POV-Ray : Newsgroups : povray.general : Calculating patricle field density Server Time
6 Nov 2026 22:52:11 EST (-0500)
  Calculating patricle field density (Message 1 to 21 of 21)
Subject: Calculating patricle field density
Date: 29 Jul 1999 23:10:06
Message: <37a214ad.8986978@204.213.191.228>
How do I calculate the density of a particle field in some point in
space? Suppose that the positions of all particles are stored in an
array.
Peter Popov
ICQ: 15002700
Subject: Re: Calculating patricle field density
Date: 29 Jul 1999 23:27:54
Message: <37A11BC9.FE29C5F2@compuserve.com>
Calculate the distance from each particle, and use an equation like
1/distance^2(depending on what you want) for each particle, and add the
amount of contribution from each particle(not average). Getting the
distance and calculating is sometimes not much slower than skipping
particles beyond a certain distance, although that may help.
Date: 29 Jul 1999 23:59:19
Message: <37A12272.AB82E461@pacbell.net>
> array.
> Peter Popov
> ICQ: 15002700
 Just for kicks you might take a look:
http://www.sbox.tu-graz.ac.at/home/a/ahi/particle-system.html
Ken Tyler
mailto://tylereng@pacbell.net
http://home.pacbell.net/tylereng/links.htm
Date: 30 Jul 1999 07:45:50
Message: <37A1907F.FC3C434E@compuserve.com>
Tnanks Ken(I know, it wasn't me who you were answering). That link looks
helpful. Got any others on particle simulation?
Mr Popov: I am also making a particle simulator, and it is almost to the
point of building "superparticles" out of particles, like molecules out
of atoms. No competition for yours though, mine is written in C++.
(yours is written in POV, right?)
Date: 30 Jul 1999 07:52:19
Message: <37A191C6.51BA01AE@numerik.uni-kiel.de>
> > array.
> > Peter Popov
> > ICQ: 15002700
> Ken Tyler
I have one question:
Any idea why the particles are converted to blobs by Andreas?
Just a point to add, Peter and I continue the mail/news-mixed
conversation:
Calculations like these can be done with octave.
http://www.che.wisc.edu/octave/
It's GPL (Peter, you can drop the price of Matlab) and a Matlab clone.
Nice features:
Vectorisation of almost any operation. You can do the integration of one
timestep for all particles at a time, for example.
Nice as well is the vectorized sprintf. It gives you a formatted output
as often as your input suffices. A one-liner just to convert all
particles to blobs.
So much hype is enough...
Axel
Date: 30 Jul 1999 07:53:15
Message: <37A19189.54044DFE@pacbell.net>
The fun, smart, bounce stretchy stuff page has some info on it I beleive:
http://freespace.virgin.net/hugo.elias/
Pual T. Bourk always has usefull info:
http://www.mhri.edu.au/~pdb/rendering/software.html
Colefax has an include file doesn't he ?
http://www.geocities.com/SiliconValley/Lakes/1434/
You might take a quick peek at Daniel Skarda's links page:
http://atrey.karlin.mff.cuni.cz/~0rfelyus/bookmark.html
Also see my links in the announcement group in the 3d resources section.
I recall more info available in those sites but I don't have time to
track them all down for you.
Luck,
Ken Tyler
Date: 30 Jul 1999 08:05:56
Message: <37A19534.FD193C62@compuserve.com>
beleive:<
Not enough, unfortunately. I have already scoured that one for info.
>Pual T. Bourk always has usefull info:<
Now that looks useful. I had seen one of his pages then lost it.
>You might take a quick peek at Daniel Skarda's links page:<
Another that I had lost.
Thanks!
Date: 30 Jul 1999 08:13:41
Message: <37A19653.49EB2BAD@pacbell.net>
See specificaly : http://www.mhri.edu.au/~pdb/modelling/particle/
> Thanks!
No problem sir.
Ken Tyler
Date: 30 Jul 1999 08:14:28
Message: <37A19734.26C5764A@compuserve.com>
Looks like my other message didn't go through...
Anyway, the blobs make the water drops merge together similar to real
droplets, the LiquidSpray include file also does it. My particle
simulator takes a different approach, and outputs calls to a macro,
which allows me to easily vary the results without re-simulating the
model.
