POV-Ray : Newsgroups : povray.general : #read fiasco Server Time
27 Oct 2026 15:01:40 EDT (-0400)
  #read fiasco (Message 1 to 50 of 102)
Goto Latest 50 Messages Next 50 Messages >>>
Subject: #read fiasco
Date: 8 Aug 1999 10:36:10
Message: <37ad95da@news.povray.org>
I wish that the documentation better explained the syntax for #read and
#write.
I have created a file of the positions and velocities of a number of
particles, (34 particles at 350 time periods).  I have pasted the first
four records from my file.
0,0,2.82488,1.88872,1.28931,-0.528847,-0.0413402,-0.84771
0,1,4.52083,2,3.26511,0.180401,-0.87059,-0.457743
0,2,2.46931,-1.21869,-0.8285,-0.187654,-0.372504,-0.90886
0,3,-2.75538,0.609548,-1.23555,-0.440196,-0.39602,-0.805851
The text file has the carriage returns already in it, as you can see. I
successfully used the following command to write this file:
#write
(MyFile2,tt,",",n,",",actorp[n][0].x,",",actorp[n][0].y,",",actorp[n][0].z,",",actorv[n][0].x,",",actorv[n][0].y,",",actorv[n][0].z,"\n"
But when I try to read the file, either superpatch for 3.1a crashes, or
it says something about expecting a variable but seeing a comma
instead.  I want to load this huge file into memory into two different
arrays, each with two subscripts.
According to my interpretation of the debug stream, when the program
gets into the second line of variables, it hangs up on about the third
variable. I am trying the following commands to read the file:
#fopen MyFile2 "c:\pov31\include\traillist.txt" read
#declare tt=0    ;
#while (tt<350*clock+1)
#declare n=0    ;
#while (n<num)
#debug "yeehah"
#read (MyFile2,l,m,px,py,pz,vx,vy,vz)
 #debug str(l,2,2)
 #debug str(m,2,2)
 #debug str(px,2,2)
 #debug str(py,2,2)
 #debug str(pz,2,2)
 #debug str(vx,2,2)
 #debug str(vy,2,2)
 #debug str(vz,2,2)
#declare actorp[tt][n]=<px,py,pz>;
#declare actorv[tt][n]=<vx,vy,vz>;
#declare n=n+1   ;
#declare tt=tt+1;
#fclose Myfile2
Thanks for any possible help.   This "one hour" doofy project turned
into a twelve hour battle with the software! I suspect the problem is
in the use of two-dimensional arrays, as a much simpler,
one-dimenstional array "reading" project works great.   If I may
politely state so,  the 3.1a documentation preaches to the choir too
often on syntax and rarely gives enough examples of how to actually use
the terms. In this case, I don't know how to read my file.
Subject: Re: #read fiasco
Date: 8 Aug 1999 10:59:32
Message: <37AD9B72.C4599B34@compuserve.com>
Look in the "fileio" folder in the demonstration scenes for some
examples.
Date: 8 Aug 1999 11:03:09
Message: <37ad9c2d@news.povray.org>
NOPE. Simplistic one-liner data files. I need to understand how to read
a larger number of variables.  Should there be a carriage return/ how do
you accomodate for it/  CAN you put into a 2-D array?
Anyone else?
> examples.
Date: 8 Aug 1999 11:24:13
Message: <37ADA0AB.274@geocities.com>
> #write.
it took me some time to understand this, but you need commas between
*all* data file entries for #read to work correctly. That includes
commas
at the ends of lines, too.
I hope this helps
Subject: BLESS YOU!
Date: 8 Aug 1999 12:33:01
Message: <37adb13d@news.povray.org>
That was the trick!  Will name next animation submission in honor of you!
 Was I negligent in not seeing this important detail in the documentation?
> > #write.
> commas
> I hope this helps
Date: 8 Aug 1999 14:10:47
Message: <37ADCB22.8CF1DAB8@erols.com>
> and #write.
> first four records from my file.
Generally, when I have an outside program generate data for POV-Ray,
I have the same program output a standard .INC file, with all of the
#declares, #locals, etc., needed for POV-Ray to parse the file directly.
