POV-Ray : Newsgroups : povray.general : Any way to avoid repeated parsing? Server Time
27 Oct 2026 11:47:03 EDT (-0400)
  Any way to avoid repeated parsing? (Message 1 to 50 of 52)
Goto Latest 50 Messages Next 2 Messages >>>
Subject: Any way to avoid repeated parsing?
Date: 16 Sep 1999 14:24:52
Message: <37e135f4@news.povray.org>
Is it necessary for POV-Ray to parse a file separately for each view of the
same scene?  Is there any way to "save" the result of the parsing to use in
repeated raytracings from different views?
Thanks in advance for any help with this.
-John VanZwieten
Subject: Re: Any way to avoid repeated parsing?
Date: 16 Sep 1999 15:09:40
Message: <37e14074@news.povray.org>
Hmmm, to view other camera angles reparsing is needed because of the
change in rays going to/from objects.  Their profiles are always going
to be different, well that's my guess anyhow.  Parsing was improved as
I recall for multiple frames or renders of the same scene but think
you're talking about keeping a memory map of sorts which considers any
and all changes to camera position.  Of course if a scenes objects,
etc. change with time then the question is probably moot.
John VanZwieten <Joh### [at] emailmsncom> wrote in message
news:37e135f4@news.povray.org...
of the
use in
> -John VanZwieten
Date: 16 Sep 1999 15:19:54
Message: <37e142da@news.povray.org>
Bob Hughes <inv### [at] aolcom> wrote in message
news:37e14074@news.povray.org...
So parsing is view angle-dependent, rather than just scene-dependent.
My situation is a "fly through" where the camera location/angle change but the
scenes objects do not.
Thanks for the info,
-John VanZwieten
Date: 16 Sep 1999 15:24:24
Message: <37e143e8@news.povray.org>
I'm not totally inner workings savy, but yes, from what I understand
the visible scene is calculated so the other stuff can be dropped out.
That makes for a change in parse I believe even when just viewpoint
changes.
news:37e142da@news.povray.org...
the
going
scene-dependent.
think
any
objects,
change but the
> -John VanZwieten
Date: 16 Sep 1999 15:27:20
Message: <37e14498@news.povray.org>
>changes.
Nope.  But vista buffers are view-angle dependent.  Still, there's not
currently any way to save the results of the parse.  My understanding
is that it wouldn't save as much time as it might seem anyway.
Date: 16 Sep 1999 15:34:52
Message: <37E1465A.55670386@uni-paderborn.de>
> -John VanZwieten
There is no simple way how to do this.
POV-Ray is an offline program which reads
its input, computes a pretty output and
terminates. There is an animation loop,
but it is based on reparsing the scene.
I noticed some debates on a binary format
(this is probably what you mean) but it
was never implemented (binary triangle
meshes are the only exception). Anyway,
a binary format would not lead to a
significant parsing speedup.
You asked for "any way". OK, there is a
way how to do a camera animation without
reparsing the scene. This requires some
programming. You have to write a program
which mimicks POV-Ray but keeps running
unless told to terminate. Such an
interactive POV-Ray must have an option
to parse a new file after rendering a
frame, without destroying the original
scene which is still in memory. The new
file will contain just the new camera.
That's it.
	y.
Date: 16 Sep 1999 15:35:47
Message: <37e14693@news.povray.org>
Ron Parker <par### [at] fwicom> wrote in message news:37e14498@news.povray.org...
> >changes.
Why not?  Parsing on a scene I'm working with takes >1.5 hours.
-John Van
Date: 16 Sep 1999 15:50:22
Message: <37e149fe@news.povray.org>
>> >changes.
The reason that was given the last time this came up was that profiling
shows that most of the time parsing is actually spent allocating and
shuffling memory around.  Of course this isn't true for all scenes, but
that's what "they" said.
Now that I have access to a copy of vTune for Windows, maybe I'll find
a big scene to parse and see for myself.
Date: 16 Sep 1999 16:42:29
Message: <37e15635@news.povray.org>
In article <37e149fe@news.povray.org> , par### [at] fwicom (Ron Parker) wrote:
You can try pyramid.pov in the sample scenes. Just increase the recursion
level if you need a scene taking even longer to parse.
    Thorsten
Date: 16 Sep 1999 16:46:53
Message: <37e1573d@news.povray.org>
But what when you render exactly the same scene at a different resolution?
