POV-Ray : Newsgroups : povray.general : Columns Server Time
6 Nov 2026 21:53:52 EST (-0500)
  Columns (Message 1 to 13 of 13)
Subject: Columns
Date: 23 Oct 1999 20:03:16
Message: <38124B92.8293582A@global2000.net>
What are good methods of making columns?  I tried blobs and unions of
spheres and cylinders to make the grooves in a column but they didn't
work as well as I thought they would.
Brendan Ryan
Subject: Re: Columns
Date: 23 Oct 1999 20:13:23
Message: <38124FAF.2F0D0344@yahoo.com>
If the sides are straight(no curve, just a uniform diameter or a linear
taper) then you could use a prism object.
Another thing you could do is use CSG with a while loop to make the
grooves.
Date: 23 Oct 1999 20:26:45
Message: <38125113.E010B185@global2000.net>
I tried using a while loop with CSG but it said something like 'at least 2
objects should be in CSG'.
Brendan Ryan
> grooves.
Date: 23 Oct 1999 20:41:45
Message: <38125539.AE5602C5@pacbell.net>
> Brendan Ryan
Colonnes.inc
http://www.iro.umontreal.ca/~pigeon/pub/PovPage/PovPage.html
Column.inc
http://www.no13.net/
Ken Tyler -  1100+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Date: 23 Oct 1999 21:21:55
Message: <38125E01.345C811E@global2000.net>
Thanks. I was looking for a doric column.
Brendan Ryan
> > Brendan Ryan
> Colonnes.inc
> Column.inc
Date: 23 Oct 1999 22:22:29
Message: <38126DF0.C0ABD51F@yahoo.com>
Sounds like a sign your loop isn't looping. Try something like this:
#macro Column(colHeight, colRadius, colRidges)
    difference {
        cylinder {<0,0,0>, <0,colHeight,0>, colRadius}
        #local k=0;//the loop counter
        #while(k<colRidges)
            cylinder {<0,-0.1,0>, <0,colHeight + 0.1,0>,
(colRadius*pi)/colRidges
                translate x*colRadius rotate k*y*(360/colRidges)
            #local k=k+1;
Rounding off the sharp edges will take a bit more work, but it shouldn't
be too hard. I will work on that. This is how the macro is used:
object {Column(1, 1, 17)
    pigment {color White}
Date: 24 Oct 1999 03:34:44
Message: <abASOAkzGgCEs41uBQHPhcFtLPpF@4ax.com>
On Sat, 23 Oct 1999 21:25:42 -0500, Chris Huff
If you use a blob with negative components to cut out the rooves
you'll spare yourself the trouble of heavy trig calcs to smooth those
edges out, methinks.
Peter Popov
ICQ: 15002700
Date: 24 Oct 1999 09:21:32
Message: <38130869.9B7150@yahoo.com>
edges out, methinks.<
But that takes out all of the fun! :-)
Good idea, I will include that option in the macro. Or probably make a
separate macro, because this will probably need several parameters that
nothing else will use.
Date: 24 Oct 1999 20:43:55
Message: <3813A685.B16A6771@global2000.net>
Would the main body of the column have to be a blob for this method to be
used?
Brendan Ryan
> Peter Popov
> ICQ: 15002700
Date: 24 Oct 1999 22:05:38
Message: <3813baf2@news.povray.org>
Think so, if I follow this thread right.  Use a cylinder {-y,y,1
scale<whatever>} for the column, then other cylinders circling it with
negative strength.  Watch out for the Insert menu when using it to start off
a 'blob', apparently wrong with radius and strength switched.  Compare to
the Scene help Doc.
Andrea Ryan <ary### [at] global2000net> wrote in message
news:3813A685.B16A6771@global2000.net...
> used?
> Brendan Ryan
shouldn't
> > Peter Popov
> > ICQ: 15002700
Date: 24 Oct 1999 22:11:44
Message: <3813BB23.2B0A7CBE@global2000.net>
I'm using blobs and unions of spheres and cylinders to makes the grooves
but when the number of grooves get high, they get smaller and shallower.
When the number of grooves is high enough, they disappear.
Brendan Ryan
Date: 24 Oct 1999 22:14:08
Message: <3813BBBB.6CC95672@global2000.net>
I'm not using negative strength right now.
Brendan Ryan
> Brendan Ryan
Date: 27 Oct 1999 15:58:20
Message: <38175816.658B7A4D@global2000.net>
I might critique your tutorial but where can I find it?
Brendan Ryan
> > Brendan Ryan
> You could also try my DMesh program. It makes column type objects fairly
> well - you can add all the grooves and bumps you want, as well as other
> dents or imperfections. You could also add some 'vines' snaking around
> it if you had the inclination. You could even bend or curve it around a
> bit if you got real ambitious.
> One of the tutorials I'm working on covers exactly this topic - Columns,
> birdbaths and other similiar objects. I could certainly send you the
> preliminary models and info as a starting point.
> The program actually has a bit of a learning curve at the moment, but I
> *finally* got back to it after a little unexpected 4-week ...delay... so
> things are picking up on the more 'user-friendly' version. On the other
> hand, my email window is alway open, and sounds like you'd be an
> excellent person to 'critique' the tutorial if you were interested.
> Bruce Lamming
> Home of DMesh - Distortion Based Mesh Generation
> http://www.geocities.com/SoHo/Studios/4500/