This requires very little extra effort in the program that generates the
data, and the results parse a lot faster.
For instance, in my last IRTC entry, the insect parts were made of
bicubic patches, which I converted to meshes using a bit of macro
code.  I got tired of waiting for the macro to parse, so I modified the
macro to write the triangles to a file, in full POV syntax.  From then
on I merely #included the generated files, in place of the original
generating code.  Things parsed much more quickly.
John
Date: 9 Aug 1999 02:23:56
Message: <37ae73fc@news.povray.org>
John VanSickle <van### [at] erolscom> wrote:
: For instance, in my last IRTC entry, the insect parts were made of
: bicubic patches, which I converted to meshes
  I wonder why.
Subject: Re: BLESS YOU!
Date: 9 Aug 1999 05:32:13
Message: <37AEA020.7C3D7E8A@giwersworld.org>
	A better question, why in the world would the interpreter
require a comma and CR/LF at the end of a line? I can't say I've
seen everything in my time but that is not a rational data set
requirement.
Download 'us-ascii' (1 KB)
Date: 9 Aug 1999 06:00:57
Message: <37aea6d9@news.povray.org>
Matt Giwer <mgi### [at] giwersworldorg> wrote:
: 	A better question, why in the world would the interpreter
: require a comma and CR/LF at the end of a line? I can't say I've
: seen everything in my time but that is not a rational data set
: requirement.
  It doesn't require a comma and a CR/LF. It just requires a comma between
values. It couldn't care less about CR/LF's. It just ingores them.
: begin:vcard
  Please don't post this vcard crap here.
Date: 9 Aug 1999 08:48:33
Message: <37AECD93.333A1FDB@geocities.com>
So, like how would you make your inc if you had two variables which were
[350][34] each?
Would your file generator literally say:
#declare position.x[1][1]=1;
#declare position.y[1][1]=2;
#declare position.z[1][1]=3;
#declare position.x[1][2]=4;
#declare position.y[1][2]=5;
#declare position.z[1][2]=6;
I know how to write such a file, but wouldn't this make it a huge INC?  Are
you sure this is faster than reading with a #while loop the following data:
 1,2,3,4,5,6,
> > and #write.
> Regards,
> John
Date: 9 Aug 1999 10:18:01
Message: <37AEE28B.4228E453@geocities.com>
One more comment:  I am pretty sure the error message said something about an
unexpected PRESENCE of a comma; my problem was ultimately the
unexpected ABSENCE of a comma. I think if I had seen a different message, I would have
fixed the problem in a matter of minutes.
Is the error message stream correct?
> #write.
> #write
> #declare tt=0    ;
> #declare n=0    ;
> #while (n<num)
> #debug "yeehah"
>  #debug str(l,2,2)
>  #debug str(m,2,2)
>  #debug str(px,2,2)
>  #debug str(py,2,2)
>  #debug str(pz,2,2)
>  #debug str(vx,2,2)
>  #debug str(vy,2,2)
>  #debug str(vz,2,2)
> #declare n=n+1   ;
> #end
> #declare tt=tt+1;
> #end
> #fclose Myfile2
Date: 9 Aug 1999 11:03:48
Message: <37AEEDD8.E7936225@giwersworld.org>
> : requirement.
	That is the point. Absent the CR/LF any one corrupt data point
can currupt the entire result as everything is shifted only
point. Data number 23 replaces population value 290000 and
everything propagates in error from their on. But with CR/LF a
faulty data line is reported instantly.
	As I said, rational data set.
> : begin:vcard
	When the POV-team post that rule, I will delate it. Until then,
take it up with Mozilla.
	Please don't post that! Or are requests one way?
	If you have a problem, remember the Canadian Bacon grafitti.
<blink>-------please--don't-----------------</blink>
http://www.giwersworld.org/artii/
http://www.giwersworld.org/artiii/
Finally up on 99/06/22 updated 07/13
Date: 9 Aug 1999 11:28:19
Message: <37aef393@news.povray.org>
The difference: Warp's signature is 2 lines.  Way below the McQuary Limit.