Then it seems a pity that you have to render again.....
Sander
Bob Hughes <inv### [at] aolcom> schreef in berichtnieuws
37e143e8@news.povray.org...
> changes.
> Bob
Date: 16 Sep 1999 19:03:16
Message: <37e17734@news.povray.org>
You might notice that renders (and parses) tend to be quicker when run
the second time.  This of course might be OS platform dependant and
such, don't know.  Possibly it's only because of memory use
effieciency of the OS and nothing to do with POV-Ray itself.
Sander <san### [at] the-internet> wrote in message
news:37e1573d@news.povray.org...
resolution?
> Sander
understand
out.
viewpoint
> > changes.
> > Bob
Date: 16 Sep 1999 23:26:47
Message: <37e1b4f7@news.povray.org>
But skipping the parsing step would also remove the need for all of this
memory shuffling.  Once you've got a scene parsed and allocated in memory,
it would be nice to render scenes of an animation by simply changing what's
already in memory instead of destroying it all and rebuilding it for each
frame.
And, while it wouldn't make much difference for scenes with lots of glass or
media, it could be a noticable speed improvement for other scenes, such as
ones with lots of triangles or ones built using extreme recursion (which POV
is slow at parsing).
And, granted, all those light buffers, vista buffers, and the like would
have to be re-computed each time, but I still think it is something that
would benefit POV.
-Nathan
Date: 16 Sep 1999 23:42:31
Message: <37e4b8a5.258366537@news.povray.org>
On Thu, 16 Sep 1999 23:27:41 -0400, "Nathan Kopp" <Nat### [at] Koppcom>
>frame.
I agree, in the animation case.  I've long thought about how to modify
POV so it only parses the static parts of a scene once.  It would
definitely be nice if you could somehow say "The whole scene is
static, so only reparse the camera definition for each frame."
Of course, even that would be difficult to achieve if you're using any
kind of complex camera motion, such as Colefax's splines.
Date: 17 Sep 1999 03:13:21
Message: <37e1ea11@news.povray.org>
Bob Hughes <inv### [at] aolcom> wrote:
: I'm not totally inner workings savy, but yes, from what I understand
: the visible scene is calculated so the other stuff can be dropped out.
  You can't do that. You have no way to know if an object will be visible
through reflection/refraction (other than actually raytracing the scene).
If an object was not hit by any ray in the previous frame, you have no way
to know if it will be hit or not in the current frame.
  Automatically declaring objects as "static" depending on whether the clock
value affects them or not is a mathematically impossible problem (AFAIK).
You can always write a program which is not analytically solvable.
Numerical solving would be at least as slow as the actual parsing of the
scene, so no benefits would be achieved.
  You can only be sure that an object is not affected by the clock value
when it doesn't use any identifier which has been "touched" by 'clock'
(or other identifiers which have been "touched", etc). The same thing for
'clock_delta'.
  This is not enought, though. An object may depend on the clock value even
if it doesn't use any identifier. For example:
  #if(clock<.5) sphere { 0,1 pigment { rgb 1 } } #end
  But even this is not enough. The object may depend on the contents of an
external file (which is #read during parsing and which may change from
frame to frame).
Date: 17 Sep 1999 04:43:37
Message: <37E1FD31.61D49939@aol.com>
That sounds feasable to me, provided that special case is made.  You know how
POV-Ray allows one atmospheric media?  Maybe you could allow one static {}
block...
I guess the problem is when does POV release the stuff that is in
memory...unless you went so far as to add a keyword to tell it to do so.  Like
#if (clock = 100) clear_memory
Seems to me that things could get messy though.  Until recently there were all
those global variables that weren't getting cleared (I wouldn't doubt there are
still some).  Now that I think about, that kinda' shows how it could be done -
since POV in the windows version is running from the time you start it, then if
the parsed scene wasn't freed it would be used the next time you
render...assuming you didn't try writing stuff to the same areas in memory.
I really don't know enough about how it manages memory or parses or...just about
everything, so I guess I'm not one to talk.
-Mike
Date: 17 Sep 1999 09:05:09
Message: <37E23C71.53E6027@numerik.uni-kiel.de>
> -John VanZwieten
Hi there,
my default insertion here, like some folks always say 'visit my links
page' I use to say the following:
I object to the statement that POV-Ray is slow in parsing. All that POV
is doing, is saying that it parsed some 1.5h, but most of the time it
did run your code.
