POV-Ray : Newsgroups : povray.general : Regular Polygons & Prisms Server Time
27 Oct 2026 10:35:02 EDT (-0400)
  Regular Polygons & Prisms (Message 1 to 26 of 26)
Subject: Regular Polygons & Prisms
Date: 5 Oct 1999 17:59:22
Message: <37FA73D2.E62AFFB3@global2000.net>
I am trying to create a macro for making regular polygons and prisms. I
can't get one point to rotate to the vertexes.
Brendan Ryan
Subject: Re: Regular Polygons & Prisms
Date: 5 Oct 1999 19:06:22
Message: <37FA8463.E65258A@enst.fr>
> Brendan Ryan
	If I understand correctly, what you want is vrotate: it allows you to
rotate a vector (or a point) the same way that rotate allows you to
rotate an object.
		Jerome
* Always listen to experts,   * Jérôme M. BERGER
* they'll tell you what can't * mailto:ber### [at] inamecom
* be done and why...          * http://www.enst.fr/~jberger
* Then do it.                 *
Date: 5 Oct 1999 20:16:29
Message: <37FA9515.F640302@xs4all.nl>
> Brendan Ryan
I'm not sure if I understand you right but you might have a look at a macro I
made that produces (regular) polygons (with a soft edge). It's at:
http://www.xs4all.nl/~remcodek/pov.html (look for the softform-include).
Good luck,
Remco
Date: 6 Oct 1999 19:12:10
Message: <37FBD65E.919D4BFF@global2000.net>
I need 2d vectors for polygons but vrotate changes them into 3d vectors.
Thanks for help.
Brendan Ryan
> > Brendan Ryan
> rotate an object.
>                 Jerome
> * Then do it.                 *
Date: 6 Oct 1999 19:15:41
Message: <37FBD731.D0E65A14@global2000.net>
My zip file program can't open the zip file. Help!
Brendan Ryan
> > Brendan Ryan
> Good luck,
> Remco
Date: 6 Oct 1999 22:18:41
Message: <37FC0338.130FCDFF@xs4all.nl>
> Thanks for help.
> Brendan Ryan
Try this:
temp_vec=vrtotate(<0,1,0>,<0,0,120>);
vec=<temp_vec.x,temp_vec.y>;
That's how I got it working.
Good luck,
Remco
Date: 6 Oct 1999 22:21:34
Message: <37FC03E4.E2B7A5A8@xs4all.nl>
> Brendan Ryan
> > > Brendan Ryan
> > Good luck,
> > Remco
It's zipped with WinZip.
Uh-oh, I installed a new version, don't tell me that it makes zips you can't
open with older zippers.
Anyways I may have answered your question in another message. If you really want
to see the macro let me know and I'll mail it to you (and make sure you'll be
able to see it).
Good luck,
Remco
Date: 6 Oct 1999 23:18:09
Message: <37FC1001.D2A41646@global2000.net>
I downloaded the zip file again and I can see the files in it. -Must have been a bad
download. Thanks for your help. :-)
Brendan Ryan
> > Brendan Ryan
> > > > Brendan Ryan
> > > Good luck,
> > > Remco
> able to see it).
> Good luck,
> Remco
Date: 6 Oct 1999 23:40:12
Message: <37FC1530.62EAFF12@global2000.net>
I used your code but it still made 3d vectors. The last point should be the same
as the first one. This is the code that creates the vectors.
#fopen data "data.inc" append
#local rotation_no = 0;
#while (rotation_no<=sides)
#local angle_of_rotation = 360/sides;
#local temp_vec=vrtotate(<0,1,0>,<0,0,angle_of_rotation*rotation_no>);
#local vec=<temp_vec.x,temp_vec.y>;
#local rotation_no = rotation_no+1;
#write (data, "",vec,"")
> > Brendan Ryan
> Good luck,
> Remco
Date: 7 Oct 1999 05:42:06
Message: <37FC6B23.BD8C7DAA@xs4all.nl>
> #end
I'm not sure I understand where it went wrong.