Yours is six lines, which is already in excess of the limit, plus a mostly-
useless MIME attachment that eats up another 22 lines and incidentally adds
an extra step to reading your postings with text-mode newsreaders such as
slrn (which I use) that want to do the right thing with MIME-formatted
postings.  Just because some idiot at Nutscrape doesn't understand USENET
culture doesn't mean you have to meekly follow along.
Date: 9 Aug 1999 17:47:26
Message: <37af4adc.2344328@news.povray.org>
Ys, the vcf card is something of an annoyance.  I have Agent set up to save
and every now and again I have to delete all those dratted vcf cards.  There is a
temptation to filter out the offending users, but I have resisted this because this
would
mean missing some of Matt's more interesting postings :-)
David
dav### [at] cwcomnet
http://www.hamiltonite.mcmail.com
Date: 9 Aug 1999 17:49:16
Message: <37AF4FC2.D6811FA0@erols.com>
>   I wonder why.
Most of the bug parts had 12 bicubic patches in them, but others had
16, and I think one has 20.  There are 128 triangles per patch, and each
bug had roughly 30,000 triangles in it.  The use of meshes achieved a
memory savings of about 4.5 megs per bug.
They also parsed more quickly this way.
John
Date: 10 Aug 1999 11:42:34
Message: <37B03D85.F5822236@ndirect.co.uk>
Mat
It's very annoying, and the information on both your own card and
that of SamuelT another offender could be put in text format
without taking up so much bandwidth.
Most annoying is when I've got a render going and I'm reading
news groups and every time I open one of your messages, the
message comes up and then I see something else loading, scrole to
the bottom of the message and it's a bloody VCard.
I havn't mentioned this before, because I feel that your
contributions to these groups are positive.
> > : requirement.
> > : begin:vcard
> > main(i,_){for(_?--i,main(i,"FhhQHFIJD|FQTITFN]zRFHhhTBFHhhTBFysdB"[i]
Steve
%HAV-A-NICEDAY Error reading file mailto:sjl### [at] ndirectcouk
Date: 10 Aug 1999 16:40:45
Message: <37B0914C.B43E620D@erols.com>
> > > #read and #write.
> > > of particles, (34 particles at 350 time periods).  I have pasted
> > > the first four records from my file.
> > directly. This requires very little extra effort in the program that
> > generates the data, and the results parse a lot faster.
> > the macro to write the triangles to a file, in full POV syntax.
> > From then on I merely #included the generated files, in place of the
> > original generating code.  Things parsed much more quickly.
> were [350][34] each?
No, the file generator can also dump out the following:
#declare position=array[350][34] = {
  { <1,2,3>,<4,5,6>, ... }, {... }, ...
The PovRay code would look like this:
// START OF SAMPLE BASIC CODE
#write(MyFile,"#declare position=array[", ROWS, "][", COLUMNS, "] = {\n")
#local iI=0; #while(iI<ROWS)
  #if (iI>0) #write(MyFile,",") #end
  #write(MyFile,"{ ")
  #local iJ=0; #while(iJ<COLUMNS)
    #if (iJ>0) #write(MyFile,",") #end
    #write(MyFile,MyDataArray[iI][iJ])
  #local iJ=iJ+1; #end
  #write(MyFile, " }\n" )
#local iI=iI+1; #end
#write(MyFile, "}\n" )
// END OF SAMPLE CODE
Your file generating program can print out the #declares, square
brackets, angle brackets, squiggly brackets, commas, and so forth.
The only difficulty is that if you want to have text data in there as
well, you have to explicitly print out the quotes with the CHR$()
function:
  #write(MyFile, "#declare MyString="; CHR$(34); "Stormbringer";
    CHR$(34); "\n")
which will create a line of text that looks like this:
  #declare MyString="Stormbringer"
You can feed a vector to the #write() directive as well; my example does.
  #write(MyFile,x-y+z*3)
will cause the string
  < 1,-1, 3>
to be written to MyFile.  There is no need to bust up the vectors into
scalars, only to build them back up later.
Of course, keeping track of the brackets and quotation marks can be
a bit of a trick. :-)
As you can see from my response, it will not be very much larger than
the file you already plan to use.  It might be twice as big, but that's
what we have hard drives for.