It just doesn't tell you
'your $%*&ing codes runtime: 1.49Hrs
parsing time: 60 sec'
What do we have? By the grace of the POV-Ray Team we have one and only
one interface to the rendering engine, and thats the Scene Description
Language.
Like that name says, it's a language defined to describe a scene. It's
not designed to do heavy numerics or business-transactions.
Throughout it's history (which I experienced not so much of) it has been
extended by more and more programming constructs, giving the users more
and more possibilities. Thanx, guys.
But that stuff doesn't only have to be coded, but it has to be paid for.
And that's simply speed.
Short: the parser is fine, the interpreter is slow. That's fine, I do
prefer a good renderer to yet another interpreter.
Could someone speed it up? No, because there are way too many backdoors,
like pre- and postframe shellouts and #read, so one rarely knows, what
content changed at what time.
So, if you want to stick to portable and simple coding for the users,
you stick to the speed.
More speed would require a serious breaking of compatibility, and in my
opinion, another interface to the engine. POVLegal won't like it, and
most probably the POV-Ray Team won't code it.
(I think of something like a DOM-based CORBA interface)
A short remark on the binary format. It was implemented, but provided
the heterogeneous tree structure of the scene in memory, you have a lot
of work putting all those pointers back into place, and most objects
will be created one by one, so not that much of speedup to expect.
Axel
Date: 17 Sep 1999 09:35:32
Message: <37e243a4@news.povray.org>
>'clock_delta'.
clock_delta is a constant for a given animation sequence, isn't it?
This can still be detected, of course.  Anything that's inside an #if
block or a #while block that is dependent on clock is automatically
dependent on clock.
>frame to frame).
e.g. by using a preframe shellout, or by writing it during the parse of the
current frame.  And let's not forget #include files that are generated
automatically by either of those methods.
Obviously such scenes couldn't be rendered with "smart reparsing."  It would
have to be an option, and probably not a default option.  Alternatively, you
could have a way to explicitly mark objects as being fixed from frame to frame,
and anything that isn't so marked is automatically reparsed.  This wouldn't
even take too much change to the parser.
Date: 17 Sep 1999 10:07:34
Message: <37E24B1F.D6FE18F1@uni-paderborn.de>
> >frame.
I know about at least one such implementation (my own).
During a research project I implemented a parallel version
of POV-Ray (I call it POV||Ray) which used an incremental
parsing concept (see my note Xref: news.povray.org
povray.general:14892). My version went never public as the
implementation was somewhat experimental, based on some not
well supported components, some of the original POV-Ray
functionality would not be preserved, etc. (For instance,
animations based on a #clock variable would not work at all.)
Parsing was a tricky part of the implementation and I spent
some time on it. For a camera animation, the parsing times
dropped from 15 minutes to cca 3 seconds or less.
POV-Ray is not dependent on a particular interactive modeler,
therefore there is the pre- and post- processing overhead
that can be avoided if a raytracer is used within an
integrated environment. The right way lies perhaps in between
these two extremes.
My idea was/is making POV-Ray *persistent*. ;-)
I mean a termination upon request only. There could be an
interface which allows changing the scene which persists,
incremental adding of new objects, etc. The interface
could even be the same as up to now - an (incremental)
.pov file.
Not necessarily. However, I am afraid that some of the
backward compatibility would have to be given up (so if
you mean this, you are right). Many already existing tools
would thus become outdated (those which have something to
do with animations). But maybe even not.
A #clock variable would not be used by a preprocessor
anymore, at least not the way it is used now. However,
it could be used for generating an incremental .pov file
(or a script file or whatever the interface looks like).
Unless... unless there is a true 4D extension made to
POV-Ray. (Some extensions, like adding IDs to
objects/textures will be needed anyway.)
> block...
I do not know how POV-Ray allows one atmospheric media,
but I think I know what you mean. It's probably the same
as in the case of camera, right?
This can be done.
Yes, I mean something like this. With one objection -
the solution should not be bound to windows.
I know something about it. Feel free to ask me (a direct
msg or CC, please - I don't read news very regularly).
A final (useless) remark: If you (I guess you guys are
members of the POV-Team) decide to go the way I sketch
here, make a clear concept before making any quick
and dirty optimizations. As Mike said, things could get
messy...
	Tom
Date: 17 Sep 1999 10:39:46
Message: <37e252b2@news.povray.org>
>messy...
