POV-Ray : Newsgroups : povray.general : Working with Text Server Time
6 Nov 2026 22:52:12 EST (-0500)
  Working with Text (Message 1 to 21 of 21)
Subject: Working with Text
Date: 27 Jul 1999 19:54:43
Message: <379e46c3@news.povray.org>
Can't seem to find much on working with text as graphic objects.  The POV
package has an example which, blissfully, uses True Type fonts.
In addition to color and texture, I would like to bevel, round the face,
illuminate from inside, wrap the line of text around a sphere or cylinder
(inside or out) and the like.
Any thoughts?
Thanks,
Matt
Subject: Re: Working with Text
Date: 27 Jul 1999 20:42:03
Message: <379e51db@news.povray.org>
There are ways to do these things. Do you mean as actual features
internal to POV-Ray or as scripted in a file? Take a look at this URL
here if you haven't already.
 http://www.xs4all.nl/~remcodek/softtext.html
> Any thoughts?
> Thanks,
> Matt
 mailto://inversez@aol.com?Subject=PoV-News
Subject: Re: Working with Text Objects
Date: 28 Jul 1999 03:48:27
Message: <379eb5cb@news.povray.org>
Hi Bob:
While I have greater aspirations for POV-Ray than eye-candy typography
(Hey... I LIKE candy!), my most immediate need is to produce gooey, shiney,
sparkling, fancy and eye-catching titles and logos for web graphics.
Crude starting example at:  http://member.aol.com/ideatoys/logos.htm
Sure, there are plenty of $10 programs out the which bevel, level and
dishevel fonts, then coat, color and wet them down.    I want to do ALL
those naughty things to letters, and then some-- I just want to do it under
programmatic control.
If I can do the grunt work in Moray or somesuch, fine--  so long as I can
change the text string, color, size, etc., using a parameter file.
I'll study the link you kindly provided.  My choice at this point, however,
because of the vast number available, would be to use TrueType fonts as
starting points.
Any thoughts?
Thanks,
Matt
Bob Hughes wrote in message <379e51db@news.povray.org>...
>> Any thoughts?
>> Thanks,
>> Matt
> omniVERSE: beyond the universe
>  http://members.aol.com/inversez/homepage.htm
Date: 28 Jul 1999 07:53:44
Message: <379eef48@news.povray.org>
If the softtext utility outputs triangle meshes, you could use the PCM
macro to do even more transformations to the fonts (like adding spikes or
growing hair to them or morphing them) which are not possible with softtext.
  See http://www.geocities.com/SiliconValley/Lakes/1434/pcm.html
Date: 28 Jul 1999 08:22:28
Message: <379EF77E.D073E664@puzzlecraft.com>
You can curve, twist and bend text any way you wish with Chris Colefax's
Object Bender.
I'd like to learn edge sculpting and face rounding myself. I think, but am
not sure, that POV treats the font like a spline sweep so it might be a bit
tricky rounding the face out.
steve
> Any thoughts?
> Thanks,
> Matt
Date: 28 Jul 1999 09:39:50
Message: <379f0826@news.povray.org>
Steve <ste### [at] puzzlecraftcom> wrote:
: You can curve, twist and bend text any way you wish with Chris Colefax's
: Object Bender.
  I think that bending ttf's is SLOW.
Date: 28 Jul 1999 09:51:50
Message: <379F09D4.F3896274@pacbell.net>
> : Object Bender.
I would agree with you on that.
Ken Tyler
mailto://tylereng@pacbell.net
http://home.pacbell.net/tylereng/links.htm
Date: 28 Jul 1999 15:44:25
Message: <379f5d99@news.povray.org>
Someone had done a bevelling include here someplace, most likely found
in one of the scene-file groups dating back to last summer or fall I
believe, not sure. It deformed the ttf text somehow. Looking at that
logo you gave the link to it didn't seem too difficult to do that at
least. You can easily difference shapes from the text to achieve some
new looks, I did the English alphabet letters individually once,
subtracting a inversed sphere from them. The existence of a complete
text changing include file of the sort you suggest is unknown to me.