> Are you sure this is faster than reading with a #while loop the
> following data:
>  1,2,3,4,5,6,
Yes, it is much faster.  The file is generated in a form the parser
already knows how to understand; the other method you discuss goes
through a #while-#end loop, which takes extra time in any interpreted
language.
Hope this helps,
John
Date: 10 Aug 1999 20:08:06
Message: <37B0BEEA.FD225D80@peak.edu.ee>
What can a vcard do that a sig can't, anyway?
Margus
Date: 10 Aug 1999 20:11:53
Message: <37B0BF84.E1832F8A@pacbell.net>
> Margus
Irritate people ?
Ken Tyler
See my 700+ Povray and 3D Rendering and Raytracing Links at:
Date: 10 Aug 1999 20:33:32
Message: <slrn7r1h96.mo.parkerr@linux.parkerr.fwi.com>
On Tue, 10 Aug 1999 17:10:44 -0700, Ken <tyl### [at] pacbellnet> wrote:
>> Margus
>Irritate people ?
As a counterexample I offer Warp's sig. >:)
Date: 10 Aug 1999 22:30:01
Message: <37B0E02C.41D53827@peak.edu.ee>
Oh yes it can. Don't even get me started here...
Margus
Ken wrote:
> > Margus
> Irritate people ?
> Ken Tyler
Date: 10 Aug 1999 22:31:09
Message: <37B0E07F.5EF61D32@giwersworld.org>
Steve wrote:
> Mat
	Taking up bandwidth. I haven't heard that one seriously
suggested in nearly ten years. In all my posts to all these
newsgroups on the POV server probably do not add up to one image
binary.
	Why would you be looking for an image except in the binaries
newsgroup?
	Thank you for saying that but you can always filter me out. No
skin off my nose.
Date: 10 Aug 1999 22:31:50
Message: <37B0E0A9.DF80807E@giwersworld.org>
	I thought no one would ever ask.
	For me it is a lack of annoyance. I appreciate them. What does
annoy me to no end is exactly the same sig words over and over
and over. And the more clever the faster the annoyance increases.
	From the BBS days, one of the main selling points of the offline
readers was rotating sigs.
	The Vcard is a different solution by encapsulating all the sig
words, read them if you wish and only if you wish.
	There have always been problems of backwards campatibility of
new ideas with old.
Date: 10 Aug 1999 22:35:21
Message: <37B0E17B.868EAB3A@giwersworld.org>
	When .com domains were permitted, internet culture began a
permanent change that will never turn back. In the last seven
years, the old "internet culture" has been reduced to 20% at most
if all students are counted regardless of using it or not, not
counting intranets. Four years ago I read some university-type
hand-wringing over the cost of converting to graphics terminals
to keep up with the changes.
	I am hardly sympathetic to people who try to turn back the clock
by claiming a company with maybe 40% of the installed market
doesn't understand. And the other big chunck of the installed
market is Free Agent. Shall the world go backwards because
universities have not paid to move forward?
	I don't see why this newsgroup should be used to debate the
merits of progress. If people want to use UNIX they take
everything that comes with it and does not come with it. If it
doesn't come with a newsreader compatible with current more
popular apps that is part of the consequences of using Unix.
	So those of us who can use new features should not because of
what is not available in Unix? Was l&oumlaut;ss mit diese Bild?
	BTW: ARPA probably still maintains my 1972 account. You know how
the government never throw things away.
Subject: [Profane] Re: BLESS YOU!
Date: 10 Aug 1999 23:02:19
Message: <37B0E7E2.EE3@unforgettable.com>
Matt Giwer wrote:
> Steve wrote:
> > Mat
> binary.
> newsgroup?
> skin off my nose.
Dear Matt:
Kindly go fuck yourself. Now.
Take your VCard with you.
Thank you.
-Xplo
Subject: Re: [Profane] Re: BLESS YOU!
Date: 10 Aug 1999 23:06:14
Message: <37B0E8B9.2376D121@giwersworld.org>
Xplo Eristotle wrote:
> > skin off my nose.
> Dear Matt:
> Thank you.
	Have you considered the fact that some children do read this
newsgroup?