No, this thread is purely speculative and purely unofficial.  Even if
some of us are members of the POV-Team, we're speaking completely
unofficially here.  But I agree with your sentiment anyway; even an
unofficial patch should be well-thought-out ahead of time.
Date: 18 Sep 1999 01:05:54
Message: <37e31db2@news.povray.org>
Nieminen Juha wrote in message <37e1ea11@news.povray.org>...
clock
>'clock_delta'.
>frame to frame).
Add a 'static' object modifier to the language that can be applied to
anything, for example:
sphere{<0,0,0>, 1 pigment{ rgb 1} static}
 POV-Ray will not reparse any object that contains that modifier after the
first frame of an animation.  If you apply it to an object that does get
changed over the course of an animation, that's your problem, not POV's.
Mark
Date: 19 Sep 1999 04:49:49
Message: <37e4a3ad@news.povray.org>
Mark Wagner <mar### [at] gtenet> wrote:
: Add a 'static' object modifier to the language that can be applied to
: anything, for example:
: sphere{<0,0,0>, 1 pigment{ rgb 1} static}
:  POV-Ray will not reparse any object that contains that modifier after the
: first frame of an animation.  If you apply it to an object that does get
: changed over the course of an animation, that's your problem, not POV's.
  I think this is not enough either. Povray will have to parse the entire
file anyways if there's some non-static objects (for example at the end of
the file). One solution to this is, of course, to keep a copy of the scene
in memory with all static objects removed.
  There's another problem: If all objects generated in a #while-loop are
static, that loop doesn't need to be parsed but just once. But how do you
tell this to povray?
Date: 19 Sep 1999 17:32:57
Message: <37E557AB.D1CC1582@merlin.net.au>
how about a static block i.e.
static{
easy to skip in parsing and can contain anything.
Of course the scene coder has to be extra careful what's put in there.
Cheers, PoD.
Date: 19 Sep 1999 22:02:23
Message: <37e59626.511717648@news.povray.org>
>static{
I prefer the syntax
#static
because block syntax is currently restricted to actual entities, and
#-directives are used for procedural and flow-control things.
Date: 20 Sep 1999 05:38:35
Message: <37e6009b@news.povray.org>
Ron Parker <par### [at] fwicom> wrote:
: #static
: #end
  Not bad. This way you could specify anything as static, not just objects.
Date: 20 Sep 1999 18:27:41
Message: <37E6B604.EE361FE9@merlin.net.au>
> >static{
> I prefer the syntax
> #static
> #end
Err. yeah given how the rest of the syntax works, you're right, I've
just never liked that syntax.
The main point is the same though, if this is not the first parsing of
the file then traet this block as a comment.
Cheers, PoD.
Date: 21 Sep 1999 05:12:34
Message: <37E74BF0.2982877B@uni-paderborn.de>
> >static{
> I prefer the syntax
> #static
> #end
Well, if such a thing were really to be implemented, then
I would suggest #endstatic instead of just #end.
Using #end as a common construct terminator could lead to
nesting problems, especially if several such contructs
are needed in the future.
The current #if, #while, #ifdef, etc directives are safe
about using a common #end terminator as there is a simple
nesting rule. However, this simplicity could be violated
when adding new constructs like this. Using special
constructs for specials is perhaps better than using
special semantics for specials. (Wow, what a sentence.)
	y.
Date: 21 Sep 1999 11:26:52
Message: <slrn7uf8ts.v8.parkerr@ron.gwmicro.com>
But #static is just a fancy way of saying "#if (this_is_the_first_parse)",
so it nests perfectly with other #ifs.  It has to, because otherwise you'll
hit an unmatched #end or an unmatched #if the second time you parse the file.
Unless you're thinking about something horrible like this
#static
  #if (0)
#endstatic
   object {wristband}
#static
#endstatic
to make the mat object only appear in frames after the first one. (does that
make it an antistatic mat?)  But that's a horrible, horrible corruption of
the purpose of #static (and wouldn't scale to multiple processors working on
the same animation.)
Date: 21 Sep 1999 12:24:47
Message: <37E7B148.A2343E4@uni-paderborn.de>
> #static
>   #if (0)
> #endstatic
>    object {wristband}
> #static
>   #end
> #endstatic
Now I can't think of a better example...
Uhm. Never mind, I have a more conceptual question:
How do you define an object which is defined in the
second frame (or 51th frame if you want) and does
not change (persists) till the end of the animation?
