Hello:
I seem to recall some discussion somewhere comparing rendering times of
skyvase.pov as a sort of hardware benchmark (It DOES take 100% of my OS/CPU
resources, according to Win98 System Monitor.)
640x480 No AA
Using a 400 Celeron overclocked to 500, 83 MHz bus, I get skyvase times
around 48-50 sec. ...about 5 times faster than my 233MMX.
Here's the rub: using TWO CPUs on motherboard, o/c to same 500 (let's hear a
big Tool Time "GHz! Arr! Arr! Arr!" grunt), NT4.0 (only service pack 1 so
far) seeing both CPUs, times are no better- maybe even slightly slower.
Have not tried multiple instances.
Whuzz happnin? Where's the beef?
Thanks,
Matt
Matt Swarm wrote:
> Hello:
> 640x480 No AA
> Thanks,
> Matt
The official home of the Povray benchmarks is at:
http://www.haveland.com/povbench/
Ken Tyler
See my 700+ Povray and 3D Rendering and Raytracing Links at:
Well, POV-Ray doesn't take advantage of multiple CPU's, you will have to
use multiple copies of POV running at once to get both CPU's. But there
should be some speedup, because other programs would be put on the other
processor. Unless all non multiprocessing enabled programs are put on
one particular processor.
On Wed, 18 Aug 1999 17:09:58 -0700, "Matt Swarm" <mic### [at] aol com> wrote:
>640x480 No AA
Hi, Matt. Have a look at the .url provided by Ken for the POVBench pages.
Though not an official benchmark designated by the POV-Team, it has become
the de facto standard through the years, since the time that Dan Farmer
originally wrote the scene.
I'm certain that this unofficial benchmark uses 640w by 480h and +a0.3
(anti-aliasing ON). Otherwise, your times will be misleadingly short.
Alan
news.povray.org - where POV-Ray enthusiasts around the world can get
together to exchange ideas, information, and experiences with others
Matt Swarm wrote:
> Hello:
> 640x480 No AA
Ummmm. Unless you grabbed the PVM patched version of POV-Ray, it should only
actually be using one of those.
NT4.0's overhead might explain a lot.
Running two instances should show you a lot.
"My new computer's got the clocks, it rocks
But it was obsolete before I opened the box" - W.A.Y.
Hello Folks:
Thanks for your comments and links. I checked the POVBench, compared with
the parallel section since using dual processors. Seems that my numbers
appear entirely respectable-- and that on a motherboard in use for only two
days, one whose BIOS has not yet even been tuned.
SkyVase on ABit w/ dual 400 Celeron at 500, 83 MHz bus, 128MB RAM, no BIOS
tuning.
_______________________________
640x480 a0.3
Instances Time Each
4 65.5 Single CPU Win98
2 62.25
1 63.5
8 30 Dual CPU NT40
6 28.7
4 28.31
2 32.6
1 65
It's clear that the dual CPU machine is at peak efficiency around FOUR
instances.
I have not yet experimented with DIVIDING the image into four sections, then
combining.
On it's face, I am unconcerned with:
--- the amount of time it will take to load programs into parallel nodes
(POV programs are ridiculously short);
--- networking the image portions to a hub for combining (100 Mb net is
nearly FREE these days, and would take all of 50 milliseconds) and for BIOS
programmers, there may totally FREE motherboard communications busses (5
times faster!) just waiting to be exploited (do the numbers 33 and 66 MHz
suggest anything?);
--- image portion combining overhead. [As implied, conveyance of the image
portions would not be significant providing the portion size is not too
fine-grained. 10ms would be huge if the renderer was only given a 20ms
job, but only a half-percent of a two-second job.] As for the Combiner Hub,
it would use RAMDisk, and should not take any longer to combine than the
nodes took to produce the imageportions.
Given this guess, if we are measuring ONE rendering, the combiner will
double the time. If however, we are averaging ONE HUNDRED renderings, it
will only add ONE PERCENT (it's doing the last job's output while the
imaging nodes are onto new mischief).
It is apparent here that *load balancing* is a pretty crucial issue. I'm a
bit more concerned about initialization times of the POV interpreter.
Another concern in real world image processing with cluster computers is
PREDICTING how long a given program will take to render, so we know how to
carve up the images so as to initiate the optimal number of instances on a
multi-CPU node (in my case 4- see above).
SCENARIO ONE:
This would be more of an issue on, say, a 10-dual-CPU-node "10 GHz"
cluster. Perhaps for continuous image production this will actually be a
nonissue. (Report the instances to the 'boss' when they get below, say,
four... and get another job. ---Non-union, I would say.--- :)
SCENARIO TWO:
Number of instances on a node would indeed *not* be a concern on, say, a
300
single-CPU cluster-- but giving each CPU a task large enough so that
communication remains a small percentage would still require predictive
analysis.
