POV-Ray : Newsgroups : povray.general : Linux with v3.1g Server Time
27 Oct 2026 13:59:26 EDT (-0400)
  Linux with v3.1g (Message 1 to 5 of 5)
Subject: Linux with v3.1g
Date: 25 Aug 1999 19:37:28
Message: <37c47c5a.65470@news.povray.org>
Hello All,
I had a copy of PovRay v3 working just fine in my SuSE (v6.1) Linux.
When I upgraded to PovRay version 3.1g, I get the following error:
Parsing....povray: error in loading shared libraries
: undefined symbol: __bzero
The paths are correct in the .povrayrc file and the library
libX11.so.6 does exist on the system.  I am using the x-povray version
of the program in KDE. I used the new 'install' utility to move the
files to the recomended directories.
I have used PovRay for DOS for a long time but am relatively new to
Linux.  Where do I look to solve this problem?
Orrin - Long Island, New York
orr### [at] orrinorg
http://www.orrin.org/carib/    (Caribbean Index)
http://www.orrin.org/syocc/    (Syosset Camera Club)
http://www.orrin.org/wphs/     (HS Reunion)
http://www.orrin.org/          (Site Index)
Subject: Re: Linux with v3.1g
Date: 25 Aug 1999 20:25:41
Message: <37C5DD3D.65F76774@stic.net>
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
I had a similar problem with my version (mine segfaulted). My advice to
you is to compile your own version of Pov-Ray 3.1g. If you do it right,
it may even end up being faster than the pre-compiled version (it will
also work, most likely :) If you don't want to do that, I really
can't think of what you really can do, except run ldd <povray exec> and
see if anything points to a library that does not exist (or it is looking
for it in the wrong place).
<p>Good luck, and happ tracing,
<p>Tim Soderstrom
<br>TigerHawk
<br>Tig### [at] Sticnet
<br>
<br>
<p>Orrin wrote:
<blockquote TYPE=CITE>Hello All,
<p>I had a copy of PovRay v3 working just fine in my SuSE (v6.1) Linux.
<br>When I upgraded to PovRay version 3.1g, I get the following error:
<p>Parsing....povray: error in loading shared libraries
<br>: undefined symbol: __bzero
<p>The paths are correct in the .povrayrc file and the library
<br>libX11.so.6 does exist on the system.  I am using the x-povray
version
<br>of the program in KDE. I used the new 'install' utility to move the
<br>files to the recomended directories.
<p>I have used PovRay for DOS for a long time but am relatively new to
<br>Linux.  Where do I look to solve this problem?
<p>-----------------------------
<br>Orrin - Long Island, New York
<br>orr### [at] orrinorg
<br><a
href="http://www.orrin.org/carib/">http://www.orrin.org/carib/</a>
(Caribbean Index)
<br><a
href="http://www.orrin.org/syocc/">http://www.orrin.org/syocc/</a>
<br><a
href="http://www.orrin.org/wphs/">http://www.orrin.org/wphs/</a>
(HS Reunion)
<br><a
href="http://www.orrin.org/">http://www.orrin.org/</a>
(Site Index)</blockquote>
</html>
Date: 26 Aug 1999 13:34:00
Message: <37c57a02.436598@news.povray.org>
I ran the ldd and the results were:
	libpng.so.2 => /usr/X11R6/lib/libpng.so.2 (0x40008000)
	libz.so.1 => /usr/lib/libz.so.1 (0x40025000)
	libm.so.6 => /lib/libm.so.6 (0x40035000)
	libX11.so.6 => /usr/X11R6/lib/libX11.so.6 (0x4004f000)
	libc.so.6 => /lib/libc.so.6 (0x400f4000)
	/lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x2aaaa000)
All of these files exist on the system, but the problem persists:
Anyone else have any ideas?
><html>
><p>Tim Soderstrom
><br>TigerHawk
><br>
><br>
>version
><br><a
>(Caribbean Index)
><br><a
><br><a
>(HS Reunion)
><br><a
></html>
Date: 26 Aug 1999 13:37:14
Message: <37C57B16.331E9FA9@pacbell.net>
You may wish to take a look in povray.unix on this server to see if someone
else has had similar problems and to see it a fix was provided for this
problem.
Ken Tyler
See my 850+ Povray and 3D Rendering and Raytracing Links at:
Date: 26 Aug 1999 19:36:20
Message: <37C72338.CD109306@stic.net>
<html>
Hmm...what distrobution are you running? If you run slackware, that
may be your problem. I belive that slackware has runtime support
for glibc2, but it isn't very good, I get segfaults for most things
that use glibc2. So, you may want to find someone that'll have a binary
of glibc1 for ya (or, like I said you can try compiling it yourself).
<p>Hope that helps,
<p>Tim S.
<br> </html>
