Sorry if this question has been posted and answered somewhere, but I
have searched the postings and faqs and can find nothing on it.
I have a newish eMachine (low priced PC) with an AMD 333Mhz K2 that
renders all my old povray scenes slower than my laptop with a 120Mhz
Pentium (like 1/3 the speed rather than 3 times faster, as I would think
it should). This very slow rendering performance occurs under both the
Win98 and Mandrake Linux 6.0 OS installations on the eMachine so it does
not appear to be a OS or software installation problem to me. (Perhaps
the K2's L2 cache? but the laptop is older and only has smallish
processor cache anyway.)
Any information would be greatly appreciated.
What kind of memory do you have plugged into it? If it's DRAM instead
of SDRAM, you're seeling yourself short.
ICQ: 46085459
Subject: Re: AMD K2 (eMachine) slow pov-ray performance
Date: 27 Sep 1999 03:58:01
Message: <37ef2389@news.povray.org>
Scott Sexton & David Lewis <2b### [at] cheerful com> wrote:
: I have a newish eMachine (low priced PC) with an AMD 333Mhz K2 that
: renders all my old povray scenes slower than my laptop with a 120Mhz
: Pentium (like 1/3 the speed rather than 3 times faster, as I would think
: it should). This very slow rendering performance occurs under both the
: Win98 and Mandrake Linux 6.0 OS installations on the eMachine so it does
: not appear to be a OS or software installation problem to me. (Perhaps
: the K2's L2 cache? but the laptop is older and only has smallish
: processor cache anyway.)
The MHz amount tells very little about the real speed of the computer.
I remember that some time ago a friend of mine had a 486DX4 overclocked
to 120MHz but it was a lot slower (in games, demos, etc) than my
486DX2 66MHz. The reason was that he had an ISA video card while I had a
VLB one. It's incredible how a slow video card can slow down a twice faster
computer so much.
Of course the problem in your case can't be the video card, but the point
is that the MHz amount can be very misleading. Some poor component can make
the computer slower than other with half of MHz's.
Perhaps you have a slow component slowing down the whole thing.
Also I think that AMD has a quite slow FPU.
Not that much ! It's MAYBE 10% slower in FPU than equivalent Intel,
but the memory management is better, so for Pov it's equivalent and
even sometimes better...
There is a big problem with that computer ! (maybe it's the P120
who is wonderful, hehe !)
Fabien.
Actually, POV depends pretty much on raw MHz. AMD's FPU might be a factor, but I
don't think the classic Pentium has a much better unit. Perhaps something
radical has been done in the BIOS, like turning off all processor caches. I
cannot think of any peripheral that could slow down POV by a significant amount.
How is the overall system performance? Does it swap a lot? Also, could you give
a benchmark time for POV (e.g. skyvase.pov @ 640x480 AA 0.3)
Margus
> computer so much.
On Mon, 27 Sep 1999 14:48:22 +0300, Margus Ramst <mar### [at] peak edu ee> wrote:
The earlier Pentium fpu was much better than both the units on the 486DX
and the early AMD processors. I installed a Pentium OverDrive© on my
486DX2-66 and my Skyvase.pov rendering time (640w x 480h, +a0.3) went from
32 minutes down to 15 minutes, which is more than the clock speed
improvement should show. AMD has greatly improved floating point performance
of its later K6 and K7 processors but I don't know how they compare with the
latest Pentium IIIs using POV-Ray.
POV-Ray does work the fpu quite thoroughly. This is why most common
magazine benchmarks often don't apply if one is looking for the fastest
machine to run POV-Ray. They often use a test suite of programs that do not
perform as intensive floating point math as POV-Ray does. The converse if
also true - a machine that runs POV-Ray fast does not necessarily have the
good video performance that is required of fast 3d game play. Most test
suites take video performance into account but POV-Ray doesn't care if you
have a video card installed.
The POVBench site at http://www.haveland.com/povbench/index.htm is a
database of user statistics on various machines. It might just be me but I
have a difficult time trying to make sense of so many entries. Many of these
personal computers are home-built, which may affect how fast they can render
Skyvase. Quite a few entries show that the submitted results use custom
compiled versions of POV-Ray. Without knowing exactly what their POV-Ray
source contained these results cannot be directly compared with others. I
mean, why would someone running Windows choose to compile their own
executable, unless they've modified the source?
Alan
Thanks for your reply John. It's PC100 SDRAM.
> > instead of SDRAM, you're seeling yourself short.
Assuming it's not faulty, it's not the problem.