Date: 10 Aug 1999 23:10:21
Message: <37B0F8B6.4212DB9E@pilot.msu.edu>
I'd hate to offend anyone, but aren't you the people who get all annoyed
when a thread gets way off topic?  Well this is off topic.  Take your
signatures and fight elsewhere.
> : requirement.
> : begin:vcard
Date: 11 Aug 1999 01:43:01
Message: <37b10d65@news.povray.org>
Nobody here appreciates your abuse of this server or them.  If you don't
have anything constructive to say, kindly packup and leave.  I'm sure the
owners of this server won't take kindly to your abuse of it or other
people...
Xplo Eristotle <inq### [at] unforgettablecom> wrote in message
news:37B### [at] unforgettablecom...
> Dear Matt:
> Thank you.
> -Xplo
Date: 11 Aug 1999 02:34:16
Message: <37b11968@news.povray.org>
: 	Have you considered the fact that some children do read this
: newsgroup?
  Yes, it seems that there's at least one child reading this newsgroup: You.
Date: 11 Aug 1999 02:36:34
Message: <37b119f2@news.povray.org>
Ron Parker <par### [at] fwicom> wrote:
: As a counterexample I offer Warp's sig. >:)
  At least my sig can be posted without multipart mime-encoding...
  And anyways, it's a good signature. It has my nick. Twice. ;)
Date: 11 Aug 1999 02:40:39
Message: <37b11ae7@news.povray.org>
: 	The Vcard is a different solution by encapsulating all the sig
: words, read them if you wish and only if you wish.
  Only if you use certain brwosers to read the news.
: 	There have always been problems of backwards campatibility of
: new ideas with old.
  That's like saying that windows sucks because it can't run unix programs.
  Come on. Get a life.
Date: 11 Aug 1999 07:38:27
Message: <37B16026.DC119B68@geocities.com>
Thanks for the exhaustive reply.  I was about to ask what one could do if one
had TWO variables, but I guess that I can simply turn my two 3D arrays into
one 6D array.
>   #write(MyFile,"{ ")
> function:
>     CHR$(34); "\n")
>   < 1,-1, 3>
> Hope this helps,
> John
Date: 11 Aug 1999 07:48:20
Message: <37B16278.43468FB2@geocities.com>
My browser can use html; those of many others cannot.  At first I thought it
was only the Luddites who were emailing me to complain that their stone-age
browsers weren't able to handle html.  Then I realized that I was guilty of
Micro-____-ism: inconveniencing others to accomodate my bells and whistles,
and calling it progress.  I later viewed it as a courtesy to the group not to
//resist
//resist
//resist the temptaiton to underline and boldface the next phrase with html
codes
*emphasize*
//whew, that was close!!
a word in every paragraph if it made things difficult for some friends with
outdated or no-frills browsers.
> new ideas with old.
>   Owner
>   Images Incarnate
>   Matt Giwer
>   Owner                                      <mgi### [at] giwersworldorg>
>   Images Incarnate
>   14205 Nebraska Ave #27;Tampa;FL;33613;USA  Cellular: 813-694-3998
>                                              Work: 813-972-2574
>   Additional Information:
>   Last Name      Giwer
>   First Name     Matt
>   Version        2.1
Date: 11 Aug 1999 08:58:41
Message: <37B173AB.7513@unforgettable.com>
> people...
To judge from the way Matt gets away with saying "if you don't like my
lousy netiquette, filter me", the owners of this server don't seem to
care.
I wonder if I could get Usenet posters to use this guy's email address
as spam bait. After all, if he doesn't want to receive all that spam, he
can just filter it.. no skin off his nose. :P
-Xplo
Date: 11 Aug 1999 09:15:04
Message: <37B1775D.47924A2A@giwersworld.org>
> : newsgroup?
	If you do not like my posts, at least have the courtesy to shut
up. If you do not want to be boethered by them, filter them out.
	I do not feel myself graced by complainers reading them.
	Is this clear enough?
	And if you can not have your way by everyone complying with your
wishes you are going to hurl insults, upon what do you base your
moral superiority save your love of your ancient tin?
<blink>---please--don't---</blink>
Oh my God! They've rendered Kenny!
Date: 11 Aug 1999 09:22:22
Message: <37B17912.2590D3CE@giwersworld.org>
> care.
