When I use spotlight then why is the light intensity
not at full intensity within the "radius" angle?
In the following example when I use normal point light
the whole plane is full illuminated. with spotlight I
expected the area inside the red lines to be full
illuminated but it is not so at all. Why? I can't find
the answer in the docs.
// off = normal light, on = spotlight.
#declare Spotlight = on;
// angle for both "radius" and "falloff".
#declare Angle = 60;
location 100*y
look_at 0
plane {
y, -0.001
pigment {color rgb 1}
finish {ambient 0 diffuse 1 brilliance 0}
light_source {
0, color 1
#if (Spotlight=on)
spotlight
radius Angle
falloff Angle
point_at x
cylinder {y, y+100*x, 0.5 rotate +Angle*y pigment {color red 1} finish
{ambient 1 diffuse 0}}
cylinder {y, y+100*x, 0.5 rotate -Angle*y pigment {color red 1} finish
Greetings,
Rune S. Johansen
Visit The RSJ Website at http://rsj.mobilixnet.dk
for 3D images including still lives, dragons,
mathematical shapes, and more. Stereograms,
tutorials, The POV Desktop Theme, hundreds of
raytracing jokes, miscellaneous other things,
and a lot of fun!
Most likely a 'tightness' thing. Defaults to 10 if not used and can be
from 0 to 100 near as I know. If someone knows the intricities of how
it works though, I'd be a willing listener.
Rune S. Johansen <run### [at] iname com> wrote in message
news:37dba28e@news.povray.org...
> camera {
> location 100*y
> look_at 0
> plane {
> y, -0.001
> light_source {
> 0, color 1
> #if (Spotlight=on)
> spotlight
> radius Angle
> falloff Angle
> point_at x
> #end
finish
finish
> Greetings,
> Rune S. Johansen
> and a lot of fun!
> Bob
It is a tightness thing: if you look at the curves of intensity versus
angle in the pov doc, you'll notice that for tightnesses other than 0,
the light starts falling off right from the beginning...
Jerome
* Always listen to experts, * Jérôme M. BERGER
* they'll tell you what can't * mailto:ber### [at] iname com
* be done and why... * http://www.enst.fr/~jberger
* Then do it. *
