Can someone explain to me why the text at the site below is not readable ?
Mostly I see bunch of little boxes with text headers in english. Is it
a language setting problem with netscape ? I tried different settings but
it made little difference.
http://web.kyoto-inet.or.jp/people/tantaka/modeler.html
Ken Tyler
See my 700+ Povray and 3D Rendering and Raytracing Links at:
The ".jp" indicates the site is hosted in Japan. I don't have my browsers set
to show pages in anything other than english. As a result, when I drop in on
Finnish, Japaneze, etc... sites, I see the gobbledeegook you seem to have
seen. I tried backtracking to the fellow's index page, but could not find any
obvious link to a set of english language pages.
David
> David
I suspected the .jp connection but wanted confirmation that my software wasn't
wigging out on me :)
Ken Tyler
<grin> These days, that's quite a valid concern. For instance, I just rebooted
because when I clicked on something on my desktop, it registered clicks on upwards
of a half a dozen icons all at the same time. And, of course, I was lucky enough to
be trying to double-click on my email program. :{P Nothing like having half a dozen
programs all trying to load at the same time on my tired old P166. Turns out the
keyboard cable was loose and was registering as if the shift-key was being pressed.
David
In article <37C### [at] pacbell net> , Ken <tyl### [at] pacbell net>
It is a side in Japanese. Usually you need to setup your OS to support these
character systems. I know that Windows can work with both, Russian and
English systems, so I suppose by installing some extra libraries you can get
support for all languages (in this case Japanese) under a regular English
(or any other language) Windows...
Thorsten
e-mail: tho### [at] trf de
David Heys <cel### [at] hotmail com> wrote:
: The ".jp" indicates the site is hosted in Japan. I don't have my browsers set
: to show pages in anything other than english. As a result, when I drop in on
: Finnish, Japaneze, etc... sites, I see the gobbledeegook you seem to have
: seen.
Finnish? I have never seen such a page in Finland. I think that they all
use regular latin-1 coding.
> : seen.
I don't even have latin-1 coding as an option in my version of Netscape.
I have my default set to western ISO 8859-1 and have options to various
flavours of Baltic, Central Europe, Chinese, Cyrillic, Greek, Japanese,
Korean, Turkish, and Unicode.
Ken Tyler
See my 850+ Povray and 3D Rendering and Raytracing Links at:
All you need to do is have a Japanese font installed on your system.
You can get the Bitstream Cyberbit font, or just go to Microsoft's IE site and
get the "international language packs". All they really are is just a font file
and a .NLS file. They install to the system, so then Netscape can use whatever
language you put in.
"My new computer's got the clocks, it rocks
But it was obsolete before I opened the box" - W.A.Y.
Ken:
I love a good mystery.
The respondants have taken what seems to be the right tack. Japanese
consistently mix in western characters and names, even in their
Japanese-language printed material. All without translation or even
transliteration. Just 'plop.'
BUT... a look at the HTML source does NOT remind me of Unicode or extended
character sets. Too many $-signs and not enough characters wrapping into
the upper range of the normal 255-character ASCII set. It doesn't look
like other Japanese sites, if memory serves.
If my off-the-cuff peek has led me astray... I'll blame it on sleep
deprivation. If not, I'd guess somebody's HTML editor DLL went all scwewy.
If this helps, hows about some comments on my Image Size vs. Rendering Times
problem?
Matt
Ken wrote in message <37C### [at] pacbell net>...
>Ken Tyler
Ken:
If you like, I could run this by a couple of my clients in Japan-- one a
magazine editor.
problem?
Matt
>Ken Tyler
Matt Swarm wrote:
> Ken:
That sounds plausable.
> problem?
> Matt
I have been hesitant to respond to this particular suggestion because I
honestly don't know if it is relevant or not. I know from personal experience
that the only time a larger image takes significantly longer to render than
a smaller image does is when advanced features in Pov are used creating a need
to trace a greater number of rays. A simple sphere, one light source, and a
camera can be rendered at high resolutions in surprisingly short amounts of
time. I personally stick with the theory that load needs to balanced by means
of content and not size.
It should not be a surprising that on my p200 machine the skyvase file is
still an adequate challenge and takes a few minuets to render. It may only
take a few seconds on a Cray computer but wouldn't that be expected because
of it's significantly greater computing power ?
Ken Tyler
> > : seen.
To help out, Latin-1 is ISO-8859-1.
If you were only involved in the esoteric field of i18n then you'd know that :-)
Oh, and byt the way, Windows uses their own CP-1252, not Latin-1/8859-1. Almost the
same, but just different enough to cause headaches.
Matt Swarm wrote:
> Ken:
Yes, it is Japanese, but not the most common encodings. It is not EUC-JP nor
Shift-JIS. It is "JIS" or ISO-2022-JP. But additionally it has a lot of
Katakana/Hiragana and not so much Kanji. This can also make it look different.
Just use Netscape on RedHat Linux 6.0 and you'd see it all by selecting
"Japanese (Auto-Detect)". For those of you on Windows, you have to first have
Unicode or Japanese font installed and then change the Netscape preferences to
use that font for Japanese.
Now, if you love a good mystery, here is how to solve this one. First, get a
Japanese font setup and working. You can test it out by hitting my favorite
test site: http://www.sanrio.co.jp/ (I'm pretty sure they'll be around for a
while)
Next, go to the mysery site. Now that you are there, by the URL you guess it's
Japanese. First try viewing using "Japanese (EUC-JP)". Nope. No dice. Now try
"Japanese (Shift-JIS). Nope. Not a Japanese MS Windows kinda site :-). Now try
"Japanese (Auto-Detect). Bingo! So it's Japanese, but not one of those two
encodings. That leaves "JIS"/ISO-2022-JP.
Ya done good Jon!
I was going to take the easy way out and quiz a couple of clients in Japan--
assuming I could find a monment in the middle of packing for this move--
aaaarrrghh!
nor
different.
have
to
a
a
>while)
it's
try
try
Matt Swarm wrote:
> Ya done good Jon!
> aaaarrrghh!
Now, if you were only running Netscape on Linux, all would have worked great.
Jon A. Cruz a écrit dans le message
<37C2478D.4E733503@geocities.com>...
>Matt Swarm wrote:
>> Ya done good Jon!
in Japan--
move--
>> aaaarrrghh!
worked great.
Maybe that's because Linux is already Chinese ot most fo us ? ;-)
Unless you happen to be running Red Hat Linux and you go to a web page
heavy in Java. The everything goes KABLOOY!!! (There are work-arounds,
but Netscape unter Linux is Quite buggy. For more info see
www.searchlinux.com)
Ken Matassa
> Ken Matassa
Silly Matassa, Java's for Applications.
Jon A. Cruz: Java programmer who keeps Java disabled in Netscape.
Ken;
The site you refer to, namely
is in fact in Japanese. The encoding is ISO-2022-JP, and should appear
similar to the attached graphic if your web browser is configured correctly.
Gregg
Download 'jp.jpg' (40 KB)
Preview of image 'jp.jpg'
Yah, disabling Java is a good idea. What I was refering to were Java
applettes, which seem to cause the Linux port of Netscape to do some
funny things, depending on system set up. There is an whole newsgroup at
searchlinux.com devoted to this problem.
Ken Matassa
I know.
Some time I might bother working on that, but not now. Just not worth it.
About the only thing that I'd ever need an applet to work for is to access
the MS MSDN library. And when I'm in Linux guess how much I need that.