	"Filter" is the power of any user.
	And IF the owners tell me about it, fine. Then I can choose to
change or not to participate. That will be MY choice.
	Your choice is to filter or not to filter. You read my posts on
my terms, not yours.
	Not that is an interesting threat and your email addr as
instigtator is quite interesting. And your post is forwarded to
your ISP.
	If I do not comply with the dicatations of mere users of this
you folks are going to get me spammed.
	Let me tell you this, boy. IF that happens, you all will regret
it. And I can do it in a heartbeat. And I will not do one direct
thing.
	Are petty little Hilters going to try to enforce your will on
everyone else or are you going to grow up and join the human
race?
	You newcomers should never think you know what the internet is
all about.
Date: 11 Aug 1999 09:27:28
Message: <37B17A45.8E2FE2BB@giwersworld.org>
	Is that a good thing or an old fart stick in the mud position?
	And that is a good thing? To post something as a sig that only
those familar with obscure legal but unprofession C code can read
if they want to waste the time?
	Please explain why and exercise in obscurity is a good thing.
	Yes, you are very clever. Yes you are a horrible example of the
art of programming.
Date: 11 Aug 1999 09:28:26
Message: <37b17a7a@news.povray.org>
On Tue, 10 Aug 1999 22:35:39 -0400, Matt Giwer wrote:
>This is a multi-part message in MIME format.
>--------------353C53C99B3BCF3BB8CA77D4
>Content-Type: text/plain; charset=us-ascii
>Content-Transfer-Encoding: 7bit
Learn some history, then come tell me about the Internet.  If you
can find me.  It wasn't .com that changed the world, it was aol.com
and netscape.com in particular.  And it wasn't for the better.
Bzzzt.  trn is in the #2 spot, with almost as many users as Nutscrape.
In most non-alt groups, the proportion is higher for trn.
Date: 11 Aug 1999 09:30:49
Message: <37B17B0F.CA7D010D@giwersworld.org>
	Variety is something we cherish in the modern world. Only
Communists and Nazis said everyone had to be the same.
	And you have a filter. USE IT!
	Use your filter to stop reading me instead of trying to play
hitlerite dictator. FILTER! FILTER! FILTER! And go away.
	What a horrible example of programming. And BORING!
Date: 11 Aug 1999 09:46:41
Message: <37B17EC6.83C08146@giwersworld.org>
	I am inconviencing no one with their high powered newsreaders.
They can all filter me out. If they choose to be inconvenienced
they have no business complaining.
	If they WANT to read my posts then they put up with the
inconvenience.
	So far I have been told there are all of exactly THREE people
who have a problem.
	I do not care if no one reads what I post.
	If you want to understand this all, go read The Fountainhead and
Atlas Shrugged.
	How else explain my being "given a chance" to post without the
format they demand. Was that so nice of him in response to saying
FILTER?
	Some clown with an anal fixation knowing children are reading
this wants to insert pages of the RFC because IN HIS OPINION not
the committee's it is non-compliant. Is that not cute?
	And let me ask in general, how long these folks have been into
computers, programming, the ARPAnet? I have 32 years in October
and it would have been 34 years except I turned down a job offer
at Oak Ridge to finish college. Anyone here want to play, "match
the credentials"?
	I would rather this whole thing drop and folks with those highly
superior newsreaders just use their filters. If the newsgroup
owners contact me to the contrary that is a different issue. And
then my above choice.
	But I really do not like users presuming to dicate to other
users based upon their own choice of software and their own
arrogance.
	Any questions?
Date: 11 Aug 1999 09:48:12
Message: <37B17F22.C0E5A9F2@giwersworld.org>
	I wish they would but I am not one to put up with rude and
arrogant.
	Does this post bother you? Not the content, the format.
Date: 11 Aug 1999 10:01:54
Message: <37b18252@news.povray.org>
Matt, I was pretty much ignoring this spat until I noticed that threat. I
agree that it is way out of line and you should protect yourself as best you
can. I can't believe someone would do something like that over one KB of
what, to them, is text.
Just goes to show you that road rage is not all on the road. We must now
drive defensively on the Information Highway. To carry a trite allusion even
further, many who drive '68 Datsuns resent those who drive SUV's and have to
do something to be able to look down on them. Info-terrorism is going a
little too far.