The temp_vec is a 3D-vector from which you derive vec as a 2D-vector.
I tried this and I got a file with 2D-vectors (after fixing a small typo).
I agree the last point should be the same as the first and indeed in my file the
first was: <0,1> while the last was <2.44921e-016,1>. I don't know if this
really bothers you, but 2.44921e-016 is might close to 0. If you'd really like
to avoid it you could put in something like:
#if (vec.u<.0000001)
  #declare vec=0;
Not very elegant, but efficient enough. It won't really matter for the resulting
scene.
Bye,
Remco
Date: 7 Oct 1999 10:50:05
Message: <37fcb31d@news.povray.org>
POV-Ray shouldn't have a problem with 3D vectors in the prism definition (or
lathes, or sor's), as long as they lie in the correct plane (ie. XZ for the
prism, XY for the other two).  Here's an answer I posted back in July '97
when this question was asked on comp.graphics.rendering.raytracing:
  #declare NumberofSides = 5;
  #declare BasePrism = prism {0, 1, NumberofSides + 1
    #declare Rot = 0; #while (Rot < 360)
      vrotate (x, z * Rot),
    #declare Rot = Rot + 360 / NumberofSides; #end
      x}
By changing the NumberofSides, you can create any sided figure,
automatically centred around the origin.  You can then use this object
to create other objects, eg:
  difference {
    object {BasePrism scale <2, 4, 2>}
    object {BasePrism scale <1.5, 2, 1.5> translate <0, 3, 0>}
    pigment {rgb 1}}
In the above example we have scaled the first prism by 2 in width, and
the second by 1.5; you can change the thickness of the sides by
adjusting the numbers, eg: 2 and 1.9 for thinner sides, 2 and 1.1 for
thicker sides.
Date: 7 Oct 1999 16:18:29
Message: <37FCFF25.F69CC0B5@global2000.net>
Yay! It worked! I rendered a regular pentagon! But... there's still a little problem.
I used the following code:
#if (-0.000000000000000244921<=vec.u<=0.000000000000000244921)
#declare vec=<0,1>;
and the first three vectors were <0,1> when there should be only one at the beginning.
The second and third vectors had negative numbers in them.
The last vector didn't match the first one. I want them to be alike so there would be
no warnings. I might use the quadratic and cubic splines after adding the control
points. If a prism using quadratic or cubic splines is not closed, POV-Ray will
generate a error message.
Brendan Ryan
> > #end
>   #declare vec=0;
> #end
> scene.
> Bye,
> Remco
Date: 7 Oct 1999 16:36:58
Message: <37FD0458.128DFEF9@pacbell.net>
problem.
> #declare vec=<0,1>;
> #end
You can't use numbers that long in pov. Drop about 10 zeros and it
should work ok.
Ken Tyler
1100+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Date: 7 Oct 1999 18:23:50
Message: <37FD1DAB.E7F7CC86@xs4all.nl>
problem.
> #declare vec=<0,1>;
> #end
beginning.
be
> Brendan Ryan
Closing is easier if you just copy the first point to the last. There is no way
that can go wrong (the stuff in between however....)
Cheers!
Remco
Date: 7 Oct 1999 20:35:28
Message: <37FD3B62.1178E21F@global2000.net>
Now, the macro is nearly perfect. It can create whole prism statements but the part
that
omits the comma after the last vector doesn't work. Here's the code:  (which is inside
a
while loop)
Brendan Ryan
#write (data, "","\n")
#ifndef (comma_no)
#local comma_no = sides;
#if (comma_no>0)
#write (data, "",",")
#else
#local comma_no = comma_no-1
problem.
> > #declare vec=<0,1>;
> > #end
beginning.
be
> > Brendan Ryan
> Cheers!
> Remco
Date: 7 Oct 1999 22:08:10
Message: <37FD523E.F6734AD2@xs4all.nl>
that
inside a
> while loop)
> Brendan Ryan
> #ifndef (comma_no)
> #end
> #if (comma_no>0)
> #else
> #end
I'm not sure how the rest looks but this seems a bit complicated.
