them all at the same time, you
have that one moment recorded from all angles, and can then play them back.
http://www.whatisthematrix.com/cmp/sfx-bullet_frames.html
"My new computer's got the clocks, it rocks
But it was obsolete before I opened the box" - W.A.Y.
Date: 30 Oct 1999 12:08:55
Message: <381b1817@news.povray.org>
I think we are not talking about the same thing. The Matrix thing was done
with blue screen and a motionless (if I recall properly) background with a
few rendered bullet tracks. The commercial I am talking about froze a moving
background (leaves and birds in the air) then did a 360 around it's
circumference. If there had been cameras in the shot they were hidden quite
well. The trick was to show a 360 sweep around a background all in one
instance. Much different than doing a 360 on one object.
The Matrix things had a completely different look. I think the couple in the
commercial were blue screen and were set into a partially rendered setting,
but I could be wrong... I'll look into it.
Jon A. Cruz <jon### [at] geocitiescom> wrote in message
news:381B0536.F73A37DB@geocities.com...
out
be
> > what
young
in
way
> > to do it.
This
placed
you
back.
Date: 30 Oct 1999 15:12:27
Message: <381b431b@news.povray.org>
Well, at least I know the commercial you're talking about.  I would have
said the same thing as Jon A. C., stop-motion camera system type thing.  So
what you're saying is the few photographs needed to then make models of all
the stuff, (birds and leaves and water fountain) could have then been
computer generated to forego any existing cameras for the initial picture
creation.  Been awhile since I saw it but anythings possible I suppose.
news:381b1817@news.povray.org...
moving
quite
the
setting,
> out
> be
> > > what
a
> young
frozen
> in
a
> way
> > > to do it.
> This
> placed
time,
> you
> back.
Date: 30 Oct 1999 16:15:40
Message: <381b51ec@news.povray.org>
news:381b431b@news.povray.org...
Really! Can you remember -who- it was an ad for???
Date: 30 Oct 1999 22:01:05
Message: <381BA2FC.FE47EBF3@netscape.net>
The Gap?  They did one to the tune of "Jump, Jive, and Wail."  It was
quite well done.
Date: 31 Oct 1999 01:17:15
Message: <381BDF22.B1D2F086@geocities.com>
Yes. I think I know that commercial. That was one of the first big ones that
the specific effects company did. Same technology. The Matrix stuff just added
the green screen. The commercial had dove or pigeons, or whatever all over.
I remember reading about it in Millimeter before all the Matrix stuff.
Ahh. Found some of it.
http://www.virtualcamera.com/mm1.html
Could this be the commercial you were thinking of?
http://www.virtualcamera.com/images/discoverframe.jpg
http://www.virtualcamera.com/discover.html
> ...Shot in London, in this spot we
> used the 80 lens curved camera to
> create a 360 degree move around
> a couple kissing as the seasons
> changed around them...
Date: 31 Oct 1999 02:33:41
Message: <381bf0d5@news.povray.org>
Not at all.
news:381b51ec@news.povray.org...
Date: 31 Oct 1999 09:14:30
Message: <381c4ec6@news.povray.org>
Great! This seem to be it!
    Clearly my memory of it was a little lacking, but then I haven't seen it
since I tried to figure it out. I have to wait for a few things (still
fixing my computer) before I can even install the QuickTime to view the
samples with...
news:381BDF22.B1D2F086@geocities.com...
done
a
moving
quite
the
setting,
that
added
over.