I think you cannot. (Nor can I.) In other words,
#static will not allow you to insert any static objects
in any other frame except of the first one. Right?
	y.
Date: 21 Sep 1999 12:39:05
Message: <37e7b4a9@news.povray.org>
Right.  Presumably you could extend it to #static (start,end)
which would mean the contents of the block are static for clock
values between start and end.
Date: 21 Sep 1999 13:50:26
Message: <37E7C55B.1081F62A@uni-paderborn.de>
That's it. Then why not having simply #if (start, end)?
Let the POV-Ray decide what persists and for how long.
This would also save one keyword. However, when nesting
#if with #if(start, end), one could get in troubles. To
avoid this, you have to carefully restrict usage of
#if(start, end).
Note that the above arguments apply to #static(start,end),
too.
	y.
Date: 21 Sep 1999 14:56:15
Message: <37e7d4cf@news.povray.org>
I'm not sure I like this syntax.  For one thing, it's too easy to
mistype a less-than as a comma.  For another, it doesn't convey
the correct idea.  #if (start, end) seems to imply that it's
shorthand for #if (start < clock & clock < end) when in fact it's
another concept entirely: everything inside the #static block
would be parsed for any frame where the clock is outside the
prescribed limits, and it would be parsed at most once per
rendering session with a clock value somewhere inside the limits.
And keywords are fairly cheap.
>#if(start, end).
The only problems I see with nesting would be something like
#if (clock > .5 )
  #static (.3,.6)
or
#static (.3,.6)
  #if (clock > .5 )
and both of these are clearly misuses of the static qualifier:
the things being declared static are not in fact static over
the declared range, and the user deserves whatever he or she
gets. :)
Date: 21 Sep 1999 17:22:08
Message: <37E7F6FA.A831C395@uni-paderborn.de>
The syntax itself is not so important. But you are
completely right. :-) I would bet that you mistyped
the comma when writing that message, didn't you?
Not exactly. Actually, I was thinking about
#if(start,end) as about the shorthand for
#if (start < clock & clock < end). But it's
not *only* a shorthand. A special #if syntax
would also tell the parser to skip the parsing
if the clock value is outside the limits. This
is something what the parser cannot do when it
sees #if (start < clock & clock < end).
Anyway, you are right. The special #if syntax
does not suggest that the parser will try to
skip the block for a frame outside the limit.
There may be a nested #if inside the block
which does not get parsed, although it should.
Wait a moment... (looking into tokenize.c,
Parse_Directive, Skip_Tokens, Get_Token).
Interesting... I'm lazy to study the code now,
but I would say that all directives, even those
in a FALSE branch of an #if get parsed! Is it
really so? Is it really needed? If it is not
needed, then I would reconsider binding the
"time limited static feature" to objects,
textures, etc.
(I think that somebody here already suggested
the same, but this debate had not been so far
yet that time.)
Damned. I think that we both are overlooking
one important detail. We are discussing the
language. But we should also consider what
should happen with the objects in memory. When
is an object/texture/etc supposed to be released?
The original idea was to keep static objects
in memory throughout the whole animation. But
if an object should durate just for the time
specified in #static(start,end), then the
situation is much more complicated. (The clock
function is not necessarily monotone. During an
animation, an object/texture/etc. can be
sometimes there and sometimes not.)
Howgh.
I know. However, extending syntax is usually
better than adding a new keyword. In this
particular case it is not possible.
When speaking about extended syntax, I would
have a suggestion for the POV-Team which makes
the POV language more robust. Why should one be
able to say "ambient rgb<0.1,0.2,0.8>" in a
texture but couldn't say the same for diffuse?!
(This is not just an aesthetical comment, it
really helps sometimes, e.g. when converting
materials from other formats to .pov.)
This is my wish list:
- diffuse in a texture is now a float. It could
be defined for rgb channels separately.
- phong, ditto.
- specular, ditto.
- if there is something I forgot, ditto.
The texture finish memory storage will grow a
little. However, I do not see a reason for having
incredibly many textures in a scene. (I may be
wrong.)
The changes involve extending the parser (in parstxtr.c
replacing Parse_Float with Parse_Colour will usually
do), redefining the types in frame.h, and rewriting a
few routines. I can help by pointing to the critical
places in the code which are to be changed and even
by sending short code fragments. (I prefer e-mail.)