How about this:
#write (data,"",vec,"")
#if (counter<sides)
or something in that fashion.
Another solution, which also relates to your problem with closing the prism
could be:
#while (counter<sides)
  // create a new vec for this value
#declare vec=first_vec;
I hope this makes sense.
Don't look too much at the write-stuff, I just copied it from your example.
Good luck again :)
Remco
Date: 7 Oct 1999 23:04:31
Message: <37FD5E50.1D2D4C61@global2000.net>
Finally! The finial comma vanished! I just declared comma_no before most of the other
stuff
and moved the line that subtracted one form comma_no to the outside of a #if
statement. I
think that the later is what fixed it.
Brendan Ryan          Thank you Remco! :-)
part that
inside a
> > while loop)
> > Brendan Ryan
> > #ifndef (comma_no)
> > #end
> > #if (comma_no>0)
> > #else
> > #end
> How about this:
> #if (counter<sides)
> #end
> could be:
> #end
> Good luck again :)
> Remco
Date: 7 Oct 1999 23:11:46
Message: <37FD6004.A3A5944A@global2000.net>
I posted a image of a septagon prism in povray.binaries.images.
other stuff
statement. I
part that
inside a
> > > while loop)
> > > Brendan Ryan
> > > #ifndef (comma_no)
> > > #end
> > > #if (comma_no>0)
> > > #else
> > > #end
> > How about this:
> > #if (counter<sides)
> > #end
> > could be:
> > #end
> > Good luck again :)
> > Remco
Date: 8 Oct 1999 04:33:36
Message: <37fdac60@news.povray.org>
Andrea Ryan <ary### [at] global2000net> wrote:
: #if (-0.000000000000000244921<=vec.u<=0.000000000000000244921)
  This comparison doesn't work as expected. It will be true when the value
of 'vec.u' is less than the first value.
  Why?
  Let's take a simpler example:
#if(-0.5 <= var <= 0.5)
  #debug "Hello\n"
  This will print "Hello" only when 'var' is less than '-0.5'.
  What happens?
  First povray will evaluate the first operator, ie. "-0.5 <= var". If
'var' is greater or equal to -0.5, it will return true, which is the same
as 1, else false, which is the same as 0.
  Let's suppose that 'var' has the value 0. The comparison "-0.5 <= 0" will
return true, ie 1. Now povray will make the comparison "1 <= 0.5" which
returns false. The string is not printed.
  Let's suppose that 'var' has the value -1. The comparison "-0.5 <= -1" will
return false, ie 0. The comparison "0 <= 0.5" will return true. The string
is printed.
  Thus, the string will be printed only when the value of 'var' is less
than -0.5.
  The correct way to do the comparison is:
#if(-0.5 <= var & var <= 0.5)
Date: 8 Oct 1999 15:58:53
Message: <37FE4C07.9CBC088@global2000.net>
It uses a #switch with #range now.
Brendan Ryan
>   Why?
>   #debug "Hello\n"
> #end
>   What happens?
> is printed.
> than -0.5.
Date: 8 Oct 1999 19:00:27
Message: <37FE7698.EA91502D@global2000.net>
After a little testing, I found that the macro worked fine for prisms with
a odd number of sides, but it doesn't work prisms that have an even number
of sides.
I think the problem is in this code:
#while (rotation_no<sides)
#local temp_vec=vrotate(<0,1,0>,<0,1,angle_of_rotation*rotation_no>);
#local vec=<temp_vec.y,temp_vec.z>;
//the stuff that writes to the data file
When a prism with a even number of sides is created, one of the points has
a coordinate with an incorrect sign. Thanks for your help.
Brendan Ryan
> Brendan Ryan
Date: 8 Oct 1999 20:23:18
Message: <37FE8B28.8415B51B@xs4all.nl>
> of sides.
> #end
> Brendan Ryan
> Andrea Ryan wrote:
I don't know exactly what caused your problem but the code above has some typos.
