POV-Ray : Newsgroups : povray.general : Torus pattern suggestion Server Time
27 Oct 2026 11:45:44 EDT (-0400)
  Torus pattern suggestion (Message 1 to 17 of 17)
Subject: Torus pattern suggestion
Date: 15 Sep 1999 17:06:21
Message: <37E00892.1BEC2B42@isd.net>
Suggestion for the next version of POV:
A torus pattern, like the sphere one, but a torus...
Would be major radius 1, along the X-Y or X-Z plane, with the value
gradually dropping off from 1 at minor-radius 0 to 0 at minor-radius 1.
Subject: Re: Torus pattern suggestion
Date: 15 Sep 1999 17:12:41
Message: <37E00B55.DFDFC5A@pacbell.net>
And your argument for the inclusion of this and what benefits it would offer
are ?
  This is not a challenge of your suggestion. If you have a valid reason
you think this should be added you should make your request as compelling
as possible. Many requests for new features are posted here but few
follow through with why they think the time should be spent on adding
them.
Ken Tyler
See my 1000+ Povray and 3D Rendering and Raytracing Links at:
Date: 15 Sep 1999 17:49:59
Message: <37e01487@news.povray.org>
To keep people like me from using superpatch just to make smoke rings with
media?
Seriously, the only use I can think of (not that this really means anything)
is for media.
Ken <tyl### [at] pacbellnet> wrote in message
news:37E### [at] pacbellnet...
offer
> are ?
> them.
> Ken Tyler
Date: 15 Sep 1999 22:25:11
Message: <37E0534A.97886FD7@isd.net>
Like Bill said, main use would probably be media. AARGH, what was my idea?!!?
*5 minutes later* Oh yeah. My original thought came about from the engraving
text on a ring question. A torical pattern could be used along with text objects
in an orthographic view to create a height_field that would be perfect for
engraving the text on the ring. Yes, that was it!!! I remembered!!!
> are ?
> them.
> Ken Tyler
Date: 16 Sep 1999 06:55:57
Message: <37E0CD11.8890D7F7@compuserve.com>
Well, for that, you could use onion or wood pattern. And perhaps a
spherical or cylinderical pigment_map to limit those patterns, or you
could just use multiple objects, or you could use a disk object...
The only place I think a torus pattern could be useful is in media. But
it would be extremely useful there. (flourescent bulbs, dust rings from
a shock wave, etc...)
BTW, doesn't the Superpatch already have a toroidal pattern? Of course,
with the Superpatch, you can make any pattern with the isosurface
functions used as patterns.
Date: 16 Sep 1999 07:20:33
Message: <37E0D3D8.926F46BE@mitre.org>
It's not too hard to determine distance from a circle, but you do
realize that a repeating torus pattern would look a little funny near
the axis of symmetry...
Xander
Date: 16 Sep 1999 09:28:22
Message: <37e0f076@news.povray.org>
Even there, it's of limited usefulness if it has a fixed major radius.
Date: 16 Sep 1999 09:59:39
Message: <37e0f7cb@news.povray.org>
    Maybe I don't know what you mean. I was just thinking that I would be
happy with a major radius of 1 and a minor radius of 1. Everything else can
be done with density and scale. As long as the density starts at 1 along the
focus of the minor radius and goes to 0 and stays there.
    Isosurface torus pretty much requires a toroidal container which means
that you cannot combine it with another media in the same container.
Date: 16 Sep 1999 10:39:10
Message: <37e1010e@news.povray.org>
The problem is that if I want a toroidal density pattern with a major radius
of 1 and a minor radius of .1, I have to scale the pattern by 100 and then
put my entire color map into the range [0 .. 0.001]  That doesn't scale very
well.
Really?  Are you sure?
//------------ cut here --------->8=========
#declare myfun=function{max(0,1-sqrt( y*y + sqr(sqrt(x*x+z*z)-5)))}
sphere { 0,6.1 hollow
  interior { media {
      density {function {myfun}}
      emission .2 intervals 10 samples 5 5
  texture {pigment {color rgbt 1}}
light_source {<-20,20,-20> rgb 1}
camera {location <0,5,-10> look_at 0}
Date: 16 Sep 1999 11:49:06
Message: <37e11172@news.povray.org>
    Well, no, I wasn't sure (I should include a standard disclaimer whenever
I say any thing about POV and especially Isosurface).  I had read someone's
recommendation (maybe your's?) to use max() but hadn't had a chance to try
it yet. Too many things on too few burners. Thanks.
Date: 16 Sep 1999 13:18:18
Message: <37E129C8.7B9BF847@erols.com>
> 1.
I posted source for two versions of this pattern, either to one of the
programming groups or to the unofficial patch group, with recommended
names of ring and donut (or something like that).  One version returned
a value of 1 at the minor radius focal point, dropping to 0 when the
minor radius reached, and remaining at 0 for all points outside of the
torus.  This was intended for smoke rings, angel's halos, parts of
neon sign lettering, etc.
The other version started with a value of 0 at minor_radius=0, rose
to 1 at minor_radius=1, and then repeated this range for minor radii>1.
This pattern was more suited for simulating the interior of curved
branches, etc.
The major radius was 1 for both patterns.
John
ICQ: 46085459
Date: 16 Sep 1999 13:19:24
Message: <37E12A0A.275CEDA7@erols.com>
Maybe the user wants the funny look...
ICQ: 46085459
Date: 16 Sep 1999 16:56:13
Message: <37E157AE.4B8E450E@isd.net>
Hello? Earth to Ron...
You can scale it to any radius you want, and the minor radius is set by
adjusting the color_map numbers. Therefore ant torical shape you want.
Date: 16 Sep 1999 16:57:24
Message: <37E15AC5.5AE1BC1B@merlin.net.au>
I have posted a patch for both the official source and the super-patch
which does exactly this.
And yes it does excelent smoke rings.
Cheers, PoD.
Date: 16 Sep 1999 17:04:35
Message: <37e15b63@news.povray.org>
Earth to David...
I said that.  I also said that if you scale it to a major radius of 100
and a minor radius of .1, you have to keep your color map in the range
0 to .001.  That's a small range, and we all know how well POV likes
small numbers, no?
Date: 17 Sep 1999 10:51:25
Message: <37e2556d@news.povray.org>
Larry Fontaine <lfo### [at] isdnet> wrote in message
news:37E00892.1BEC2B42@isd.net...
    Having played around some more, I wonder if there is a way to make a
torus pattern rotate along it's minor axis, so as to make a true smoke ring
animate?
    I suspect that at this point it will take isosurface if it can be done
at all. It would have to be a radial pattern rotated around  the major axis
somehow.
Date: 17 Sep 1999 11:56:26
Message: <37e264aa@news.povray.org>
>animate?
>somehow.
Well, radial is just atan2(x,z) scaled and rotated appropriately.  There isn't
yet an atan2 in the superpatch, but there will be.  At that point, you'll be
able to compute a function like what you're looking for, but it won't be
pretty.