Like you say, there are certainly programs which manipulate it though,
but it wouldn't be difficult to do the basics via macro or such I'm
sure.
Matt Swarm wrote:
> Hi Bob:
> starting points.
> Any thoughts?
> >> Any thoughts?
Date: 31 Jul 1999 11:04:47
Message: <37a2ec6d.82005290@news.povray.org>
On Tue, 27 Jul 1999 16:53:37 -0700, "Matt Swarm" <ide### [at] aolcom>
>Any thoughts?
IMO the easiest way to bevel the text is to export text to a modeller
and bevel it there (IIRC there way a simple modeller called "VSPOV" or
similar which could take in a 2D DXF object - as produced by Corel
Draw exporting text - raise it into 3D and bevel it).
However, what you're left with is meshes rather than true text...
Cheers,
Cliff Bowman
Why not pay my 3D Dr Who site a visit at http://www.who3d.cwc.net/
PS change ".duffcom" to ".net" if replying via e-mail
Date: 1 Aug 1999 13:06:31
Message: <37A4726F.A618D798@xs4all.nl>
Why wouldn't those things be possible? Have you tried it?
Remco
Date: 2 Aug 1999 02:32:57
Message: <37a53b99@news.povray.org>
Remco de Korte <rem### [at] xs4allnl> wrote:
:>   If the softtext utility outputs triangle meshes, you could use the PCM
:> macro to do even more transformations to the fonts (like adding spikes or
:> growing hair to them or morphing them) which are not possible with softtext.
: Why wouldn't those things be possible? Have you tried it?
  Actually yes. I downloaded it and tried it. I couldn't do anything but
type the text and save. I was unable to do ANY transformations to the text.
  Am I missing something?
Date: 2 Aug 1999 02:51:55
Message: <37A54043.1B18BA66@xs4all.nl>
You could have a look at the example(s), like the verbal image. Source is in the
scene-files group.
Remco
Subject: Text Objects- Manipulating in POV- SoftFont and Corel
Date: 2 Aug 1999 04:40:06
Message: <37a55966@news.povray.org>
Thanks Cliff:
Second time this weekend I've encountered notion of using Corel to map and
output text for use in other programs.  Will have to give it a try.
Gave SoftFont a brief whirl a few days ago.  Could not find a way to change
the font to another TT face-- I may have missed something in my brief
tryout.  Otherwise, it did indeed map out the glyph data into a textfile
array for use in an .inc file.  Would be a great starting point if I can
make it see other fonts.  Otherwise, I may have to write my own code which
uses font API calls.
I'll reinstall Corel and give that a try, too.
Matt
Date: 2 Aug 1999 15:32:06
Message: <jerry-0208991232070001@cerebus.acusd.edu>
If you don't mind the letters being straight, you can wrap them around a
sphere or cylinder using a macro (though you may find the "Object Bounds"
part of the superpatch exceedingly useful here).
Bevel text with the following macro:
//creates beveled text
#macro bevel_text (bevelFont, bevelText, bevel_depth, text_depth,nbr_of_objects)
   union {
      #local i = 0;
      #while (i < 1)
      //This is the bevel itself
      text {
         ttf bevelFont, bevelText, bevel_depth, <bevel_depth,0,0>
         matrix < 1, 0, 0,
               0, 1, 0,
               cos(i*2*pi), sin(i*2*pi), 1,
               0, 0, 0 >
      //This is what is behind the bevel.
      //Set text_depth to 0 if you only want the bevel.
