POV-Ray : Newsgroups : povray.general : setting options Server Time
6 Nov 2026 22:32:08 EST (-0500)
  setting options (Message 1 to 14 of 14)
Subject: setting options
Date: 24 Aug 1999 14:48:43
Message: <37C2E91D.F69BA756@xs4all.nl>
I was wondering: wouldn't it be nice if you could set the command-line options
in the scene-file?
Remco
Subject: Re: setting options
Date: 24 Aug 1999 22:51:56
Message: <37C34B71.FF3DDA0C@panama.phoenix.net>
Yes.
Anthony L. Bennett
http://welcome.to/TonyB
Non nova, sed nove.
Date: 24 Aug 1999 22:54:45
Message: <37C35AC2.EB8E49AD@pacbell.net>
> in the scene-file?
> Remco
That would be true. It would also be nice if the program read my mind :)
Ken Tyler
See my 850+ Povray and 3D Rendering and Raytracing Links at:
Date: 25 Aug 1999 00:46:26
Message: <37c3737a.598729805@news.povray.org>
  "error on lines [1..1000000]. LF/CR expected but "{" found instead."
Alan
news.povray.org - where POV-Ray enthusiasts around the world can get
together to exchange ideas, information, and experiences with others
Date: 25 Aug 1999 00:56:06
Message: <37C37734.E729B08@pacbell.net>
> Alan
Maybe it would not be such a good idea after all. I am left handed so my
code would be not only non indented but backward as well. Try to parse
that !
Ken Tyler
Date: 25 Aug 1999 06:03:33
Message: <37C3BE22.86719FA4@spleen.waw.pl>
> > Alan
> that !
> Ken Tyler
Hey! That's not a problem. I wrote a program which reads the text
from a
file and writes it backwards :)
Wojtek Bauman aka reaver | rea### [at] spleenwawpl | ICQ: 3429749 |
http://reaver.spleen.waw.pl | PGP: finger bau### [at] inxpmwawpl |
Date: 25 Aug 1999 06:25:56
Message: <37C3C47C.25F4F3AF@pacbell.net>
> from a
Ok but can you write a program that reads the text from my mind and
write it foreward ? :)
Ken Tyler
Date: 25 Aug 1999 10:42:27
Message: <37c400d3@news.povray.org>
Ken a écrit dans le message <37C35AC2.EB8E49AD@pacbell.net>...
>> in the scene-file?
>> Remco
    But I am Ken, I am... You and me are for life...
>Ken Tyler
Date: 25 Aug 1999 10:58:15
Message: <37c40487@news.povray.org>
Jean Montambeault a écrit dans le message
<37c400d3@news.povray.org>...
>>> in the scene-file?
>>> Remco
mind
    Dam! That was supposed to read "POV" in the "from" column !
    Was a joke. Don't worry.
>>Ken Tyler
Date: 25 Aug 1999 14:37:31
Message: <37c437eb@news.povray.org>
Parse the entire file looking for command-line options? Might not be
feasible, since they need to be done first. Reading a Ini file or
command-line from the parse would be good for calling upon
interactions though. Say you tell it to render to a line (pixel
position for that matter) or to a clock value then do something else
(like shift the pov script by external editing) before going back and
continue another parse and pick up tracing where it left off.
Actually, there may be a way to do plenty already as is, much of which
I am still a "newbie" at.
Remco de Korte <rem### [at] xs4allnl> wrote in message
news:37C2E91D.F69BA756@xs4all.nl...
> in the scene-file?
> Remco
Date: 25 Aug 1999 14:52:02
Message: <37C43B1B.2BDFD74B@pacbell.net>
> Bob
There could be rules of hierarchy established to facilitate this. Take
for example you currently cannot use a declared object until you create
it i.e.
object {foo}
#declare foo = sphere{0,1 pigment())
  For instance you could specify that any command line options must be at
the top of the file before any scene description language is used or it will
be ignored or an error is returned. I have often wished for this feature and
see it as a way to help eliminate having to have multiple files to render a
scene. Wouldn't it be nice to set all of your animation options in the same
file for quick changes ? The same is true of many of the other features that
demand they be specified on the command line or by the appropriate settings
in an ini file.
  I have always assumed there was a technical reason prohibiting this so have
just let it slide. Remco "the rebel" de Korte just happened to voice what I
have been afraid to voice myself.
Ken Tyler
Date: 25 Aug 1999 16:01:35
Message: <37c44b9f@news.povray.org>
My guess would be non-related sections of the source code. Part to do
the Ini and command line type stuff and part to do the script parsing.
As you know, the only thing relayed back to a scene file is 'clock'
and a few things like scene file name, etc. By "technical", you could
say that there is no passing interpretation probably which exists
outside the two sections. Yet there might be after all. I never did
get the 3.0, nor the 3.1, source. Had a thought, remember the screen
resolution manipulation in that custom compile? Answer must be there
somewhere then.
Ken <tyl### [at] pacbellnet> wrote in message
news:37C43B1B.2BDFD74B@pacbell.net...
this
> Ken Tyler
Date: 26 Aug 1999 08:41:18
Message: <37C53086.CF7545C2@spleen.waw.pl>
> > from a
> Ken Tyler
Hmm... No problem with this too. But first you must write
your_mind.h
and give it to me :)
Date: 26 Aug 1999 10:59:46
Message: <37C55661.7A44E0D2@ida.utb.hb.se>
> in the scene-file?
> Remco
At least it would be nice to be able to access the command-line options inside the
scene-file...(for example #if(clock=Initial_Clock) ... )
Mikael Carneholm
Dep. of Computer Science
Högskolan i Borås, Sweden
http://www.studenter.hb.se/~arch
sa9### [at] idautbhbse