ICQ: 46085459
Date: 28 Sep 1999 01:09:09
Message: <37f04d75@news.povray.org>
In article <37ef2389@news.povray.org>, Nieminen Juha <war### [at] cc tut fi> wrote:
This is what I was told about my Evergreen 586 upgrade to my PC. A while ago I
rendered that simple glass that I made in sPatch... it took 7 hours to render
(setting max_trace_level high was part of the problem) but I was told then
that the AMD FPUs aren't that fast, however I never did hear back from that
person if they knew if it was all AMDs or just the older 586s....
This is something I need to look into. When I replace this PC with a new one
(I'm thinking about keeping the machine I got and run Linux on it, but anyway)
I don't want to go out and buy a poor performace FPU if I'm going to continue
to do stuff with POV (and I think I'm hooked now.... "you know you've been
raytracing too long when you setup a seperate configuration and icon for the
POVray Newsgroups).
PHIL
I've just tried to find out about this. It's not easy to tell. AMD may be a bit
slower on FPUs but is more efficient on memory management and other things so
I've been told. The way I interpreted all information Intel is a few percent
faster but it's also more expensive (about 15% over here - with 450Mhz).
I opted for AMD but I don't think that was a 100% rational choice.
Remco
Date: 28 Sep 1999 09:15:11
Message: <37f0bf5f@news.povray.org>
I have an AMD K6/233 at home. When I bought it, it was the best bang for the
buck. Yes, the FPU might be a little slower, but I'm betting it's not slow
enough to make up for the extra 100 MHz or so I could afford by not buying
Intel.
Date: 28 Sep 1999 10:05:43
Message: <37f0cb37@news.povray.org>
Even if I wanted to use AMD I can't. (not that I'd want to)
The reason being that 3D Studio MAX is specific to Intel processors.
Date: 28 Sep 1999 16:39:07
Message: <37f1276b@news.povray.org>
Just saw a stock market analyst commenting on AMD this morning. He said
they were the worst managed business (in the US, World? something like that)
and they cannot keep the supply up with demand for their CPUs. I'm just
telling about this, not opinion from myself. I only go with Intel because
I'm a grazing animal <moo>.
Lance Birch <lan### [at] usa net> wrote in message
news:37f0cb37@news.povray.org...
> factor, but I
> something
> caches. I
> significant amount.
> you give
The overall performance of the eMachine has been very good. It has only
been POV that shocked me. It does not need to use swap space much at all
since there is 160 MB of SDRAM and the POV scenes were fairly simple
although time consuming because of reflections.
Skyvase.pov rendered in 4 minutes and 57 seconds at a quality of 9,
640x480 AA 0.3. I will also try skyvase.pov on my old P120 laptop.
I will check the BIOS to see if I have inadvertently turned off the
processor cache or something else.
Thank you for the input Margus (and others too) !
(Later the next day) Well, I found the problem now that I studied the
system a little more carefully. It seems that both Netscape under Linux
and IE5 under Windows take lots of processor time even when they are
sitting idle. I usually have a browser open almost continuously since I
use a cable modem with an always live connection. Thanks again for all
the feedback on my question, the rendering time is now what it should be
for skyvase.pov on a K6-2 333 Mhz, about 2 minutes. I just have to make
sure I close any resource hogging browsers down when they are not in use
if I am rendering a time consuming scene!
Date: 29 Sep 1999 01:58:02
Message: <37f1aa6a@news.povray.org>
That's exactly correct actually.
That's why Gateway is dropping their AMD line soon. AMD had problems with
the processors and couldn't supply Gateway with enough, causing a 5 week
backlog (which lost Gateway $200 million BTW...).
Also the other problem with AMD right now is that the Athalon processors are
relying on boards made in Taiwan, and of course the earthquakes caused
problems for the board manufacturers meaning that there is a shortage of
boards that support the new chip...
If they don't watch it they might just sink like Cyrix did.
Bob Hughes <inv### [at] aol com> wrote in message
news:37f1276b@news.povray.org...
that)
Date: 6 Oct 1999 01:55:53
Message: <37fae469@news.povray.org>
In article <37F190F1.15F6CFE8@cheerful.com>, Scott Sexton & David Lewis
Sounds like maybe it's time to look into Opera... you gotta figure that MS is
he king of BloatWare and Netscape isn't the smallest piece of software out
their either. Back in the day (when I only had 4MB of RAM) I test installed a
copy of IE4 (I was going to be installing it for someone on their office
computer) and it rendered my Windows 3.11 useless from the splash screen on. I
had to manually removed the components from DOS before I could get it up and
running again.
BTW have you checked it when shutting off all sorts of Java?
PHIL
