POV-Ray : Newsgroups : povray.general : What time is it? Server Time
6 Nov 2026 22:32:06 EST (-0500)
  What time is it? (Message 1 to 20 of 20)
Subject: What time is it?
Date: 28 Aug 1999 01:03:30
Message: <37c76da2@news.povray.org>
Is there a way to call the present system time into a pov file? So that I
can use it to show the correct angles of the sun and moon? I think I can do
it using a text program which has a time stamp, but I wonder if POV does
it...
I don't find a reference to it in the help file, and none of the options in
the editor look like it.
Subject: Re: What time is it?
Date: 28 Aug 1999 01:10:10
Message: <37C76EDC.2F273B47@pacbell.net>
> it...
There currently is no way to access the systems clock. I have thought about
using it to randomize the seed value in a rand statement but it doesn't make
sense to use if unless you want no control over repeatability of a pattern.
You trying to make a scene you can distribute to others that will match the
time in their time zone ? Otherwise why not just type the time in ?
Ken Tyler
See my 850+ Povray and 3D Rendering and Raytracing Links at:
Date: 28 Aug 1999 02:31:57
Message: <37c7825d@news.povray.org>
Too bad, but I will try to automate my text editing program.
    I was thinking about having my file run minimized on a regular basis and
then updating my wallpaper with the output. I download satellite images all
day and can map them on a globe with Sun and Moon info...
    ...waiting for Dennis in Florida...
Date: 28 Aug 1999 03:47:10
Message: <37C793CA.932C2C68@skynet.be>
> it...
If you, or someone else, can do some C (or whatever) programming, you
could
use the "Shell-out to Operating System" command in the .ini file, to
call
a program that will write the time info into a file that you will #read
inside
povray script.
Fabien.
Date: 28 Aug 1999 13:07:35
Message: <37C817F4.170DF61C@merlin.net.au>
> > it...
> could
> call
> inside
> povray script.
> Fabien.
Er. how about something like 'time > time.txt' in DOS/Windoze or 'date >
time.txt' in *n*x.
It won't be very portable though.
Cheers, PoD.
Date: 28 Aug 1999 13:28:50
Message: <37C81C13.5C2798B8@skynet.be>
> time.txt' in *n*x.
I tought of that, but, afaik, Pov needs comma-separated data, so
the standard dos time output would be unreadable. (but I may
be wrong...)
Fabien.
Date: 28 Aug 1999 17:09:28
Message: <37c85008@news.povray.org>
Use a substr function on the read input. Extract the first two digits
for the hour, next two for minutes.
#declare Time=str(01:23:45am)
#declare H=substr(Time,0,2)
#declare M=substr(Time,2,2)
#declare Hours=strval(H)
#declare Minutes=strval(M)
Something like that anyhow. I'm not sure since I haven't done it,
yet....
Fabien Mosen <fab### [at] skynetbe> wrote in message
news:37C81C13.5C2798B8@skynet.be...
'date >
> > time.txt' in *n*x.
> be wrong...)
> Fabien.
Date: 28 Aug 1999 18:22:45
Message: <37c86135@news.povray.org>
This is what I was thinking I would use. The standard notepad in Win98 has a
F5 time stamp that I can automate with one of those shortcut macro programs.
Now if I can just figure out how to get it to do that, then run a specific
POV file and then change wall papers for me.....
    Looks like we are taking a miss with Dennis, I am a little
disappointed...
Bob Hughes <inv### [at] aolcom> wrote in message
news:37c85008@news.povray.org...
> yet....
> Bob
> 'date >
> > > time.txt' in *n*x.
> > be wrong...)
> > Fabien.
Date: 28 Aug 1999 23:48:47
Message: <37c8ad9f@news.povray.org>
Sounds like you also need POV-Ray to start up on it's own. So I guess
that means setting up the Pov file type to be rendered when "run"
somehow. Wish I knew the whole answer myself as it would be
interesting to do.
About Dennis (the hurricane), when I was a kid and lived there near
where you do (Merritt Island and Satellite Beach) it was great to
experience those things but mighty fearful stuff too. I'll never
forget the howling air and turbulent ocean. One time we almost never
got the front door shut after having it open and our neighbors got a
large corrugated pipe slammed into the front of their house. Great
stuff to see, even the "eye", if it weren't for the bad side.
Bill DeWitt <the### [at] earthlinknet> wrote in message
news:37c86135@news.povray.org...
Win98 has a
programs.
specific
> disappointed...
digits
> > yet....
> > Bob
or
> > 'date >
> > > > time.txt' in *n*x.
> > > be wrong...)
> > > Fabien.
Date: 29 Aug 1999 09:04:26
Message: <37d5c602.9079073@204.213.191.228>
>time.txt' in *n*x.
>Cheers, PoD.
This was the first thing that I tried the first time this question was
brought up. Unfortunately the time command expects stdin input. A
simple echo. > time won't work :(
Try this (in a batch file), but first create a file called quote.txt
and only put a " in it. This is untested but should be in the right
direction (the help command won't work for me and I am not sure of the
exact syntax used to concatenate files with the copy command)
@echo off
c:\
cd\
copy command.com temp.tmp
dir temp.tmp > temp.dir
find /i "temp.tmp" temp.dir > temp.tim
copy /a temp.txt /a quote.txt + temp.tim /a + quote.txt /a
del temp.tmp
del temp.dir
del temp.tim
^Z
Then read this temp.txt file in POV and extract the time using the
substr function, as Bob suggests.
Peter Popov
ICQ: 15002700
Date: 29 Aug 1999 09:11:12
Message: <37c93170@news.povray.org>
news:37c8ad9f@news.povray.org...