Until now I have not looked at your v-card, and I just now compiled "Warp"'s
sig... not a big deal either way. But as a libertarian I feel that both of
you should carefully do exactly what you want to do and then I will make
plans to do things on my end as a result of that. Unless you send code that
is invasive like a virus, folk should learn to deal.
Matt Giwer <mgi### [at] giwersworldorg> wrote in message
news:37B17912.2590D3CE@giwersworld.org...
> > care.
> your ISP.
> thing.
> race?
> all about.
Date: 11 Aug 1999 10:08:56
Message: <37b183f8@news.povray.org>
I can't see Matt's posts any longer, of course, but for once I agree with him.
Such a threat was way out of line.
Actually, I don't want to kill Matt's posts.  Maybe in a few days I'll sit
down with the source to slrn and figure out how to filter out vcards.  That
would be the productive solution, wouldn't it? :)
Date: 11 Aug 1999 10:24:58
Message: <37B187BC.BB7EDCCE@giwersworld.org>
	I do not mean to prolong this but it looks like there is some
sense showing here. All that ie required for idiocy to prevail is
for the intelligent to remain silent. There are these petty
little stalins and maos that want their way or the gulags for
those who do not bow down.
> little too far.
	I have a different opinion on the US 1st amendment and several
of the items in the UN Universal Declaration of Human Rights. If
they insist on the personal right to violate them, they are
anti-american and anti-human rights. They should live in the
Gulags they sent tens of millions of others.
	Aa a fellow registered Libertarian since it was possible in
Virginia I have not patience with these petty little dictators.
And IF I should suffer a spam attack, I will publish here exactly
how to innocently get their email addrs into the spammers email
lists.
	It is so obvious if you think about it.
Date: 11 Aug 1999 10:40:37
Message: <37b18b65@news.povray.org>
: 	Are petty little Hilters going to try to enforce your will on
: everyone else or are you going to grow up and join the human
: race?
  It is a general rule that people don't send binaries or mime attachments
to non-binaries group. Everyone agrees with this rule.
  Now you have this strange obsession about your useless vcard which you
send to every newsgroup, thus breaking the rule. Then you expect everyone
to just shut up and accept the exception in your case.
  Your attitude about defending your vcard is just plain childish. You just
tell people to shut up and to "upgrade" their "ancient" newsreaders (by
the way, this newsreader version was released 25 December 1998; quite
ancient...).
  So because you have this obsession about some useless mime attachment
which serves absolutely no purpose, you want everyone to change the
netiquette of posting to non-binaries groups and to "upgrade" to "newer"
newsreaders.
  The funny thing is that there exists no real reson for your obsession.
A regular signature works just fine and it's much more easy to read for
most of people. There's no reason for you to stop sending mime-formatted
articles and start posting just plain text. It's only an obsession.
  You talk about growing up. Perhaps you should look at the mirror.
Date: 11 Aug 1999 10:53:01
Message: <37B18E4D.379CDEB9@giwersworld.org>
	Did your great-great grandfather hate Henry Ford for ruining his
buggywhip business?
	As to learning history, only AOL 4 started using internet
protocol so that is was no mroe than an ISP gateway. Log on to
AOL and use Eudora and everything else just like a real ISP.
	And with all the lawsuits and legally (and tax deductable
upgrades) it is the most reliable and available ISP in the US.
And you never have to use an AOL utility. Want to keep running it
down?
	Your opinions are yours and like elbows. Everyone has at least
two of them.
	BS to trn. Only in the primitive university market without
graphics.
	There are dozens of websites courtiously logging hits by
newreader. tin is in the noise. Look it up. I am not motivated to
deal with such nonsense.
	Try it simply this way. Almost EVERY commerical ISP offers
something Win or Mac compatible.
	By every industry measure 90% of the installed market in the US
is Win or Mac. Reported usage is 80% Win or Mac.
	tin trn and all the varients are in that 10-20% of the rest.
	Don't kid yourself. REad the industry news.
	Guess what? The current Linux convention expects to draw 20,000
up from 12,000 last year. Now I tell you, that is a real
installed base.