The implementation is not difficult. Please pass
this suggestion to POV-Team if you think that it is a
step forward.
<snip>
	y.
Date: 21 Sep 1999 17:47:31
Message: <37e7fcf3@news.povray.org>
But you don't want to skip the parsing if the clock value is outside
the limits.  You need to parse it as if it were in the scene but not
static.  For what you want, you'd do
#static (start, end)
The #static says "this code produces the same result for all clock
values from start to end" and the #if says "don't parse this code
for the other clock values."
This means you can also say
#static (.1,.2)
#static (.3,.4)
to denote code that produces the same result over clocks in the
interval (.1,.2) and a different (but fixed) result over clocks
in the interval (.3,.4).  It will be parsed once for each of
those intervals, and for every frame outside both those intervals.
This could represent a figure that moves into the scene, stops,
turns around, stops, and then moves out of the scene.
There's a reason for that: it shouldn't try to do so.
Some must be at least partially parsed, yes.  In particular, anything
that has a corresponding #end (#macro, #while, #ifdef, or #if) must be
at least recognized, so that the correct #end can be found to terminate
the false section.  Comments must also be parsed completely.  Nothing
more need be done.  Whether it is or not is something I can't answer at
the moment, not having delved that deeply into the directive-parsing
code myself.  If #includes (for example) get parsed anyway, that would
be a bad thing indeed.
When the usual cleanup is done, objects will only be deleted if they
are either not static or the next frame will have a clock value beyond
the range for which they were declared static.
>(The clock
The clock function is indeed monotone, and in fact increases by a fixed
amount for each frame.  If an object is sometimes there and sometimes
not, then it is not static for that entire duration (but may be static
for a number of smaller durations.)
>- phong, ditto.
>- specular, ditto.
>step forward.
The best way to get new code into the official version is to write
it and make it available to the POV-Team.  It helps if you can
present a case to justify the change, as well, but you obviously
have one in mind.  If you just say "feature X would be cool"
you're likely to be ignored, but saying "feature X is cool; here's
why and here's code that does it" is much more likely to get a
favorable response.
Date: 21 Sep 1999 17:53:00
Message: <37E7FF5D.BBBFA77A@merlin.net.au>
I'm beginning to think that #static as a type of #declare would be more
feasible, after all it is only usefull for things which take a long time
to parse such as complex unions and meshes.
When parsing a #static declaration, check if the name is already in the
symbol table.  If it is then skip to the end of the declaration.
How do you know what's the end of the declaration?
Firstly all declarations should end with a semi colon.  Then each
[#declare|#local|#static] would match up with a semi colon.
#static ST = union{
  #declare A=0;#while(A<360)
    sphere{x*10,1 rotate y*A}
    #declare A=A+12;#end
  }; <- this semicolon marks the end of the #static declaration.
#undef works on #statics the same as #declares
e.g. #if(clock = 0.5) #undef ST #end
Any how, just an idea.
Cheers, PoD.
Date: 22 Sep 1999 06:11:32
Message: <37e8ab54@news.povray.org>
: I'm beginning to think that #static as a type of #declare would be more
: feasible, after all it is only usefull for things which take a long time
: to parse such as complex unions and meshes.
  You forget that you can make #while-loops which take hours to parse although
it creates only some simple objects.
: When parsing a #static declaration, check if the name is already in the
: symbol table.  If it is then skip to the end of the declaration.
: How do you know what's the end of the declaration?
: Firstly all declarations should end with a semi colon.  Then each
: [#declare|#local|#static] would match up with a semi colon.
  You still have to parse the entire code to see where is the matching
semicolon.
  There's no way to avoid parsing other than copying the whole source code
to memory without the static parts of it and then parse this copy.
Date: 22 Sep 1999 11:00:16
Message: <37E8EEFB.8C33EDE2@uni-paderborn.de>
> >(The clock
This is something I didn't know about (that the
clock function is always monotone). I thought
of it as of a variable which is automatically
declared and has a special meaning...
Are you sure that the user cannot assign an
arbitrary value to clock in the .pov code?!
> >- phong, ditto.
> >- specular, ditto.
> >step forward.
> favorable response.
