I'm having fun making flythroughs of the 3dnoise function in the
superpatch for povray.
I am trying to understand this mathematically. If I use:
3dnoise(x,y,z)
I get something with a uniform distribution of porosity. As the
threshold approaches 1.0, the percent porosity approaches 0 (% density
approaches 1.0). However, if the threshold is 0.0, there is not 100%
porosity.
I want to understand how to change the radial density of the noise
function. Suppose I want to make a sphere where the density approaches
0 at r=R. How would I do this? Intuitively, I might try:
3dnoise(x^0.5,y^0.5,z^0.5)
. So far, nothing is yielding precisely the results I'm looking for.
I am probably the wrong person to answer this, since I don't understand the
question. But I just figured out something about noise3d that maybe you
already know but if not.. maybe it will help, it might even be correct.
noise3d<x,y,z> gives one iteration of noise acros each face.
noise3d<x*3, y*3, z*3> gives three.
noise3d<x*3, y*3, z*3> *0.5 gives half the depth,
noise3d<x*3, y*3, z*3> *5.0 gives five times the depth
At least that is what it seems like. See "Noise3d" in p.b.i.
Greg M. Johnson <gre### [at] my-dejanews com> wrote in message
news:37FA64D8.6F1532FE@my-dejanews.com...
> 3dnoise(x,y,z)
> porosity.
Yes, you are linearly scaling the structure. Your density will not change as a
function of position if you make scalar operations like those. I want to make
a sphere that is "100% dense" at r=0, but gradually tapers off to zero or a
minimum density at r=some R. This is easy to do with media.
Where does 3dnoise come from? It's not in the superpatch docs or documented
anywhere that I know of...
> > 3dnoise(x,y,z)
> > porosity.
> 3dnoise(x,y,z)
> porosity.
noise3d (x*f, y*f, z*f)*(R-sqrt(x^2+y^2+z^2)) where f adjusts the
regularity of the noise (the smaller, the smoother). Note that this will
give you some noise outside the sphere too, to avoid this, you could use
noise3d (...)*max(0, R-sqrt(...)) instead.
Jerome
* Always listen to experts, * Jérôme M. BERGER
* they'll tell you what can't * mailto:ber### [at] iname com
* be done and why... * http://www.enst.fr/~jberger
* Then do it. *
That must be an omission. It's been in there since the original isosurface
patch, where it was (marginally) documented. I must have just missed it,
along with cool things like &, |, and %.
Nope. This is a solid sphere.
I've used R=500 and a dozen orders of magnitude for f.
I've had a little luck with adding an "*f" term to the right side. But this
is not the concept, although intuitively the math must be VERY CLOSE....
> > 3dnoise(x,y,z)
> > porosity.
> Jerome
> * Then do it. *
Try adding some linear function of the radius instead of multiplying.
As you shift the "field" of noise3d through the threshold value it
will appear to cause the "solid" chunks to grow and shrink.
What you get also depends on what threshold you use; if you use zero
with the above formula you'll always get a solid sphere.
What about noise3d(...)-sqrt(...)/R ?
Jerome
* Then do it. *
Whaaaaa. I give up. Could you or Jerome provide an idiot's version that I could
just cut and paste, including threshold, etc.etc.etc.etc.
Even more confused. I either get
A) cool-looking uniform coral-like(*) stuff, OR
B) a solid sphere.
Nothing inbetween.
(*) Whoa: cool idea for underwater scene........
SPHERE!
> Jerome
> * Then do it. *
Hey man, why don't you just try:
#declare f=.040;
#declare R=399;
isosurface {
function
{noise3d(x*f,y*f,z*f)+((x^2+y^2+z^2)/R^2)
accuracy 0.01
threshold 1
bounded_by {
sphere{0,500}
pigment{Green}
finish{ambient 0.1}
normal {crackle}
And then sleep on the results??
> SPHERE!
> > Jerome
> > * Then do it. *
On Tue, 05 Oct 1999 19:13:26 -0400, "Greg M. Johnson"
noise3d + min(0,1-sqrt(x*x+y*y+z*z))
and play with the threshold. I have only used the superpatch once but
I can guess that this formula will be 100% dense below a certain
radius (probably sqrt(threshold) ) and fade to noise3d at a distance 1
from the origin. Try it out.
Peter Popov
ICQ: 15002700
I posted a message regarding your questions at the images section of this
newsgroup.
> 3dnoise(x,y,z)
> porosity.
Samuel Benge
E-Mail: STB### [at] aol com
Website: http://members.aol.com/stbenge
