POV-Ray : Newsgroups : povray.general : Looking for stereopair->HF software Server Time
6 Nov 2026 22:52:14 EST (-0500)
  Looking for stereopair->HF software (Message 1 to 15 of 15)
Subject: Looking for stereopair->HF software
Date: 3 Aug 1999 09:40:18
Message: <37a6f142@news.povray.org>
Hey, Unka Ken (or anyone else).
I find myself in need of software that can take a stereo pair and generate
a credible heightfield from it.  It doesn't have to be perfect; I expect to
have to do some editing.  I know such software exists, because it's used to
create DEMs, but I've never seen any available to the public.  If anyone
knows of such software, particularly if it's free, please please let me
know.  Thanks!
Subject: Re: Looking for stereopair->HF software
Date: 3 Aug 1999 21:53:13
Message: <37A79C5E.1E3150D3@pacbell.net>
> know.  Thanks!
Unka Ken gotta no clue. Neer heara such a thinga that. Whatcha wanna for anyway ?
Ken Tyler
mailto://tylereng@pacbell.net
http://home.pacbell.net/tylereng/links.htm
Date: 4 Aug 1999 09:10:23
Message: <37a83bbf@news.povray.org>
>> know.  Thanks!
You can't see thousands of uses for it just off the top of your head?  I
actually found one example of such software, but of course it's an expensive
high-end GIS package.  Its official use is to take two or more aerial
photographs and generate a DEM from them, which could then be used as a
heightfield in POV or for more sophisticated uses in watershed analysis or
other high-minded environmental pursuits.  My goal is somewhat more
pedestrian: I have a friend who teaches earth science to seventh-graders.
One of their favorite projects is the one where they build clay mountains,
then submerge them to various depths and draw the contour lines.  I was
looking for free or inexpensive software that could be used with a digital
camera to automate the process, so they can see how it's done in the digital
age.  I figured that if such a thing existed, one or more of you 3d guys
would know where to find it.  Unfortunately, I'm beginning to  believe that
there is no such thing after all.
Date: 4 Aug 1999 10:31:08
Message: <37A84EE0.6F6810D2@xs4all.nl>
Sounds like fun...
I was
> age.
And derive them of the fun?
I know someone who will probably know such a package but it's likely to be same
as the one you found, or similar like in expensive.
I thought it shouldn't be hard to make such a program if you know exactly what
to use it for (straightforward). Then I thought, the problem is probably not the
program (that's just calculating a parallax or what-do-you-call-it), but the
photography. You have to know the exact location of the camera at two points.
Also, you'll probably need quite a high resolution to get a result with a
reasonable amount of details. If the photo-part is not a problem I can't imagine
that the programming-part would be (not for you, would it?).
Remco
http://www.xs4all.nl/~remcodek/
Date: 4 Aug 1999 10:46:30
Message: <37a85246@news.povray.org>
On Wed, 04 Aug 1999 16:32:00 +0200, Remco de Korte wrote:
>I was
>> age.
Not at all.  They'd still do it the old way and have the opportunity to
get messy, they'd also get to see another way of doing the same thing,
perhaps with some cool POV visualization and some more advanced watershed
management stuff (flow lines, etc.) thrown in courtesy of GRASS.
High resolution is likely to be necessary, yes.  I'm not sure about knowing
the exact location of the camera.  Separation distance, distance from the
terrain, and some info about lens geometry might be necessary, true, unless
you were willing to cheat and feed it elevations for the summit and the
lowlands and let it scale its results to fit.  I think even USGS cheats by
putting reflective markers at known locations in the area to be photographed,
so that rectification can take place separate from stereocorrelation.
Unfortunately, I did some experiments and it's much more difficult than it
looks to recover the parallax information.  And of course I wouldn't want
such a project to take time away from valuable pursuits like the superpatch. :)
Date: 4 Aug 1999 11:01:21
Message: <37a855c1@news.povray.org>
Eh..er..um... there is something which is somewhat like this...
http://www.photomodeler.com
Ron Parker <par### [at] fwicom> wrote in message
news:37a83bbf@news.povray.org...
generate
expect to
used to
anyone
> >> know.  Thanks!
anyway ?
expensive
digital
that
Date: 4 Aug 1999 11:27:25
Message: <37a85bdd@news.povray.org>
I looked at photomodeler yesterday, actually.  It looks like a neat
program, but it does two things that don't work for me: it only seems
to work with polygonal data, and it requires me to identify and
correlate the salient features.  Stereocorrelation software doesn't
have those limitations.