Here is what I made of it:
#declare sides=5;
prism {
  linear_sweep
  linear_spline
  -0.5,
   0.5,
  sides+1,
//#local temp_vec=vrotate(<0,1,0>,<0,1,angle_of_rotation*rotation_no>);
#local temp_vec=vrotate(<0,1,0>,<0,0,angle_of_rotation*rotation_no>);
//#local vec=<temp_vec.y,temp_vec.z>;
#if (rotation_no=0)
  #declare vec0=vec;
vec,
vec0
pigment{rgb 1}
rotate x*90
When I tried this it worked fine.
Remco
Date: 8 Oct 1999 22:21:43
Message: <37FEA5C0.9A6CDFB7@global2000.net>
Thanks! It works for any prisms. I rendered a 1000-gon in 2 minutes and 22 seconds.
It looked like a cylinder. :-)
Brendan Ryan
> > of sides.
> > #end
> > Brendan Ryan
> #declare sides=5;
> prism {
>   linear_sweep
>   linear_spline
>   -0.5,
>    0.5,
>   sides+1,
> #if (rotation_no=0)
>   #declare vec0=vec;
> #end
> vec,
> #end
> vec0
> pigment{rgb 1}
> rotate x*90
> Remco
Date: 9 Oct 1999 12:05:22
Message: <37FF67F3.84418C5C@xs4all.nl>
> Brendan Ryan
Next step: take a polygon with a an even number of sides and scale each odd (or
even) side up or down. I.e. translate the point towards the center or further
away from it.
What happens?
You can do similar things with other regular (or irregular) repeating
transformations.
Ciao!
Remco
Date: 9 Oct 1999 21:03:39
Message: <37ffe5eb@news.povray.org>
Remco de Korte <rem### [at] xs4allnl> wrote:.
typos.
> #declare sides=5;
> prism {
>   linear_sweep
>   linear_spline
>   -0.5,
>    0.5,
>   sides+1,
> // #local temp_vec=vrotate(<0,1,0>,<0,1,angle_of_rotation*rotation_no>);
> // #local vec=<temp_vec.y,temp_vec.z>;
> #if (rotation_no=0)
>   #declare vec0=vec;
> #end
> vec,
> #end
> vec0
> pigment{rgb 1}
> rotate x*90
In the first line you've commented out above, the rotation of +y by 1 degree
about the y axis actually has no effect (although your second version is
more correct).  The real change is in the code in which you extract the 2D
vector from the rotated 3D vector: in the commented-out line, the temp_vec.z
component will always be 0 which obviously won't give the desired result!
At any rate, as I posted in my other reply it is not necessary to convert
the 3D to 2D vectors as you have done, as long as the vectors lie correctly
in the X-Z plane.  Also, for better coding you should remove the calculation
of the rotation angle outside the while loop; otherwise, you're simply
recalculating the same value over and over again!  Finally, for the closing
of the prism/polygon, all you really need is the unrotated radius vector at
the beginning and end.  Using this you can avoid any rounding errors and
unnecessary calculations, eg:
#macro regular_prism (Sides, Height1, Height2)
  #local RotAngle = 360/Sides;
  prism {linear_sweep linear_spline
    Height1, Height2, Sides+1, x,
    #local Count = 1; #while (Count < Sides)
      vrotate (x, y*RotAngle*Count),
    #local Count = Count + 1; #end
    x}
From here you could adjust the basic code to create star-shaped prisms, or
use curved splines to create petal shapes, etc.
Date: 9 Oct 1999 21:47:27
Message: <37FFEF26.9DC7DE39@global2000.net>
Thanks. I used your suggestions and they shaved some time off a render of a 1000
sided prism.
Brendan Ryan
> typos.
> > #declare sides=5;
> > prism {
> >   linear_sweep
> >   linear_spline
> >   -0.5,
> >    0.5,
> >   sides+1,
> > #if (rotation_no=0)
> >   #declare vec0=vec;
> > #end
> > vec,
> > #end
> > vec0
> > pigment{rgb 1}
> > rotate x*90
>     x}
> #end