For instance, it can prove helpful when converting from
VRML. A material node in VRML looks like:
Material {
  exposedField SFFloat ambientIntensity  0.2         # [0,1]
  exposedField SFColor diffuseColor      0.8 0.8 0.8 # [0,1]
  exposedField SFColor emissiveColor     0 0 0       # [0,1]
  exposedField SFFloat shininess         0.2         # [0,1]
  exposedField SFColor specularColor     0 0 0       # [0,1]
  exposedField SFFloat transparency      0           # [0,1]
I am aware of the difference between POV-Ray and VRML
lighting models. However, let's say that someone wants
to convert to .pov anyway. As it is now, at least the
specularColor cannot be properly modulated in .pov for
each of the RGB channels separately. The extension I
propose would allow this. I believe that the extension
could be helpful also in other cases. Moreover, it makes
POV-Ray more consistent (a colour as well as a
coefficient could be used not only for ambient but also
for diffuse, etc.).
As for submitting the patched sources:
If the above argumentation is reasonable enough for
including the proposed changes into the superpatch,
I'll do that (otherwise not).
Would patched POV-Ray 3.02 sources be OK for POV-Team?
If not, then which ones?
	y.
Date: 22 Sep 1999 11:24:33
Message: <37e8f4b1@news.povray.org>
POV treats it as a scalar function with no arguments.  I get an
error when I try to assign to it.
I'll include just about anything in the superpatch, as long as it
doesn't conflict with something else that's either already included
or otherwise available, in which case I'll have to decide which one
to include so as not to make a total mess.
I don't speak for the POV-Team, so I can't say for sure, but I'd
guess patched 3.1 sources would be far more useful.  There were
some fairly large changes between the two (Believe me - I had to
merge the 3.1 sources into the superpatch as "just another patch
to 3.02."  It took several hours.)
Date: 22 Sep 1999 13:02:39
Message: <37E90BA2.BFC08246@enst.fr>
> semicolon.
	Depends what you call "parsing"... For example, you don't have to
execute a #while loop to find the corresponding #end, but executing it
is still a part of scene parsing, so there a #static could bring lots of
improvement... Moreover, I seem to remember Ron saying that what took
the most time was memory allocation, so even if you need to read the
#static parts of the scene you could still gain time since you won't be
allocating any memory for them...
	Just my $0.02
		Jerome
* Always listen to experts,   * Jérôme M. BERGER
* they'll tell you what can't * mailto:ber### [at] inamecom
* be done and why...          * http://www.enst.fr/~jberger
* Then do it.                 *
Date: 22 Sep 1999 13:39:55
Message: <37E91447.75C9C106@uni-paderborn.de>
I take back some of my previous remarks. They were
based on a wrong assumption.
I see.
I've never seen the 3.1 sources. "Fairly large changes"
can slow me down but if I find the time, I'll patch the
3.1 sources soon. Whom should I send them then?
Your last remark confused me. What do you mean by
merging 3.1 sources into the superpatch? As far as I
know, the superpatch is based on 3.1, not on 3.02. Or
am I wrong?
Then - if the superpatch is really based on 3.02 -
wouldn't it really be easier for POV-Team (or whoever)
to merge yet another 3.02 patch into the superpatch?
	y.
Date: 22 Sep 1999 14:34:07
Message: <37e9211f@news.povray.org>
>am I wrong?
It was originally based on 3.02, as were most of the patches included
in it when I first released it.  The first released version was "based
on" 3.1, meaning I had at that point merged 3.1 in and it could be used
as a basis for further patching.
I maintain the superpatch; it's an unofficial version that has nothing
to do with the POV-Team, other than that they're rumored to be looking
at it as an aid to making the official version 3.5.   The version they
have is based on 3.1, as are all publicly released versions.
Date: 22 Sep 1999 16:56:04
Message: <37E941B6.E5E4640@pacbell.net>
...and if you want to be technically accurate everything in POV-Ray is based
on DKBTrace :)
Ken Tyler
See my 1000+ Povray and 3D Rendering and Raytracing Links at:
Date: 22 Sep 1999 17:19:57
Message: <37E947F8.5097579A@uni-paderborn.de>
> >am I wrong?
Thanks for an explanation. I'm not confused anymore.
(At least in concern with this.)
I see and am trying to reconstruct the recent
history... I think I got it:
The idea of a superpatch comes from people outside
of the POV-Team (maybe not, it's not so important).
A group of volunteers (SPatch-Team) decided to do
it. You and maybe a few other people of SPatch-Team
did the integration. This all happened in the times
of 3.02. Meanwhile POV-Team released an official
version 3.1. To avoid a divergence of POV-Ray 3.1
and SPatch 1.0, the official 3.1 sources must have
been merged with the actual SPatch sources as soon
as possible.
