POV-Ray : Newsgroups : povray.general : Surface Grid? Server Time
27 Oct 2026 15:55:35 EDT (-0400)
  Surface Grid? (Message 1 to 5 of 5)
Subject: Surface Grid?
Date: 27 Jul 1999 11:33:13
Message: <379dd139@news.povray.org>
I am looking for a texture to use as a surface grid (gridlines on any
surface) for to make a transparent object showing only these gridlines, a
kind of skeleton of the given surface.
I would be thankful for ANY IDEAS!
tilo
t.e### [at] tu-bsde
Subject: Re: Surface Grid?
Date: 27 Jul 1999 12:07:37
Message: <379DD8F1.3586673C@lstrust.com>
I've got a few of those at home... I'll post one in p.b.images when I get
home
Steve
> tilo
> t.e### [at] tu-bsde
Date: 27 Jul 1999 22:38:38
Message: <379E6D50.6819D506@virginia.edu>
Well, I didn't find the images, but as I said in my email all it was was a
solid square with a cross through it.... in fact it would be easy to render
and I just might.
Steve
> tilo
> t.e### [at] tu-bsde
Date: 28 Jul 1999 01:25:42
Message: <379E9355.B9868024@pacbell.net>
> tilo
> t.e### [at] tu-bsde
 There is a real problem with doing this because all pigments and pattern
types used in pov exist in 3 dimensions. Otherwise you could simply over-
lay a Y and X gradient pattern made of black and clear.
Ken Tyler
mailto://tylereng@pacbell.net
http://home.pacbell.net/tylereng/links.htm
Date: 28 Jul 1999 02:17:30
Message: <379ea07a@news.povray.org>
Tilo Eggeling <t.e### [at] tu-bsde> wrote:
: I am looking for a texture to use as a surface grid (gridlines on any
: surface) for to make a transparent object showing only these gridlines, a
: kind of skeleton of the given surface.
: I would be thankful for ANY IDEAS!
  I think that the easiest way is to use the uv-povray for this (although
it doesn't work with all the objects). See my post at povray.text.scene-files
about a gridline macro I made. For a preview, see:
http://www.cs.tut.fi/~warp/gridtest.jpg