	If you have been having your fun BSing the newcomers on this
newsgroup that is your business.
	Do not expect me to put up with it. It is likely I have been in
this business since before you were born. And given the
demographics of the computer business ... please, arrogance is
part of being a programmer. What else am I exprssing?
	I have no ego impressing someone else. My only ego is when
someone uses what I say and then tells me something I did not
know. That is my one indication of success. Nothing else.
Date: 11 Aug 1999 10:56:29
Message: <37B18F9E.6088F287@geocities.com>
Obscure sigs have long been a time-honored tradition in the Internet
community. (now that the video's out, I think I have to change mine).
"My new computer's got the clocks, it rocks
But it was obsolete before I opened the box" - W.A.Y.
Date: 11 Aug 1999 10:59:56
Message: <37b18fec@news.povray.org>
: 	And that is a good thing? To post something as a sig that only
: those familar with obscure legal but unprofession C code can read
: if they want to waste the time?
: 	Please explain why and exercise in obscurity is a good thing.
: 	Yes, you are very clever. Yes you are a horrible example of the
: art of programming.
  First of all, you should read http://www.ioccc.org/. I quote:
>     Goals of the Contest
>     To write the most Obscure/Obfuscated C program under the rules below.
>     To show the importance of programming style, in an ironic way.
>     To stress C compilers with unusual code.
>     To illustrate some of the subtleties of the C language.
>     To provide a safe forum for poor C code. :-)
  Signatures are not part of a contest, but you should get an idea about
what's the mentality behind obfuscated C (or any other programming language).
  Signatures usually contain information about the sender, but often they
also have some interesting things, like quotes, url's, jokes, etc.
  My signature is intended to be a kind of riddle (in the context of
obfuscated C). Often someone gets curious about what does it do and then
tries to compile and run it and gets surprised. Sometimes these people
write to me asking me how is it done. They feel the joy of discovering
something unexpected.
  The signature seldom offends or annoys anyone. It's just 2 lines long,
it's always located at the very end of the text and it doesn't add anything
else to the article. That is, it doesn't disturb the reading of the article.
Everyone can (or at least should) see that it's just a signature.
  And besides, why do you whine about the _contents_ of my signature? I
have never said anything about the contents of your signature. It's only
the way you send it which is annoying. There should be absolutely no reason
to blame anyone for the contents of his/her signature.
  However, if I use a gif as my signature and send it uuencoded or
mime-encoded, that's not good anymore.
Date: 11 Aug 1999 11:04:11
Message: <37B190EC.81BD41F9@giwersworld.org>
> : race?
	Since when is MIME encapsulation a binary? Can you direct me to
an rule of the owners of this newsgroup prohibiting it? IF not
why are you trying to recreate your own primitive non-graphic
environment?
	Where do the owners of this newsgroup have that rule stated?
Please state EXACTLY where that rule is stated.
	I have no obsession with it. I have an interest that your rude,
crude and close to vulgar objection to it was expressed. I do not
take carp seriously.
> ancient...).
	Ancient and primative appear to have different meanings. It
appears the creators of your 1998 version srs still using stone
axes.
> newsreaders.
	FILTER ME PLEASE!!!!!
	I do not want to bother you in the least. So FILTER me.
	You insist upon being offended and then complaining about it.
	Filter me and go away. You are not worth a fingernail to me.
	But you will not as you imagined hitlerite control of this
newsgroup would be challenged if you could not respond to me.
	What in the hell is your excuse for not filtering me instead of
being rude to me which started all this?
	Give it your best shot.
Date: 11 Aug 1999 11:05:42
Message: <37b19146@news.povray.org>
: 	Variety is something we cherish in the modern world. Only
: Communists and Nazis said everyone had to be the same.
  That's exactly the reason why you should take into account those who
are using newsreaders which are not able to handle every kind of attachments.
Not everyone can or want to use the same newsreader as you do. If you don't
consider other people who are using other newsreader, you are very impolite.
: 	Use your filter to stop reading me instead of trying to play
: hitlerite dictator. FILTER! FILTER! FILTER! And go away.
  And the reason for insulting me in this way: A vcard.
  How old are you?