Think it's possible to gut the POV interpreter so it just combines
best-guesses as what this command and that loop will require in rendering
time? (Aw, c'mon, don't tell me there's a switch for that! :) Other
strategies?
Think of another place to post these concerns?
I have begun work on the first scenario- the dual-CPU cluster. I may do
the second... have 300 ISA backplane slots, racks, and about 50 CPU cards
for starters. But I'm looking for some old ISA card which has more
processing power and is dirt cheap- like a video card which used overkill
RISC maybe?
Ain't it FUN?
Matt
Ken <tyl### [at] pacbell net> wrote:
: The official home of the Povray benchmarks is at:
: http://www.haveland.com/povbench/
I still think that this benchmark has not very much relevance anymore with
current computers. If one computer renders the skyvase in 5 seconds and
other in 6 seconds, that doesn't tell anything about which one is faster.
When we talk about times this short, you can't compare computers anymore.
If you render the scene for first time it may take 10 seconds. If you then
render it again, it may take 5 seconds. Is the computer twice as fast now?
Of course not. There are several things that affect the render time
significantly when the total time is so short, for example the disk buffer,
cache, other processes, etc. You can get very varying times from one
render to another. They have no meaning. One computer may be even faster
than other even if it takes 10 seconds to render the skyvase although the
other one takes only 5. Perhaps the other one had a faster disk or whatever.
If the scene was so slow to calculate that it took about 1 minute for
the fastest computer to render it, then the results could be relevant. Then
the time really measures rendering speed. If a poor disk cache adds a couple
of seconds to the total time, that has no meaning when the total time is
over one minute.
> over one minute.
I think you can eliminate the disk cache from the equation because the file
and memory overhead is so small that the scene easily loads into ram memory
even on the most poorly equipped machines. With regard to other elements
effecting render times I agree that a more robust scene should be developed
to really test the power of modern processors and ultimately their true
raytracing speed rating. I leave that task to those more competent than
myself to decide what that may be but I'm sure there must be some routines
in Pov that could be used for a reliable benchmark. Probably a combination
of math functions, high order primitives, and complex surface finishes that
require large numbers of ray intersection tests. All of this can still be
done without the need to consume large quantities of memory so that disk
swapping can be avoided on even under equipped machines.
Ken Tyler
Thanks for responding. For my interests and motivations for running these
tests, see my "Results..." posting below.
with
This has become conventional wisdom, useful if not applied too broadly. To
universalize it, however, is to err as those who apply narrow and specific
tests to a GENERAL computing machine.
To test for IMAGE RENDERING, what is better than loading a CPU(s) completely
with the software it will be running?
Given that, we are left only with choosing a test protocol which will
approximate our kind of script programs-- and, yes, this does require
judgment. Will we use fonts? Fog? Focal blur? Textures? How much of
each?
Note that my emphasis is directed from 'how fast is my machine?' to 'how
much WORK can I expect out of this machine?' They are corollaries, to be
sure, but my interest lies more in workload scalability-- or moving to 'real
time' designing. So far, I've found the results of my tests to be quite
relevant and informative.
[And, yes, for brief tests to be meaningful, one must minimize variables
like disk accesses (another program's), etc. A lovely example: in both
Win98 and NT, as quickly installed and (un)configured on my '1 GHz' test
machine, one of the four or six or eight instances of POV might run TWICE as
fast.
Turns out to be the instance which has the focus. Had to click on
desktop after starting all.
Beyond that, discarding extremes, my results were very consistant. A
percent or two.]
When we shift the focus from the work a particular machine will do to
TESTING CPUs and machines in general, Ken, it seems to me than NM's
criticism becomes more applicable. For example, if an x86 compiler used on
POV source is inferior to an Alpha compiler, the Alpha might look 50% faster
for certain POV programs. Clearly, we are not just testing hardware.
Matt
> Matt
I won't argue your point... BUT... well ok. Then the only true test
of your performance would be when it is compared to a similar system
architecture and platform running at a specific speed. Any other
comparison would simply imply that your machine is different than
someone else's and your results would therefore be misleading. It
that what you are implying ?
Ken Tyler
On Thu, 19 Aug 1999 01:55:03 -0700, Ken <tyl### [at] pacbell net> wrote:
>...but I'm sure there must be some routines
Sounds like a fun project for the rest of the summer. It might be best to
omit experimental features such as radiosity, as their implementation may
change too soon for the benchmark to gain a following. The scene should be
complex enough to give the faster machines a workout, yet not so 'tough' as
to render (pun intended) the slower machines useless for several days. I
think it should also be aesthetically pleasing and not just a loop-generated
scene with thousands of reflective and refractive objects.