      #if (text_depth > 0)
         text {
            ttf bevelFont, bevelText, text_depth, <bevel_depth,0,0>
            translate <cos(i*2*pi)*bevel_depth,
                  sin(i*2*pi)*bevel_depth,
                  bevel_depth>
   #declare i = i + 1/nbr_of_objects;
Don't ask me how it works, I didn't create it. I just converted it to work
as a macro :*)
Jerry
Subject: Re: Text Objects- Manipulating in POV- SoftFont and Corel - mea culpa
Date: 2 Aug 1999 16:45:25
Message: <37A602E9.1A29D554@xs4all.nl>
Matt Swarm wrote:
> Thanks Cliff:
> Matt
I'm not sure but if you're referring to SoftText (SoftFont) the problem with the
font is rather silly. In screen-resolutions below 1024x768 not all of the
program window was visible and you couldn't resize it. Someone else brought this
to my attention yesterday. I've changed the program so you'll be able to see the
whole window with other resolution-settings too (and resize it).
I hope this helps.
NB the program is still far from flawless, (useful) comments are welcome.
Remco
Date: 3 Aug 1999 06:13:38
Message: <37a6c0d2@news.povray.org>
>as a macro :*)
>Jerry
Looks great, Jerry, but how does it work?   :-)
Looking forward to trying it out.   As for how it works, my next
experimental approach would involve joining compound text objects, so I'm
wondering about that 'union' directive.
Maybe a guru could lend some 'expert-tease' here?
Matt
Subject: SoftText and Mr. Whipple
Date: 3 Aug 1999 06:23:46
Message: <37a6c332@news.povray.org>
Remco de Korte wrote in message <37A602E9.1A29D554@xs4all.nl>...
with the
Thanks.  That possibility occurred to me.   I'll have another try ASAP.
It always pays to program for the LRCD- 'Lowest Reasonable Common
Denominator.'    In the case, that would be 640x480.  Millions still use it-
much easier to see so long as most monitors are CRT instead of LCD.  I
suspect the resolution will begin to disappear when LCD screens become
ubiquitous.  Or at least ubiquitouser.  :-)
Matt
Subject: Re: SoftText and Mr. Whipple
Date: 3 Aug 1999 06:39:01
Message: <37A6C6FD.76793E81@xs4all.nl>
> Matt
Normally I do so if I know the program is meant to be used on other systems then
just mine. This was something I made because I needed it for some things and
when the subject of using text in POV came up I thought it might be a friendly
idea to share it. Some people seem to object but I still hope (and know) there
are some others who can see the use of it. It's not really the program that is
great or the idea behind it, just that it gives you a heap of raw data on which
you can unleash your own creative genius using POV. I'm very curious about what
others have done with it, because I think working with text(objects) in POV can
give much more interesting results than the eye-candy-type 3D-text programs.
Remco
BTW who is Mr. Whipple?
Subject: SoftText- 'Objections- to It
Date: 3 Aug 1999 19:42:05
Message: <37a77e4d@news.povray.org>
Can't see why anyone would 'object' to the program, unless on the grounds
that one is making use of the intellectual property of another in the data.
But since fonts are actually meant to be USED, this argument gets a bit
thin.  Legally, if the creator of a font knew the font data was used
initially- but the result looked nothing like the font after processing-
there would be few grounds for action.  The original data has become little
more than 'inspiration.'
BTW, Mr. Whipple is a old character-- making a comeback-- on American
commercial ads.   He specialty was squeezing soft toilet tissue.
Matt
then
and
friendly
there
is
which
what
can
programs.
>Regards,
>Remco
Date: 11 Aug 1999 08:13:53
Message: <37b14698.130154984@news.povray.org>
On Mon, 2 Aug 1999 01:06:24 -0700, "Matt Swarm" <ide### [at] aolcom>
wrote:
>Thanks Cliff:
No problem. I've tinkered around with the "Beveled Text" macro Jerry
supplied, and Superpatch POV, and got some quite interesting results
(actually boring but.. well, you know). It *looks* loke the macro
might actually be faster than using a mesh generated via Corel -> DXF
-> 3D Bevel. In some ways the quality is higher too (and in some ways
lower - there's never a win-win scenario).
Cheers,
Cliff Bowman
Date: 12 Aug 1999 15:03:40
Message: <37b31a8c@news.povray.org>
Thanks, Cliff-- been there and plan to return.
Matt