> interesting to do.
Unless you chose otherwise at the time of setting up POV, running a .pov
file activates POV-Ray and opens the file. Then the macro program will push
<render>.
    We spent most of yesterday at Port Sebastian watching the edge of the
Hurricane. One of the reasons I asked this question was because I wondered
how far away you can see clouds from... turns out that it is quite far.
Using a correctly scaled earth and correctly located points on the earth, I
was able to see 10 mile spheres from over 150 miles away.
    Using reality to simulate POV I went to the beach. The edge of hurricane
Dennis was clearly visible, but without the knowledge that it was -possible-
to see it I would have just assumed that there were some clouds between me
and it. Having been raised in Florida I can tell when a hurricane is in the
area and for some time before we really felt the wind I was sure I was
seeing the storm.
    I am a hurricane lover and even now that I own property I would rather
have a hurricane than have safety. In fact I have been known to offend
people by expressing the opinion that if a big enough one came we would be
rid of all the condos and might even have a new port down in south Cocoa
Beach.... about where A1A comes back together....>8-}
Date: 29 Aug 1999 09:26:09
Message: <37C93533.2DF3342B@fv.aetec.ee>
> >time.txt' in *n*x.
> >Cheers, PoD.
One possibility would be to create response file, which contains
carriage return /newline and direct it as input to time command. I.e.
create text file nl.txt, which contains single newline. Now invoke:
time <nl.txt >time
BTW, if You have NT, then it has /T option, which just ouputs time:
C:\>time /T
16:15
Date: 29 Aug 1999 09:35:56
Message: <37C93704.87820A14@pacbell.net>
> seeing the storm.
 Sometime around 1978/79 I was setting up mobile homes in Colorado and
Wyoming. One early afternoon on a hill over looking Cheyenne Wyoming I
saw what looked like a column of smoke rising on the other side of town.
We were setting up a new 65' double wide mobile home on a custom lot.
As we watch another column of smoke dropped out of the clouds !!?
We watched as 5 more columns of smoke dropped out of the sky in a
matter of 4 minuets time with 7 all told visible at once.
 They were of course tornados forming from a major hail storm system
parked right over the town. I looked over at my co worker and pointed
out that we were on an exposed ridge, setting up large 15 ton empty
unanchored boxes, and that I was getting the heck out of there. He
agreed and we drove 50 miles south to where we lived and called it a
day. On the way home we ran through two hail storms the worst of which
had hail a bit larger that golf balls and it was like trying to drive
on a road covered with marbles of that size. I thought we were going
off the road a couple of times.
  Upon returning the next day we did not have to worry about finishing
the set up as the two halves of the trailers were scattered across 4
acres of field and smashed about as flat as if they had been run over
by a freight train. I can truely appreciate the power of major storm
systems but I'm also smart enough to get out of their way despite my
own fascination with them. I hope you too are as smart as I have been
and know when to run like heck when the time comes : )
Ken Tyler
Date: 29 Aug 1999 12:51:02
Message: <37c964f6@news.povray.org>
    Sorry to disappoint you, I am one of those nuts who hide from the
evacuation cops. I've tried to surf in 115 mph winds (never did make it out
past the break). Me and my Lovely Wife sat out the last one on Cocoa Beach
when she was 7 months pregnant. We lived on Orlando Ave (which is two blocks
from the beach) and got 100 mph winds.
    I have also been known to chase tornados.
Date: 29 Aug 1999 13:04:03
Message: <37C967CD.FD998992@pacbell.net>
Chasing tornados is one thing. Having them chase you is an altogether
different story !
To keep it on topic I have tried modelling a tornado and have as yet not
even come close to getting it right. Even made an animation of one once
but it is difficult to control the shape and not have it look artificial.
Anyone else try this and have success ? I could post the anim if anyone
is interested.
Ken Tyler
Date: 29 Aug 1999 13:24:41
Message: <37c96cd9@news.povray.org>
> is interested.
    Oooo...  Tornado modeling......
    It's no wonder I never get anything done, I keep stopping to try
something else!
Date: 29 Aug 1999 16:32:38
Message: <37ca98b1.149597703@news.povray.org>
On Sun, 29 Aug 1999 14:03:57 GMT, pet### [at] usanet (Peter Popov)
This works:
echo | more | time | find "Current"
I didn't invent this one myself; I picked it up from some "101 hints
for Windoze" article many years ago.
Date: 29 Aug 1999 19:07:14
Message: <37c9bd22@news.povray.org>
Okay, something that might help (seems all right) is being posted at
the p.t.s-f group, thanks to Ron P. for his command line to retrieve
"current" time. I had forgotten all about that little gem gleamed from
the masses of DOS stuff I have.
news:37c76da2@news.povray.org...
that I
can do
does
> it...
options in
Date: 30 Aug 1999 08:39:31
Message: <37ca7b83@news.povray.org>
news:37c9bd22@news.povray.org...
    Thanks! That works. I modified the batch file to self exit and called it
from the pov ini file and am now almost completely automated.
    If only the rest of the process worked as well...
Date: 31 Aug 1999 12:10:12
Message: <37cbfe64@news.povray.org>
Well, I haven't had much luck calling POV-Ray to render and then
render a second time without error. Something about running
pvengine.exe (Win) instead of povray.exe (DOS) I think. A Ini file
can't be included on the command-line apparently. I was going to do it
all by using the batch file via Task Scheduler, which it does so fine
on one run only and using what Ini was previously set already, then it
does nothing on the second run. Other than that I've got a expensive
looking PC clock checker.
news:37ca7b83@news.povray.org...
at
retrieve
from
called it