Date: 30 Jul 1999 08:15:44
Message: <37A196CE.F5964781@pacbell.net>
Axel Hecht wrote:
> Hi,
I'm not even sure where I found that site and since it has no executables
I havn't looked at it too closely. It is provided by me mostly as an aid
to others that might want to look into it's possiblities.
Ken Tyler
Date: 30 Jul 1999 08:22:55
Message: <37A19930.5AC04947@compuserve.com>
Ah, some good force equations I can use. Variables I hadn't even thought
of. Thanks!
Date: 30 Jul 1999 13:24:08
Message: <37A1DF14.C52A5E76@pacbell.net>
Chris Huff wrote:
> and it is almost to the point of building "superparticles" out of particles,
> like molecules out of atoms.
A single Feyman checkerboard configuration is one of all possible ways
for an electron to go from an initial point to a destination point.
choice of a particular single configuration is a random quantum choice.
Read on: http://www.innerx.net/personal/tsmith/ficw.html
Ken Tyler
Date: 30 Jul 1999 18:50:52
Message: <37A22A71.F73D7588@ndirect.co.uk>
The force is either with you or it isn't, no equations required.
> of. Thanks!
Steve
%HAV-A-NICEDAY Error reading file mailto:sjl### [at] ndirectcouk
Date: 30 Jul 1999 19:45:12
Message: <37a33721.31435718@204.213.191.228>
On Fri, 30 Jul 1999 06:46:09 -0500, Chris Huff
Err... mine is still being written in POV, to be correct ;) More than
half of it is done, but I am foreseeing troubles putting it all
together. As the Russian like to say, "We'll live, we'll see." :)
Peter Popov
ICQ: 15002700
Date: 30 Jul 1999 19:47:10
Message: <37a437a6.31569131@204.213.191.228>
This is clearly the best page on the topic that I have ever seen!
Thanks, Unkle Ken.
That'll be enough for the time being, thank you :)
BTW I already taught my spell checker the word 'unkle' as it kept
choking over it :)
Peter Popov
ICQ: 15002700
Date: 30 Jul 1999 19:54:24
Message: <37A23A8A.ABC63CD@pacbell.net>
> Thanks, Unkle Ken.
I'm glad you found it of use to you.
> choking over it :)
  That is probably because the english spelling for unkle is uncle
Mr. POV-Nut sir ;~]
Ken Tyler
Date: 30 Jul 1999 20:43:11
Message: <37a344e9.34964293@204.213.191.228>
>Mr. POV-Nut sir ;~]
And the English spelling of 'kolor' is 'color' ;~] ... sir!
Peter Popov
ICQ: 15002700
Date: 30 Jul 1999 20:57:52
Message: <37A24964.7D0E695A@pacbell.net>
> >Mr. POV-Nut sir ;~]
> Peter Popov
> ICQ: 15002700
It is ? Actually I mispelled culler on purpose. Kind of a play on my
name and so there was no name collision with the official colors.inc
*~} ... SIR !
Ken Tyler
Date: 31 Jul 1999 09:31:15
Message: <37A2E5FE.37281A01@ndirect.co.uk>
Colour: thank you.
> >Mr. POV-Nut sir ;~]
> Peter Popov
> ICQ: 15002700
Steve
Date: 31 Jul 1999 12:03:11
Message: <37a41bf6.23268090@204.213.191.228>
On Sat, 31 Jul 1999 13:03:10 +0100, Steve <sjl### [at] ndirectcouk> wrote:
>Colour: thank you.
I stand corrected. Actually I only try to use 'color' in POV as it
saves a byte and a keystroke and prefer to use the British (English
:)) spelling wherever possible, but five years in an American
high-school are enough to wipe out any extra 'u's and the like :)
Peter Popov
ICQ: 15002700
Date: 31 Jul 1999 13:06:01
Message: <37A32B88.62FFBF91@ndirect.co.uk>
Peter
Life would be so boaring if we were all the same. ;-)
Peter Popov wrote:
> On Sat, 31 Jul 1999 13:03:10 í��, Steve <sjl### [at] ndirectcouk> wrote:
> >Colour: thank you.
> Peter Popov
> ICQ: 15002700
Steve