Now I also understand why the merging took you a
long time and do not envy you the work.
OK, back to the business: When my patch is ready,
whom should I send it to ? To you? Or to
news://news.povray.org/povray.patches?
In the later case, is there an official procedure
about how to post patches to the povray.patches?
And if so, where could I read it?
(Forgive my stupid questions, I'm a newbie here.)
	y.
Date: 22 Sep 1999 17:26:31
Message: <37E949BB.360EFCE8@enter.net>
> semicolon.
How about considering #static as an alternative to #include?
There would be two acceptable forms the parser would expect...
#static /filename/
or
#static (/filename/,/start/,/end/)
If the former was encountered, POV would parse the include file
indicated by "filename" once on the first frame rendered, then just
retain it until all frames were completed.
For the latter syntax, it would behave exactly like #include until
frame # "start" was reached, then parse one more time and hold until
either frame # "end" was reached, or all the specified frames were
completed (whichever comes first, depending on the INI file options
selected). If more frames than "end" are rendered, just go back to
considering it identical to saying #include after the last rendered
frame.
This way, if the static section does not need reparsing, POV need
only read a single line to discover this and move on. And of course,
it leaves responsibility for deciding what should be static firmly
on the shoulders of the user, where it belongs.
Charles
http://www.enter.net/~cfusner
"...Then darkness took me, and I strayed out of thought and time,
 and I wandered far on roads that I will not tell..."
                              -The Two Towers, JRR Tolkien
Date: 22 Sep 1999 17:43:27
Message: <37e94d7f@news.povray.org>
You can post it to povray.binaries.programming and post a note
about it in povray.unofficial.patches so we know to look for it
there.  That way everyone can enjoy it, even it if takes me the
usual months to get it into the superpatch. :)  As for how to
get patches into the official version, I'm not sure there is an
official documented method, but at least one team member will
see it in the unofficial.patches group.
Date: 22 Sep 1999 17:46:22
Message: <37e94e2e@news.povray.org>
>> semicolon.
>#static /filename/
>or
Or, using the syntax I proposed,
#include "filename"
Date: 22 Sep 1999 18:04:24
Message: <37E95247.5BB9DA24@peak.edu.ee>
But you can change the clock value and clock delta in an arbitrary manner during
an animation. Just #write the appropriate initial_clock, final_clock,
initial_frame and final_frame options to an ini file.
Margus
Date: 22 Sep 1999 18:09:02
Message: <37e9537e@news.povray.org>
But wouldn't you then have to restart the renderer for those options to take
effect?  If not, I'd say that's a bug.  Even if you can, you shouldn't use
#static if you're gonna play around with the poor thing's mind like that.
Date: 22 Sep 1999 18:19:12
Message: <37E955BF.10594924@peak.edu.ee>
> effect?
Come to think of it, I haven't tried. And I agree, it's too twisted to worry
about :)
Margus
Date: 22 Sep 1999 19:22:01
Message: <37E965C8.8A158CAA@merlin.net.au>
You could make a #while loop which takes days to parse and creates no
objects at all
> semicolon.
If a #while loop is inside a #static declaration, you'd only have to
look for the matching #end which would not take long at all.
#include would be totally ignored.
What difference does reading it into memory make?
Date: 22 Sep 1999 19:55:24
Message: <37E96C75.99FEBDF0@enter.net>
> #include "filename"
> #end
True. Three lines instead of one isn't going to make a significant
difference to parsing, although it's slightly more trouble to type,
so the above would give almost identical results -- *if* the end
user applies it correctly.
I only mentioned it as a supplement to #include (analogous to the
way #local is a specialized supplement to #declare) because problems
with making it a #static block were brought up. As an alternative
to #include, there'd be no block, and users would have to
externalize the static info to a separate file because... that's
just the way it works.
Whereas, if you require the user to set up a #static block with an
embedded #include in it, sure as there's rain you'll have people
who skip the #include and just stuff hundreds of lines of code
between #static and its corresponding #end and complain that it
isn't making the kind of difference they think it ought to (and
Warp will have to add something new to the VFAQ). As much as I
hate "protect them from their own stupidity" style programming...
Well, I'm a scene coder, not a programmer. I only mention it
in passing, FWIW.
Charles