Alan
Subject: Benchmark Concerns- Skyvase Rendering Times
Date: 19 Aug 1999 16:30:27
Message: <37bc6963@news.povray.org>
Hi Ken:
In essence, you are asking if I believe meaningful comparison is possible.
I sure do.
I also believe that it's possible to properly compare apples and oranges--
but only by asking the RIGHT question! 'Which is better for your health?'
is not a meaningful question. 'Which is better if one has scurvey?' is
measurable and thus answerable.
Similarly, 'Which is the more powerful CPU?' should be sharpened by: Power
to do WHAT? CPU A and B may be virtually equal as word processors, while A
could blow the socks off B while searching for prime numbers. A question
about "raw computing power" is usually a raw, unripened question.
Similarly, "true test of performance" is an unfinished premise. It
requires the "performing what" to be complete. Even that requires
judgment. Ten percent better performance at "calculating spreadsheets" is
a silly reason to buy a machine if it only 'calculates' a few minutes a
day-- better to buy based upon color and cute buttons. Yet, that same
superiority in a worker-bee machine can be worth baskets o' bucks.
I would **never** exclude the comparison of different classes of machines--
those are *exactly* the kinds of comparisons we MUST make to choose hardware
for a particular job.
My invocation of benchmark caveats was more cautionary than exclusionary.
Use them with full awareness of what we really looking at in the numbers.
Assume nothing.
I had a blast going through the benchmark sites before deciding upon
hardware. Looked at everything from 66MHz on up. In the end, I chose a
path which entails CPUs and motherboard which are not quite the most
efficient or the best immediate value per MFLOP-- but they have a 100%+
performance upgrade path and attractive motherboard features.
Matt
on
faster
>> Matt
>Ken Tyler
>The scene should be
loop-generated
Several have commented on this issue.
I agree on the need, but fear that a conventional program approach is
destined to fail.
The problem is that the gap between the slowest machines and the fastest is
growing nonlinearly. What makes this so is the 'Grove effect' plus growth
in distributive and cluster computing.
I propose a Smart Benchmark, which senses how long a routine is taking, and
terminates after a set period, projecting the time for completion of the
'full' program-- whatever the machine. All this code is (or SHOULD be)
deterministic, nonrandom, so extrapolation should be straightforward.
My benchmarking experience is limited-- there may be things lke this out
there, even if non-POV.
Matt
>Alan
>The scene should be
loop-generated
destined to fail.
Maybe an animation, with option to deduct for disk access times.
Matt
Subject: Re: Smart Benchmark: Skyvase Rendering Times
Date: 20 Aug 1999 03:11:13
Message: <37bcff91@news.povray.org>
Matt Swarm wrote in message <37bc7173@news.povray.org>...
>>The scene should be
as
>loop-generated
>destined to fail.
How about an image where the render time scales linearly with image area?
This way, you simply render the image at what you consider an appropriate
resolution for your machine (320x240 for a 486/33, 320000x240000 for a
supercomputer, etc) and then apply a correction factor for the area (the
486/33 in this example would have a correction factor of x1000000)?
Mark
Date: 20 Aug 1999 04:45:20
Message: <37bd15a0@news.povray.org>
and
>Mark
Interesting notion- certainly simpler than a tricky program. How might this
work?
We have two machines, say, Trusty Rusty (486) and the Swarm Machine I (20
500 MHz Celerons).
Q: The clock speeds on Swarm add up to about 300 times Rusty. Which image
size would we select, perhaps, for the Swarm Machine?
Q: What correction factor would we then apply?
Q: While it's true that image 1000X by 1000Y is 1000000 times greater in
area than image XY, is it also true that a THEORETICAL idealized machine
rendering in POV will also be 1000000 times longer? It's true that area
increases by the square-- what worries me here is that (so far as I know) we
are doing some computations in THREE dimensions. Might not some portions of
the image factor up by the CUBE of the increase instead of merely the
square? Or worse?
Looking forward to your thoughts.
Matt
Date: 21 Aug 1999 01:06:04
Message: <37be33bc@news.povray.org>
Matt Swarm wrote in message <37bd15a0@news.povray.org>...
>and
>>Mark
this
>work?
>500 MHz Celerons).
This is a matter of personal preference, depending on many factors,
including how fast the computer is and how much time you can afford to have
the computer spend rendering the image. However, I would recommend an image
size that would take at least five minutes to render, and preferably longer.
Multiply the resulting time by (baseline image area/rendered image area) to
get the time corrected for the image area.
we
of
>square? Or worse?
If antialiasing is not used, for sufficiently large images the only change
is in the number of rays traced, and since for large images, adjacent pixels
fire rays that follow similar pathes, and thus take similar amounts of time
to trace. This is only true if the parsing time is negligable for all
machines involved, or is not counted for the total time, as parsing time is
independant of image resolution.
Mark