Date: 4 Aug 1999 12:08:45
Message: <37a8658d@news.povray.org>
Well, I am sure you are right in the large scale, and not that I really
understand what you are talking about, but I wonder if for the expedient of
making some models for school children, if it might be made to suffice
somehow.
Barring you actually finding what you really want, of course...
news:37a85bdd@news.povray.org...
Date: 4 Aug 1999 13:28:25
Message: <37a87839@news.povray.org>
Ron Parker heeft geschreven in bericht <37a85246@news.povray.org>...
Imagine a glass plate, on both sides is a painted dot.
Set up the cameras and set focus between both dots, this is the average object
distance (Od). Measure the distance between the two cameras, centere of lens to
centre of lens. This is the StereoBase (Sb). You also need the distance from the
lens to the film plane (Id). Next, measure the parallax between the points in
your pix. Then multiply the parallax by Od^2/Sb*ID. This gives the depth between
the two dots on the glass (thickness of the glass)
Biggest problem for the software is to find the corresponding pixels in the two
pictures. I've done this lots of times by hand. I use a kite plus sterocamera to
do some aerial photography.
http://rst.gsfc.nasa.gov/Start.html
This is a site on remote sensing, I have not explored it yet but chapter 11 is
about stereo stuff.
ingo
Met dank aan de muze met het glazen oog.
Date: 4 Aug 1999 14:13:26
Message: <37a882c6@news.povray.org>
That's the part I'm concerned about, actually.  I can generally figure out the
rest from scratch when I need it (That's not to say that I won't just use what
you've derived instead... I will.)  I assume that real-world software does this
by sliding a window across the right image and doing some sort of statistical
correlation with a fixed window on the left image, but I haven't been able to
create anything here that gives me satisfactory results.  That may be due to
a lack of good data, however.  I will keep trying, of course.  I won't actually
need any of this stuff for at least six months, and if I don't have it the
world won't end.
>about stereo stuff.
Thanks, That's a very nice site in and of itself, though I didn't find anything
I could use at the moment.  Nevertheless, I will be passing it along to my
teacher friend to add to the website she's making for her students as a
starting point for independent study.
Date: 4 Aug 1999 14:18:13
Message: <37A88325.5BA41F1F@pacbell.net>
Take a peek at:
http://www.usna.edu/Users/oceano/pguth/website/microdem.htm
Ken Tyler
Date: 4 Aug 1999 14:24:10
Message: <37a8854a@news.povray.org>
On Wed, 04 Aug 1999 11:15:01 -0700, Ken wrote:
>Take a peek at:
Nice, but not exactly what I'm looking for.  I already have a
program that consumes DEMs, I'm looking for one that produces
them.  It's looking more and more like I'll have to write my
own, unless the Open Source Remote Sensing project gets around
to writing something usable soon.  Of course, if I do succeed
in writing my own, I shall donate the source to that project.
Date: 4 Aug 1999 16:21:51
Message: <37A8A025.743B8D1B@pacbell.net>
Someone who may know of some software for your needs would be John Beale.
I have found him approachable in the past and if anyone knows he probably
does. Email him at bea### [at] bestcom
Ken Tyler
Date: 4 Aug 1999 16:25:31
Message: <37a8a1bb@news.povray.org>
Thanks, Ken, I'll give that a try.
Date: 4 Aug 1999 16:43:42
Message: <37a8a5fe@news.povray.org>
Ron Parker heeft geschreven in bericht <37a8854a@news.povray.org>...
>...... I already have a
>them.
I did a search for photogrammetry  and  softcopy, found
http://wwwphoto.eng.ohio-state.edu/DPclasses/
http://www.rwel.com/dms.htm
http://www.virtuozo.com.au/Welcome.html
and lots of high-end stuff and lots of papers.
ingo
